Question about Lincoln Electric Welding Tools
I need to know if i can use that 117-021 mig welder with a flux cored wire and no gas? thanks
    New Friend:
It depends on the model. Some units needing the gas for cooling the nozzle.
Posted on Oct 24, 2010
SOURCE:
Wire wont feed on my welder
I would call miller and get a number for the closest repair station. They have a three year parts and labor warranty. 1-920-735-4505
Jan 10, 2015 | Miller Multimatic 200 MIG TIG & Stick...
Will a ya219b snap on by century mig welder weld flux core wire
Are you using knurled rollers? Check the wire. Is it reversed polarity. Flux cored wire is very voltage sensitive.
Jun 14, 2012 | Century Welding Tools
Mig gas conversion for JobSmart 125 Flux Wire Welder
The other difference between gas/gasless is the ability to reverse the gun polarity which you can't do with a gasless only welder. You can get it to work but not safely and reliability could be an issue also.
Mar 06, 2012 | Welding Tools
SMALL PUDDLES NO PENATRATION WELDER IS FARM HAND 115 VOLT MIG//FLUX CORE WIRE FEED PUT ON ANY SETTING NO DIF CANT FIND MODLE IT HAS CHPOWER.COM WEB ADDRESS
Hi:
If you are using flux core wire you need to switch the polarity of the machine. With flux core wire, your ground clamp becomes positive (lead) and your gun the ground. All you need to do is switch the cables above the feed rolls.
That will take care of the problem
If this was useful to you, please vote. Thanks.
Mar 20, 2011 | Campbell Hausfeld Welding Tools
Can the lincoln 305 d 1727-3 mig weld
If it has a setting for constant volatge, that is for wire feeders, flux cored or mig. Constant current is for stick welding. Some wire feeders have a switch to use them with a constant current machine, but that doesnt work very well, and , in my opinion, is hard on the computer in the feeder.
It looks like the ones we use in the field with a ln-25 wire feeder and flux cored wire. for mig you will also need a bottle of sheilding gas.
Jan 28, 2011 | Lincoln Electric Ranger 305D K1727-2...
Have solar 110 2172 mig welder does this mig use gas can i use flux core wire also is owners manual available
Yiu can use both innershiel and solid core wire. All you need to do is inverse the polarity for the innershield wire (gasless wire) connect the gun to the ground and ground cable to positive side.
Dec 26, 2010 | Solar Mig Welder Welding Gun Liner Parts...
I have a mig 101 wire welder serial number B-37491-1986. Can I use flux core wire instead of the gas. The welder states .24 or .030 size wire. Are tips available for this welder ?
I have a mig welder that said it could use flux core wire.
Usually, .030 is what I use.
I am not sure if yours is this way, though.
I gave up on using the gas, because my canister was too small to make it practical.
I bought mine from Pace Member Warehouse which turned into a Sam's Club years later.
Good luck.
Jun 21, 2010 | Welding Tools
What is required to switch from steel to gas on light duty mig welders
if you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Sep 06, 2009 | Lincoln Electric LE 83180 Century...
Convert flux to mig
need to buy a gauge set up , these usually come with the hose and gauge,just attach in the back and hook up your bottle..
Mar 16, 2009 | Welding Tools
Welding Tools Logo
62 people viewed this question
Top Lincoln Electric Welding Tools Experts
David Soto
David Soto
ka4iup
ka4iup
gbob59
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
