I cannot find mY COMPUTER gATEWAY SNID? - Computers & Internet
    Sniper:
  • 63 Answers
The serial number is located on the right hand side of the desktop tower near the bottom of the side panel on a white label with a 22 character serial number. On older systems the serial number may be located on the back or bottom of the case.The same white label will be located to the back side if its a laptop.You can also find it on the BOX.For 2010 laptop,it will also inside tha Battery Bay.
For desktops that shipped with the Microsoft® Windows® 7 Operating System, Acer provides an application entitled Identity Card, which can be used to display the serial number for your desktop.
To launch the Identity Card software:
  1. From the Start menu, click All Programs.
  2. Click on the Gateway folder.
  3. Click on Identity Card.
Alternatively, the serial number will be located in the BIOS which can be entered by pressing the Delete key /F2 key when turning the desktop on.
Posted on Oct 24, 2010
SOURCE:
Connect http 192 168 51
Go to your command prompt and Ping your IP where you find out the default Gateway for your router. If you are not able to find the correct IP address for your router than use http://kb.linksys.com/Linksys/ukp.aspx?vw=1&docid=ebe56f15763e4c27b44816c831d68f95_3997.xml&pid=80&respid=0&snid=2&dispid=0&cpage=search for checking the IP for linksys router and Linksys Router Support for any help and support.
May 27, 2014 | Linksys Computers & Internet
I want to know how to restore my DX4200-09 to factory settings?
· Click "Start" on your Windows desktop. Navigate through "All Programs" and "Gateway." Click on "Gateway Recovery Management."
· 2
Click "Restore" when the Gateway Recovery Management window pops up, which will take the system back to the default factory specifications. A box will pop up asking for confirmation, click "Yes" and then "Start." You may have to enter a password as well, but only if your particular Gateway had a password set.
· 3
Wait for the computer to restart. A "Restore from factory default" box will appear, requiring you to click "Next" twice in a row. Click "OK" in the box that appears next, and wait for the hard drive partition to be created. The factory default installation will then be moved over to the hard drive.
· 4
Click "OK" in the box that appears and wait for a second Gateway restart. Several minutes will pass as Windows "starts for the first time." When restarting finally finishes, a "Set Up Windows" dialog box will appear. Click "Next," followed by checking the license agreement box, and then "Next" again.
· 5
Enter a user name and picture, if desired, and a computer name. Also, customize the background wallpaper for your desktop, optionally. Click "Next."
· 6
Click "Use Recommended Settings" on the Protect Windows-based dialog box that pops up.
· 7
Set your correct date and time settings in the next box. Select your location in the following screen. Click "Next," followed by "Start" to finish.
· 8
Wait while Windows checks for your individual Gateway computer specifications and adjusts accordingly. This will likely take several minutes, so leaving your computer for a short time is fine. Windows will then prepare your hardware and finish your Gateway restoration process, including the installation of Gateway Recovery Management. Once completed, your Gateway is good to go and ready at factory settings.
hope this helps
Jun 25, 2012 | Gateway DX4200-09 PC Desktop
MOTHER BOARD
FixYa is not affiliated with Gateway. You need to contact Gateway or your laptop supplier for instructions on the warranty claim.
Dec 17, 2011 | Gateway Computers & Internet
Serial number and snid number for an acer iconia tablet so i can get the screen repaired
If you can see the screen partially you can get the code SN and SNID by the following route
  • Go to Settings
  • About tablet
  • Device Information
  • At the bottom will be the SNID and code SN
Comment back if you can't get it this way.
Aug 18, 2011 | Acer Iconia Tab A50010S32u Notebook
My laptop said that i need to active my window but i couldn't find my snid because the bar code is lose , what should i do
Can't find the key code for your Windows,,,hmmmm then you won't be able to activated Microsoft keeps thier keys codes in a...hmm, a voult. You might try calling Microsoft and see if they will help you to local your key code, and if not.....sorry but your out of luck.
Apr 07, 2011 | Gateway Computers & Internet
Please i was format my computer, i have network controller , ether net controller is missing , and audio , video, my computer is gateway ,win xp 3 pack , i don't know how get it the SNID number
Hi: I suggest you go to Gateway website and download the drivers for you different devices. Just input you model number under drivers and support and you should find the drivers you need.
Mar 28, 2011 | Gateway Computers & Internet
How do I replace the monitor on a Gateway profile 5?
Hi hhenra, I don't have a great answer you sorry to say. I looked at the specs at Gateway, and there are detailed instruction on changing almost everything on the Profile 5, except the monitor. I tried chatting with customer support but without the SNID (serial number) they could not help. I tried to find a replacement part and the monitor is the only component not listed. I could find no online instruction at all, I did find many people with the same issue but no solutions. The best I can do at this point is point you to the customer support chat, I could not even find a non pay tech support phone number. Here is the link to chat, have your SNID ready: Also here is the link to there site for paid instruction, but it is not cheap: Hope they can help you and good luck.
Dec 29, 2010 | Gateway Profile 5 PC Desktop
Where can i find the audio and video drivers for Gateway m-2408j?
You will get the drivers for your gateway from the www.support.gateway.com website.Please use the serial no/snid no of the computer for getting the drivers.Also select the correct operating system.
Nov 02, 2010 | Computers & Internet
Open Questions:
SBCglobal MAil HeLpliNe {1-/855/*536/*5666/}#[email protected] NuMbER SUPPORT NUMBER This SbCgLoBaL MaiLUSA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiLUSA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the SbCgLoBaL MaiLUSA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiLUSA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiLUSA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact SbCgLoBaL MaiLUSA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiLUSA Calling SbCgLoBaL MaiLUSA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiLUSA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiLUSA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiLUSA's phone numbers against each other. Contacting SbCgLoBaL MaiLUSA in General While I855%536%5666 is SbCgLoBaL MaiLUSA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiLUSA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Oct 16, 2019 | Best Computers & Internet
Computers & Internet Logo
654 people viewed this question
Ekse
Alun Cox
