Question about Apple MacBook Mac Notebook
When I turn on my laptop it goes to a blueish screen and a folder with a question mark in it begins flashing
  • 863 Answers
Startup file corrupted. Try inserting gray disc 1 and repair disc permissions under disc utility and also select repair disc after that. Now go into system prefs, accounts, select your user name, select login items and highlight all the programs in the box. Then press delete as these programs are not needed to start up the computer. Your not deleting the programs-just preventing them from starting up when you first press the power button. Still nothing? Then re-install the operating system and that should fix it. Still nothing? Get a new hard drive and install new operating system on that. Still nothing? Well then old chap your fu.kd as you will need to repair the logic board or buy a new logic board.
Posted on Oct 27, 2010
SOURCE:
Grey screen
Please, try this test:
When you turn on the computer, press the F8 key multiple times to get to a menu (recovery, safe mode). If you get there, select Safe Mode. Once on Safe mode, restart the computer to see if it ever gets to normal boot.
Mar 19, 2013 | Acer Computers & Internet
Why does a question mark on a folder blink at startup and not turn on laptop?
Hi Joe. It means that the start-up drive has some corruption of some sort. I've posted previously what to do in such situations so just search for flashing question mark and there's a walkthrough of possible fixes.
Mar 27, 2012 | Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz...
When we turn on our laptop we get a white screen after a little bit a folder with a question mark on it flashes in the middle of the screen. Why and what can we do about it?
it's not reading the hard drive...your computer can't find the boot disc. your hard drive is probably bad. if not, please respond back
Jun 20, 2010 | Computers & Internet
My Powerbook G4 turns on light, fan, chime but no video.
Your hard drive has lost a file needed to start up the machine. The folder with the question mark means it cannot find a useable Operating system. I hope you backed up your files you needed becuase the only real way to recover the machine is to reinstall the OS from the install disk. You must format the Hard Drive from the format option on the install disk and reinstall the OS.
May 08, 2010 | Apple PowerBook G4 Mac Notebook
Laptop not turning on properly
your hdd gets corrupter.Try reinstalling the softsre ahain.
Apr 16, 2010 | Apple PowerBook G4 Mac Notebook
Powerbook g4 Aluminum 15 LCD
it could be the inverter to the display, or the graphics chipset or the connection between them.
Nov 02, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Flashing folder with a question mark in before it loads up to the password question.
It sounds like you have spyware on your machine that is causing the problem.
Go to www.superantispyware.com and download the free spyware remover. Once you have installed, updated and done a complete scan reboot the computer and see if you get the same problem.
May 25, 2009 | Apple Mac OS X Server for Mac
Screen goes white, flashing a folder with a question mark
The flashing folder means that the computer can't find the boot system on the hard drive. If your girlfriend's step-dad has removed some parts of the OS, then the system will not start giving the 'flashing folder' result. You will need to re-install the OS from the system disk.
Insert the disk into the computer and it will boot from that and take you through the install procedure.
May 17, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Toshiba satellite a105-s1014
try the computer with an external monitor, if it works correctly then it's the monitor that has broke and you need it replaced.
otherwise, if it does the same things on the external monitor...
I would check in order:
1)RAM memory
2)Motherboard
if the problem is only after windows boot, try changing the video driver, the problem might be caused by overheating video Chip, but that should freeze the system too...try also to remove the dust from all the heatsinks with canned air...
Jan 18, 2009 | Toshiba Satellite A105 Notebook
Question mark when turn on laptop
Unfortunately, the clicking sound means that the hard drive is bad. That is why it will not boot. If it is under warranty, call Apple support. 800.275.2273 in the US.
800.263.3394 in Canada
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 19, 2008 | Apple MacBook Laptop Computer Mac...
Apple MacBook Mac Notebook Logo
82 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
