Question about Janome Sewing Machines
I just purchased a Janome Juno 3434D, although it looks to be an awesome machine, I am totally clueless how I can change the different style of capabilities it has. The box says I can do 34 different stitches, not to mention the threading. Is there a book I can purchase or a website I could go to, to see what settings to do for each style?
  • Janome Master
  • 12,731 Answers
Posted on Oct 24, 2017
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Get online & find a manual that explains everything.
Posted on Oct 23, 2017
SOURCE:
dupina
  • 110 Answers
SOURCE: tension
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine.
Posted on Nov 30, 2007
  • 35 Answers
SOURCE: looking for a instruction book for janome limited edition sewing machine my style 30
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link to them:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Posted on Aug 16, 2008
  • 323 Answers
SOURCE: how to thread sewing machine
Yes, but it is a good basic machine.
Here's how to thread it:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Mar 20, 2009
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
Zenqi
  • 208 Answers
SOURCE: problems threading my janome serger
One critical hint:
You must thread the loopers BEFORE the needles, otherwise it won't stitch. Begin with upper looper, lower looper, right needle then left needle.
Posted on Jan 16, 2010
I am looking for the instruction manual of the janome v 74088 619
Search the internet for:
Make + Model + the word "Manual"
Feb 29, 2016 | Janome Sewing Machines
I need a manuel janome serger 3434d
try this link for the manual and parts
Janome 3434D Parts
Aug 25, 2014 | Sewing Machines
Janome Juno 3434d wont make a chain
If it was hitting before you stopped, it's likely that the looper either got bent or was knocked out of time. I would take it in for repair.
Dec 23, 2012 | Sewing Machines
My Juno janome serger 3434d upper looper and lower looper keep jamming into each other.
it sounds like the serger needs to be checked to see if it's out of
time, at a sewing machine shop
Sep 23, 2012 | Janome 6019QC Mechanical Sewing Machine
Stitching is too loose on the Juno Janome Serger Model 3434D
sergers the most frustrating machines. Every time you change fabrics you go through a tension adjusting phase.
First make sure you have threaded the machine in the proper order. upper looper, lower looper, then needles from right to left. Always thread any machine while the presser foot lever is in the UP position.
If you ever break a thread... you MUST pull all threads and rethread using the proper order.
Ok that's out of the way. Pull all your threads and get out several pieces of the same fabric scrap. Thread each pathway with a different color. This will help you determine which thread is giving you fits. Sew a test strip. Which thread is loose? tighten/loosen that tension. Keep doing this until you have a well balance seam. Then clip the colored threads starting with the upper looper thread, tie off to your proper color for your seam pull the thread through and up through the throat plate. proceed in this manner with lower looper, right needle, left needle. Sew a test seam.
Good luck.
Aug 08, 2012 | Janome Sewing Machines
I have a juno by janome 3434d serger. when i ruffle, the first thread keeps breaking and it will not ruffle correctly. what can i do?
Whenever I've had an issue with threads breaking, it's usually the tension or it's not threaded right. You probably have the first thread lapping over one of the bottom threads it shouldn't be lapped over. I would suggest you put all of your tensions back at factory level, pull out all the threads and rethread the whole thing. Thread the two bottom ones first without moving the handwheel. (Make sure the handwheel has the two top needle in the up position. When you thread this machine, you must not have to turn the handwheel. If you do, you change something.) Then thread the top needles. After that hold all four threads and make a string. Test on the same type of fabric as what you're working with. Adjust tension as needed. HTH
SharonH
Aug 31, 2010 | Janome Sewing Machines
Sewing Machines Logo
160 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
