Question about HP Deskjet Printer
I cant get my printer to print anything. It's been ok until now
    New Friend:
  • 13 Answers
Go to control panel, then click on printers. Right cilck on your printer and then make sure your printer is online. Cancel any failed documents from the printing queue?
Does this fix it?
Posted on Oct 24, 2010
SOURCE:
Cant clear Error Code E161-403E on canon iPF605
to enter SERVICE MODE the machine has to be switched OFF. While the machine is off, hold down the sheet or roll feed button and the information button. Keep these pressed and switch the machine on, keeping the buttons pressed until you see an S in the top right-hand corner of the display, then let go of the buttons. You should now be in SERVICE MODE.
later go to maintenance menu choice replace print head.
then follow their picture image to replace the print head.
first try to print nozzle check in services mode.
Scroll right to the service mode box (rightmost box) and press OK. You should then see the word 'DISPLAY'. Scroll right until you see the choice 'ADJUST' appear. Then scroll down until you see the choice 'NOZZLE 1' appear and press OK. If you haven't already loaded paper, the printer will prompt you to do so and then it will print out the NOZZLE CHECK PATTERN.
check go any nozzle no firing out ink..
Dec 06, 2011 | Canon imagePROGRAF IPF605 InkJet Plotter...
My printer prints fine, but how can I make it print darker. It seems to have gotten much lighter and the ink is relatively new.
There should be a button on the top that says lighter/darker, move it 2 clicks to the right for more ink to be used..... please let me know if there is anything else you need, happy to help! Guy :)
Sep 23, 2010 | HP LaserJet 3050 All-In-One Printer
Brother printer dcp-135c cant add to computer
Right click on your My Computer icon. Go to Manage. From there, expand the Services and Applications section. Select Services. On the right hand side, scroll down until you see the "Print Spooler" entry. Doubleclick it. If the "Startup Type" is anything but "Automatic" change it to that. Then click the "Start" button, then "Apply" then "OK". You should be working now.
Aug 10, 2009 | Brother MultiFunction Center MFC-440CN...
I replaced the printer head but it won't calibrate
Press menu.
Press �� until Calibrate Printer is selected.
Press OK. A new screen appears with Print Calibration Page selected.
Press Start and follow the instructions on the LCD screen to complete the calibration.
If you want to clean them...
Press Menu to display the Main Menu.
Press �� until Clean Printhead is selected.
Press OK to go to the Clean Printhead menu.
Press OK to perform a Basic Clean.
Regards.
Apr 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cant delete printer
Hi ksmrdel:
Reboot computer and power down printer then power up printer and you should be ok. try to print a document.
Jan 10, 2009 | Lexmark Office Equipment & Supplies
C5180 printer won't print.
I just had this problem and here's what I did (with a little help from a previous yahoo answers post)...
1. Turn printer and computer off
2. Disconnect printer from computer
3. Unplug printer completely
4. Hold power button on printer while plugging printer back into power source. Maintain holding power button in until printer cycles completely (Ihave no idea if hold it actually does anything...but I tried it and it worked)
5. Turn printer back off (which actually may happen anyway when you finally release the power button)
6. Reconnect printer back to power source and computer.
7. Power both back up.
That should do it hopefully. Also make sure your printer cartridges aren't totally out. It won't let you print if even one of them is completely empty.
Good luck.
Aug 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Printer says printing document but will not print. anything
I had this same problem, and after 45 minutes with HP support, eventually managed to get it to print by turning the printer of and then holding down both arrow keys (left and right) at the same time while turning the printer back on. I held down the arrow keys until it said "Language: English" and then clicked through the prompts. It then restarted, and all was well again.
Other places mention doing this with the OK and Cancel keys, but that didn't do it for me - the arrow keys did.
Jun 24, 2008 | HP LaserJet 2605dn Printer
Printer won't print magenta
So what does the machine do: Not recognizing the cart (error: insert magenta) or does it not print onto the paper?
In 1# case: Reinsert the magenta cart and make sure that the support is secured above the cart top. If it is recognized: OK.
If not unplug mfc from power. take all carts out. Wait five minutes. Reconnect machine to power. wait until machine demands carts. reinsert cart as demanded and give the right answers (see display).
Machine should run a short cleaning cycle.
In 2# case: Insert full carts well. press menu then start mono (blue) then fourtimes arrow-up (te-index). machine will be in maintenance mode. press 7 then 6 then 4. machine will initialize the carts. after some cleaning cycles machine will be
in mentaenance mode again. Press 9 then 9 to leave mode. press ink etc. to run a test print. If it fails and you cant see any magenta, the valve or filter is clogged and cant be fixed anymore.
Nov 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP Deskjet Printer Logo
56 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
