Question about Dualit CTS4E 4-Slice Toaster
My toaster stopped working model 4SLGB, serial no 2008.30 product code 40344. it is only a couple of years old, i have tried changing the fuse in the plug. but this doesn't appear to be the problem. No lights come on when setting the timer and no heat comes from the elements. any ideas?
3 Suggested Answers
SOURCE:
SOURCE: Dualit combi heating element 12/95
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
Posted on Nov 30, 2008
espressonist
  • 1711 Answers
SOURCE: How do you replace a centre element of a Dualit 3 slice toaster?
You can buy the elements from ebay uk and for 110 v also, they are so slim and light that they ship them in normal envelope and arrived in no time.
You can follow the instruction in the link what to order and how to replace.
We have the procedure here in this link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Good luck
Posted on Aug 20, 2010
Kitchen aid 2-slice toaster stopped working. It is plugged in to a good outlet.
The wiring is probably the problem. Check the connections. And then the elements . It may be burned in two.
Jan 27, 2013 | KitchenAid KPTT780ER 2-Slice Toaster
Received a B&D Convection,Toaster,Rotissere oven but did not get a operator's manual and am not familiar with the convection operation. Can I get a manual? I believe this oven is about 2 years old but...
Try the following site: http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4 . Then scroll down or use the Find feature of your browser (under Edit). You want the manual for the TRO200 and TRO300 series toaster ovens for the TRO355. If you have a different model which seems likely (since the TRO300 series aren't convection models), scroll through the list for one that matches the TRO and either the whole model number or the first digit or two. (Usually the model number is on the back of the toaster oven on a plaque with the serial number.)
I hope this helps.
Dec 17, 2010 | Black & Decker TRO355 Toast-R-Oven 1550...
I need to purchase a replacement for my toaster over #6233 - I need a new Baking Pan & Broiling Tray. Mine is very soiled and will not clean
FYI Oster Toaster Oven: about 18 months ago after careful consideration we purchased a counter top toaster oven for the RV from WalMart. I have a 20+ year old Oster Kitchen Center and found easy access to repair parts a couple of years ago, very pleased.
Last trip out in the RV the timer knob stripped out after what I would describe as a couple of months of light use. Google'd the model in search of a replacement knob only to find many others had "been there, done that". The model is obsolete and no service parts are available.
The Oster customer service rep seemed finished at this point and asked if there was anything else she could do for me. I asked what I, a long time Oster customer, should do with the useless oven. After repeating the question rephrased several different ways she put me on hold.
She returned several minutes later to inform me that as a "one time" courtesy Oster would replace our out of warranty oven with a current model. The replacement unit would have no warranty or support from Oster.
She supplied the model number and gave us an Order #. Looking up the model number and checking reviews I have very low expectations for the replacement. Most comment as to the poor quality and reliability of this current model.
A perfect example of a manufacturer who once produced a quality produce but now sells cheap imported disposable products.
YMMV
Nov 07, 2010 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Right side stopped working (KPTT809)
I had the same problem with my Kitchenaid toaster which is 4 years old. I called Kitchenaid and they said that this model now has a 5 year warranty and they have replaced the toaster for a new one. What a fantastic company. Try giving them a call.
Jul 06, 2009 | KitchenAid KPTT890 Pro Line 4-Slice...
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Back to Basics egg toaster
My egg cooker stopped working, so I took the unit apart. To answer your question, I did not see a fuse inside. One way to tell if it is a power problem to the mother board is to observe whether the LEDs light up or not after pressing the switches. If the LEDs don't light, there could be something wrong with either a power component or a power connection.
In my case, the toaster worked fine. Usually these problems are caused by loose connections. Sometimes it is not obvious where the loose connection is. All I did was loosen and re-connect the wires to the egg cooker and also to the board they came from. I also shined up the toast slide button copper connections with a nail file. This was just a precaution, since the toast slide button had to be working (i.e. it still toasted, just didn't cook an egg).
So far, it seems to be working, but time will tell. If the problem was due to something other than a loose connection, it will happen again.
Apr 14, 2008 | Kitchen Appliances - Others
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Dualit CTS4E 4-Slice Toaster Logo
164 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Ross Keen
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
