Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Will not start. Have cleaned carb and replaced gaskets. Spark plug fires when layed against block. Used ignition tester with plug still installed and can see it is firing. Can see fuel in cylinder but will not hit at all. Even put small amount of gas mix directly into cylinder and will not hit. Used compression tester and after 3-4 pulls shows 92 pds.
    Brigadier General:
  • 4,088 Answers
I would expect more pressure than what you have recorded. Remove the muffler and turn the engine over slowly while watching the condition of the piston, ring(s), and cylinder wall. If there is severe scoring of these parts, suspect that the machine has been operated with no, or insufficient oil in the fuel. This will require replacement of the cylinder, piston, and ring(s). If you farm the work out, you can expect a substantial bill for parts and labor. You might compare this cost to a fresh machine. Hope this helps!
Posted on Oct 24, 2010
  • Husqvarna Master
  • 2,239 Answers
I think this machine has seized,
Posted on Jan 08, 2011
SOURCE:
My 1974 Yamaha 250 Enduro wont start I have cleaned and redone the carb. I have changed the coil pack and spark plug. Any suggestions will help Im not a mechanic by any means so not sure where to start...
you need good compression ( at least 90 psi , kicking it with the throttle open) , good crankshaft seals for sucking the fuel/air into the botton end, proper point gap and timing set for spark ( spark should be big and fat,if not the source coil is weak,, this is a flywheel magnito ignition and it needs no battery to fire the plug) if you clean the carb, make sure you also clean the choke pickup tube or it wont choke. also make sure you have the slide installed in the right direction ( not backwards and the idle is not set too high at first...compression/****-good spark at the right time-proper fuel/air ratio and it will run
Jul 04, 2010 | 1974 Yamaha DT 360
Briggs & Stratton 6.75 lawnmower. Won't start.
1) Determined that there is spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No spark lx279
1) How have you determined that there is no spark?
thanks, rwvanlue
Nov 26, 2009 | John Deere Garden
Pouland chain saw won't start, seems to not be getting spark
thanks, rwvanlue
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 26, 2009 | Poulan PP4218AV 18" Chain Saw
I am trying to rebuild my Stihl FS-55 weedeater. I have fire and gas to the plug but it will not start. My gap on the coil is .0010''. Can you help me please?
Basics to check:
b) is there spark
1) Determine that there is spark?
thanks, rwvanlue
1) spark plug
Chain Saws:
Remove Carburetor
Nov 22, 2009 | Garden
My yardnman walk behind lawn mower doesn't start. I prime it three times, hold the throttle open and pull the cord and it doesn't start. Is there a switch or step I'm missing ?
thanks, rwvanlue
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Pull cord won' start engine
Here are some basics to check, you will not need all of them, but one may help.
Basics to check:
b) is there spark
thanks, rwvanlue
1) spark plug
Chain Saws:
Remove Carburetor
Nov 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Machine not start
1) spark plug
Chain Saws:
Remove Carburetor
Nov 20, 2009 | Yard Machines Garden
CRAFTMAN LEAF BLOWER WONT START
1) spark plug
Chain Saws:
Remove Carburetor
Nov 19, 2009 | Craftsman 4 Cycle Blower/Vac
I have a yard machine lawn mower that will not start. i have changed the plug and cleaned out the carburetor. any suggestion will help.
thanks, rwvanlue
Nov 14, 2009 | Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
362 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
lnbn1975
Marvin
Marvin
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
