Question about LG GT540 Cell Phone
I cant connect my phone to my pc downloaded lgsuite but nothing else happen,s. I get a message cant connect to server
    New Friend:
  • 85 Answers
Try to get access point of your operator and put that manually in pc suit setting
Posted on Oct 24, 2010
SOURCE:
Error connecting to server
Error messages can mean several things. You may have lost internet connection for a short period or your tablet may be having problems with downloading. This is a common problem that happens to devices if they aren't working properly with internet or you could have interferance. Try down loading later at night, late late and see if it just happens to work.
Feb 28, 2014 | Android 4.0 Tablet PC
I cant test my 7941g because i keep getting a small bullseye on the bottom left corner of the screen
Your phone is trying to connect to a TFTP server address to download a firmware and/or config file update. You need to figure out what IP address it is trying to connect to (You may have to use wireshark or another packet sniffer to determine this).
Once you know the IP it is trying to connect to, you'll need to set up a small network with a TFTP server running on that same address, and feed the phone a firmware update and/or config file. It will likely not fully boot unless it gets a firmware update.
Cisco Phone 48V Power Supply
Dec 05, 2012 | Cisco 7941G IP Phone
How to change settings in Outlook to delete message from server after downloading
Hi, follow the steps below. Don't change any of your settings since they already work, but when you get to step 7 this is where you check whether or not you want to remove the emails from the sever.
Open Outlook 2003 then:
  1. Click Tools ' E-mail Accounts.
  2. Select Add a new e-mail account and click Next.
  3. Select POP3, then click Next.
  4. Enter the following information:
    • User Information
      • Your Name: Type your name as you'd like it to appear when you send an email message.
      • E-mail Address: Type your Yahoo! Mail Plus email address (for example, [email protected]).
    • Server Information
      • Incoming mail server (POP3): Type pop.mail.yahoo.com
      • Outgoing mail server (SMTP): Type smtp.mail.yahoo.com
    • Login Information
      • User Name: Type your Yahoo! ID (your email address without the "@yahoo.com").
      • Password: Type your Yahoo! password.
    • Check the Remember password checkbox if you don't want Outlook to prompt you for your password each time you check your mail.
    • Do notcheck the Log on using Secure Password Authentication (SPA) checkbox.
  5. Click the More Settings button. The Internet E-mail Settings dialog box appears.
  6. Select the Outgoing Server tab:
    • Check the My outgoing server (SMTP) requires authentication checkbox.
    • Make sure that Use same settings as my incoming mail server is selected.
  7. Select the Advanced tab:
    • Under "Incoming server (POP3)," check the This server requires an encrypted connection (SSL) checkbox. The number in the "Incoming server (POP3)" field usually changes automatically from 110 to 995. If it doesn't, type 995.
    • In the Outgoing server (SMTP) field, type 465. Under it, check the This server requires an encrypted connection (SSL) checkbox.
    • If you want to save your Yahoo! Mail messages on both the Yahoo! Mail server and on your computer, check the Leave a copy of messages on the server checkbox. If you want your messages to be deleted from the Yahoo! server once Outlook has downloaded them onto your computer, leave the box unchecked.
    Note: After your messages are deleted from the server, we cannot retrieve them.
