Question about Philips 42PF9630A 42 in. Plasma Television
Hi, my philips plasma tv 42pf9946/98 can't turn on power! LED power indictor light off, just happen today! I had opened the cover and check the power supply unit ok! But when I push the right hand side push button switch, I did not hear the power on relay switch click sound at all! Suspect due to switch transistor is dead, I do not circuit diagram and I need your help to tell me what is happen to my plasma tv? Hope you can give me a repair guide for this problem! Many thanks! KC Lee
  • Khiang Choon Lee Oct 27, 2010
    Can I send some photo to you and you let me know what to check?
  • Philips Master
  • 17,130 Answers
It is important that you have a clear idea off the SMPS unit which is the power supply unit of the set. The secondary voltages must be checked one by one to confirm the voltages to each of the sections.
primarily the voltage to the microprocessor must be in order so that the +5 volt to the mP is available.
The regulator of the +5 voltage must be checked to be in order.
If the processor is functioning the relay must click to allow the primary voltages to work. The oscillations of the mP must be checked to ensure that the processor works.
I have some tips for checking the SMPS, so try this link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Please check the circuit carefully specially in the HT side.
Posted on Oct 25, 2010
SOURCE:
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
I have had my TV-- a 42" Philips plasma-- for
it can be a poor contact or puffed capacitor in the power supply board
Dec 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television TV wont turn on..I get the initial green power light, but it quickly goes to a flashing red light (flashes a series of 4 times). Philips tech support is a joke....
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Jan 08, 2010 | Philips 42PF9631D 42 in. Plasma Television
2003 philips 50" plasma tv with picture fading. How do I fix this?
Hi,my philips plasma 50FD9934 dont turn on just led flasing red and green contniusly.Please help!!!!This is a power suply problem?thanks
Nov 14, 2009 | Philips 50FD9934 50 in. Plasma Television
No picture in Philips 42pf7220a/37 Plasma TV.
Hi my name is Roety,
I can help you with your issue ,
You can look for two bad capacitors on the power supply. They will look swollen on top like this photo
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Nov 14, 2009 | Philips 42PF7220A 42 in. Plasma Television
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
Jan 03, 2008 | Philips 42PF9956 42 in. HD-Ready Plasma...
Philips 42PF9630A 42 in. Plasma Television Logo
154 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
