Question about KitchenAid Dishwashers
We went to run our dishwasher and lights are out....nothing works......house fuse fine. Been told to look for fuse box inside of dishwasher panel but cannot identify.
  • 1,531 Answers
If the circuit breaker is good then you need to check the main power line to the unit and make sure everything is connected properly.
Posted on Oct 24, 2010
SOURCE:
Lg LDF6920ST has no power. I went to turn on to run and nothing happens. Does not light up or anything. Was working fine this morning. Now nothing. Checked and made sure the breaker was not blown.
First check the small electrical box at and behind the kick plate below the door. Possible loose connections, usually wire nuts make the connection, turn them clockwise to tighten, check for melted wires at the connection. If all ok test there with a voltage meter at the white and black wires. Should be around 110. If nothing house issue, if power dishwasher power button or eoc issue. You can reset the eoc by disconnecting power for 5 min then reconnect.
Oct 30, 2013 | LG Dishwashers
My dishwasher will not run. None of the lights are on. The D/W ran fine a few days ago. Nothing has occurred. Checked fuse box and there has been no disruption of power. The model # is GU 1500 XTL 83....
The most probable thing wrong is a THERMAL FUSE that is clipped to the control panel housing.
If your fairly mechinacally inclined and want to check that,remove the screws from all around the inside of the door when its opened,seperatae the inner/outer door panels and remove the cover off the control board and check for contunuty on the thermal fuse. THe first thing to do before taking apart the door is TURN OFF POWER TO DISHWASHER AT THE FUSE PANEL.
the part number for the thermal fuse is 8193762 it could be purcahsed at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
partselect.com
Gene
Aug 26, 2011 | Whirlpool Dishwashers
Dishwasher was running and power went off
It is mounted on the main control board inside the door. It is a white square on the side of the board housing. To check it you will need an ohm meter. If it is bad there will be no continuity. Make sure the power is off before you do this! Good luck.
Apr 30, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
Sep 22, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Frigidaire dishwasher fdb2415lf will not turn on. Was working fine, no fuse blown, not disconnected.
I have one of these modles and yesterday after it finished I noticed a lilttle green light on below the main options, a little lock that is telling me to "hold to unlock" not sure what that means, so tried this morning to "hold" nothing happened as need to run the machine, and right now there is no response. HELP!!!!!!!
May 31, 2009 | Frigidaire 24 in. FDBB944C Built-in...
Hi, I have a KitchenAidDishwasher (Model KUDP01FL). It's worked well for a few years. Yesterday, when we went to turn it on, none of the lights on the buttons were on. WE can't turn it on at all. The...
Kill the power to the unit. Pull the control panel down to access the control board located on the right hand side of the panel. There will be 2 wires coming in to a white plastic clip on fuse located on the side of the control board. It will have a plastic pliable shield over it. Pull the 2 wires and check for continuity across this fuse. If no continuity then go to parts house with model number of unit and ask for thermal fuse for your unit. Replace this fuse following the instructions included in the kit and use all the parts included in the kit.
Apr 11, 2009 | Dishwashers
Where is the fuse box on a Kitchenaid dishwasher, KUDP02CR?
There is no fuse box inside the dishwasher. The fuse box or electrical panel for your house is where you shut off the power to the dishwasher.
please mark this answer as a fixya!
Mar 09, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
No power to control panel after power surge
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jan 05, 2008 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
136 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
