A vertical green line has showed up on my low hour LG 50py3d and does not go away. It comes about midway down the screen.
  • 1 more comment
  • mmedlen Oct 24, 2010
    All other functions are working fine to the best of my knowledge.
    I did not mention that the green line becomes very difficult to see when a picture is on he screen.
    With dark colors its is difficult to see. It is most apparent over blue. I am working on sending you a picture, however, it won't show up well on the pictures I have taken as it tends to get muted.
  • mmedlen Oct 25, 2010
    Pictures do not show line adequately to transmit. The intensity of the line varies from day to day, at this time it is very light and is only evident when the tv is connected to a device, ie sat dish, dvd, receiver, etc. Sometimes when the tv is in process of connecting the line is very distinct against a black backdrop.
  • 4,889 Answers
Colored vertical lines on the tv are usually associated to faulty logic control board(adressing block malfunction) or the sustain boards. Are all the other functions in the tv fully operational?
Posted on Oct 24, 2010
  • 1 more comment
  • eagle338
    eagle338 Oct 24, 2010
    One last thing before I confirm it. Can you please upload an image of tv with it turned on, upload it to imageshack.us and get me the direct link?
  • eagle338
    Ok. Send it across we will see. If its not very bad then a component level repair might be possible.
  • eagle338
    eagle338 Oct 25, 2010
    Ok. I have seen this one before. It looks like you have bad capacitors on one of the sustain boards. How good are your electronics/soldering skills?
SOURCE:
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
Hi i have a 50" LG plasma which now has 2mm wide vertical pinkish lines from the top to the centre?? is this fixable??
This could be a board or the panel. It is hard to say. Both can cause this. Have a repair shop check it out.
Oct 14, 2009 | LG 50PY3D Plasma TV
Vertical color lines show up and don't go away
If they are thin vertical lines then I'm afraid there is a fault within the plasma screen & this would need replaced which is a very costly repair.
Sep 25, 2009 | LG 50PY3D Plasma TV
Gateway gtw p42m303 promblem need advice
I think you need a control PCB.
If the Set has an LG Screen, which I think it does, it is going to be a PDP42X2.
They commonly produce vertical Red and or Yellow lines that come and go.
6871QCH060Q is the boards part number.
You should just check it is an LG PDP42X2 by peering through the holes in the top, use a flashlight, there are some labels along the inside at the top.
One will have the Screen number on it.. LG PDP42X2 or PDP42X2A.
Sep 06, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Green lines that extend across the screen vertically
If it looks like a veritcal pin stripe it most likely is a de-laimiation of the flex cable to the glass, this can only be fixed by replacing the pannel. If it is in warranty get it in right away.
Sep 01, 2009 | LG 42LC2D 42 in. LCD HDTV
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me [email protected]
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Ekse