  8. Click OK to close the Internet E-mail Settings dialog box.
  9. Click Next and then Finish.
  10. Close and restart your Microsoft Outlook.
Jun 05, 2012 | Microsoft Office Outlook 2003 for PC
I recently bought a samsung B3210 cell phone, cant read or send emails. its keeps on saying server error. what can i do to fix this
Here is a quick tutorial of configuring Samsung Star S5233 Star 3G S5603 S5600 Preston Star WiFi for setting up the email client inside the phone with its POP3 Settings for G mail NOTE VERY FIRST ENABLE POP3 FROM YOUR G MAIL ACCOUNT SETTINGS LOG IN TO YOUR G MAIL ACCOUNT ON TOP RIGHT CLICK ON SETTINGS THEN CLICK FORWARDING and POP3 THEN ENABLE POP3 FOR ALL MAIL OR YOU CAN SELECT OTHER OPTION. BUT AT LEAST POP3 MUST BE ENABLED. THEN SAVE CHANGES POP3 G mail Settings For Samsung Star Cellphones Go To Menu Messages Click Settings Email Then Touch Email Setup Wizard Notice will Touch OK Give name to your account E g G mail Enter your email id your name at g mail.com Then Enter Password for your account Incoming Server type POP3 Incoming Server pop.g mail.com Outgoing Server SMTP smtp.g mail.com Secured Connection Off Then touch OK it will display your POP3email account configured successfully Now press back button and tap on Email Accounts, then touch the email account you have just created. There some more option than above you just have to edit that recured Connection: Off POP3 Port 995 SMTP Port 587 Now tink he option APOP Log in Download Limit 500 Secured connection SSL choose SSL for second option only not for first option Retrieving Option Choose Subject only Keep On Server Tick My Address Username Password same as you entered above POP before SMTP Dont Tick SMTP Auth Tick Same as POP3 IMAP4 Tick And Finally Save All Settings.That s it Now you can retrieve your message from your mail box and on Download to download all messages But Do you want your Samsung star phone to automatically download your messages Here is a small option they have given for that.Go To Message Settings Email Receiving Options Download Limit 300KB Auto polling Home Network Only Following option is time after when email is downloaded automatically Polling Frequency 30 Minutes you can choose higher if you want Send read report: Tick And again your emails will be automatically recovered from server at every 30 minutes. And you get notified near your message notifier on your home screen if there is any unread emails.You can also optionally block email id s or subject that you don t wish to receive on your Samsung Star
Dec 13, 2011 | Samsung B3210 Cell Phone
My printer can not print. I tried to follow troubleshoot and restarted the spooler nothing happened. It showed the message that says "printer lost its connection to server" the name of the...
did you already try all the set up of your printer?. you said showed error message lost its connection to server that means you need to re install your printer to access the server. you need the CD installer of your printer then run the software so that your printer can now connect to server.
Apr 12, 2011 | Office Equipment & Supplies
Why wont my htc trophy 7 install xbox live games it says to connect to wifi or pc i connect to pc but nothing happens help plz
If you see an error message saying "Connect to a Wi-Fi network or connect your phone to your PC to complete the download," disregard it. At this time, you can only download apps or games larger than 20 MB using Marketplace and a Wi-Fi connection on your phone.
Dec 09, 2010 | HTC 7 Trophy Cell Phone
How to stop sending message. If we unknowling press send button in galaxy 3 mobile
This problem sometimes happens. But to be honest, the problem has nothing to do with your phone. The copy of the sent message got stuck on your wireless carrier server. This is server side issue and not an issue with your phone.
You need to contact your wireless carrier and inform them that a specific message keeps on sending. They need to access their server and manually remove the stuck message.
Thank you and good luck!
Firesnake
E-mail / Messaging Specialist
Nov 20, 2010 | Cell Phones
I cant connect to internet, always asking me to
To connect to the internet from your mobile phone, it is absolutely necesary to have a data plan activated since the connection from your phone is not the same as from you PC. The pc connects mostly trough a ground internet connection where you phone connects firstly to a signal router(usually big antenas on top of smaller buildings)and after that it goes to a server. From this server,your info goes to a sattelite,thus meaning that your operator is involved in a lot of costs. To activate data plan you should call your operator,ask for activartion on your number and ask them to send you connectivity settings(in the case of the Phone in the picture ask for gprs/edge settings).After that,you can connect freely to any web page in the limit of your data plan or in the limit of you pocket. Free games can be downloaded from www.sharemobile.ro wap.waptrick.ro
Dec 17, 2009 | Nokia 6300 Cell Phone
I cant view and friends cant view my web cam while
1. check your internet connection
2. if there is nothing wrong, try to download and install a newer version of Yahoo Messenger
Oct 10, 2009 | HP Pavilion dv6000z Notebook
Can not recieve email using Outlook
Check out your incoming / outgoing server details and test settings once from Outlook->Account settings. Also check for dns settings if you are using any vpn connection. Let me know if this works.
Mar 12, 2009 | Microsoft Office Outlook 2003 for PC
LG GT540 Cell Phone Logo
81 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
