Question about Ruud UAMB Air Conditioner
Ruud package unit not cooling
I have a ruud central heat and air package unit. The air coming out of the vents is just not cool. It runs all of the time and my light bill are outragous! I had it charged with freon 2 days ago and it hasn't helped. A worker also came out to look at it and realized that a heating element was stuck on. So he was assured that it fixed it. But it didn't. It has been running all day and it is still 79 degrees in here. However it has been very hot (90-96 degrees) outside. But I still don't think that this is normal. And I've had a window unit running today. So now the guy says it may be my compressor getting old and weak and going bad, but I've heard that the compressor is either good or bad, no in between. Can anyone help?
  • kjlester1 Jul 12, 2008
    my ac is on but only seems to bet sending out very minimal ammounts of cool air, the temp keeps going up in the house. it worked fine then, one night it blew a circut, we turned the circut breaker back on and has not been the same since.
You could have several problems. Your system could be overcharged or you have a leak.You could have a bad thermostat. Sounds like you have a bad Tech.
Posted on Jun 08, 2008
What type of run capacitor do I need for a Ruud AC model UPNJ-031JAZ (outside unit)
Looks like it should be a 35/3 370VAC. If it is not legible on the old capacitor read the data plate on the fan motor and compressor. These should say "uf" or "mfd" rating. Good Luck!!
Apr 17, 2017 | Heating & Cooling
Ruud achiever series "10 seer"
You should see no ice. Turn it off for a while like and hour or so.. Do you feel air coming out of the vents?
Jun 26, 2011 | Heating & Cooling
Fan unit does not come on.
Hello
if im reading this correctly,you need to push start your fan motor?
Either the motor start capacitor is bad or the motor windings are bad.
If the motor is not coming up to full speed or is faulty you will not get good cooling.
Sounds as you may need a new motor.
Jun 01, 2010 | Ruud Central System Air Conditioner
Ruud a/c heating system problem
Get service tech to check charge. Clean condensor check filters first.
Jun 12, 2009 | Heating & Cooling
Home Air Condition cooling problem
Hello. If your outdoor coils are dirty it's a good chance the indoor coils are dirty also. Clean the indoor coils and flush out the condensate line.
I know it's tempting to feel the air and try to decide if the unit is working properly but, you need to use a thermometer and while the unit is running check the temperature at the return air vent and then check the temperature at the supply vent closest to the unit. Remember to let the thermometer set for about 5 minutes before reading.
You should be looking for about 15 degrees F cooling between the return and supply.
If your coils are clean make sure the outdoor fan is operating properly. The air coming out of the outdoor fan should feel warm, almost hot. If not you may need to check your pressures. Good luck and let me know what you find.
Feb 03, 2009 | Ruud Central System Air Conditioner
Cool air through vents
I replaced the unit it was very old
Jan 25, 2009 | Ruud UBHC Air Conditioner
Compressor will not start.
Usually short cycling means that High side pressure is getting to high (due to not working condenser fan, or dirty condenser coil), or low side pressure is getting too low (might have low level of freon or restriction in sealed system). low side would drop dramatically if indoor blower is not running, so if air is not circulating thru evaporator coil, coil will freeze up and low side would be much lower then normal. Here is video how I found issue with package AC not coming on. Thermostat call for cool, but condenser would not come on, indoor blower runs ok.
Nov 02, 2008 | Ruud UAMB Air Conditioner
Ruud UAMB Air Conditioner Logo
163 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
