Question about Whirlpool Dryers
When dryer starts the drum wont move..it is a Roper large capacity electric dryer non stackable
    New Friend:
If the drum won't move but you can hear a motor running, the drive belt has probably slipped off of the drum or motor pulley or has broken. Try turning it by hand with the motor off and then turning the dryer on again.
Posted on Oct 24, 2010
SOURCE:
My GE stackable washer is pouring out water while filling up, when spinning makes horrible noise and tub goes crazy
The issue is that a shock or spring that balances the tub has come loose and pulled a hose off when it broke. So the shocks or the springs are bad. The hose might be able to just be put back on.
Feb 23, 2015 | General Electric GE 5.4 cu. ft. Large...
I have a stackable kenmore washer dryer heavy duty extra large capacity 2 speed motor. The dryer has been making squeeling noise and has stopped toumbling around what can the problem be.
Could be the belt which connects motor and dryer drum. Could be the drum support rollers. Replace both either way -- common problem.
Jun 03, 2011 | Kenmore Dryers
My Roper dryer is a little over a year old. When I turn it on it makes a humming noise but the drum does not turn and then I smell a burning smell. I cam move the drum with my hands and it will turn. Of...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 15, 2011 | Roper REX3614KW Electric Dryer
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
No heat, motion, but light is on and timer ticks
Check the thermal fuse on the blower housing. It is for over heat condition and non resettable.
eric
Jun 29, 2009 | Kenmore Dryers
When I turn on the dryer you can hear the juice going thru like its about to start but nothing happens, drum doesnt move. I checked, its not stuck. dryer only 1.5 yrs. old- happened suddenly
most of the time on your model it is the dryer main fuse that pops,you can pop the top and look to the right of the drum on the back wall all you will see a little round fuse,you can get it from your local appliance parts store for around $10,if it happened all of the sudden could have just been a power surge pop it-mike
Apr 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2009 | Roper REX3614KW Electric Dryer
My gas dryer spins but doesent get warm at all
hi debra,when you start your gas dryer you should here two clicks, if so then your ignitor should begin to glow.if not two clicks then its going to be your thermol fuse.armed with that give me some feed back an will go from there.God bless ,tom
Jan 04, 2009 | Dryers
Roper dryer
what do you mean wont cut off ?? the heat?? the drum? was this on the top part of the heationg element?
Jun 09, 2008 | Roper RES7646KQ Electric Dryer
It's not a Kenmore it actually a Whirlpool Large Capacity, Special Edition
see if you can turn the drum by hand and try again then reply to me
Dec 31, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
53 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
