Question about Magellan RoadMate 2000 GPS Receiver
Magellan 2000 doesn't power up
One year old and stopped working. No damages or abuses.
Looks like he battery is not charged or the power supply is damaged. Please help me to diagnose and fix the problem?
Regards,
Sathya
sgsetty@yahoo.com
603-888-4269
  • 1 more comment
  • raycbowen Sep 01, 2008
    magellan does not power up.
  • Anonymous Sep 03, 2008
    Same Problem here. One and half years old. It suddenly stopped. Seems like a problem with the battery.
    Thanks
    G
  • Joe Ward Oct 23, 2008
    Sounds the same as the others - my magellan is approximately 1.5 years old and it suddently quit working. Yesterday it worked fine. Today it doesn't turn on (whether I'm plugged into the car charger or not).
    It isn't like a cell phone where the battery goes out gradually or the battery doesn't hold a charge but you can continue to plug it into a power supply and use. It makes me wonder if the issue isnt the battery (note: it wasn't dropped, kicked or even moved between yesterday and today - it just quit working)?
Is this battery available in stores?
Posted on Aug 03, 2008
Try replacing the battery. ususally if the battery is dead it will freeze or not turn on. if this doesn't work magellan will replace it with a new one at a very reasonable price. I just replaced a magellan 800 with a magellan 3210 for $132.00. your may get a better deal. call magellan
if you have an a/c 110 volt to 5 volt converter for the magellan, try charging it in the house with that one rather than the car charger.
Posted on Jul 31, 2008
My magellan Roadmate 5220-LM powers on but will not go past the first screen. I have tried to use the reset button but it still will not work
Hello Liz, You may have two problems. If your unit is several years old, the battery may need to be replaced. First charge the battery overnight. To get the screen unfrozen , you need to remove the screws on the back, open the case, and unplug the white battery connection . Reconnect the battery connection after a few seconds. If this works, it is usually a temporary fix . Either your battery does not hold a charge or your charger connection is poor at best and can not deliver a full charge to the battery. It could be both.
Mar 17, 2014 | Magellan RoadMate 5220-LM GPS Vehicle...
Magellan 4250 fails to turn on. Have tried both car and home power supplies with same result. Its as if unit battery is bad.
hi depending on how old your system is its probably just your battery that needs replacement ,though it should work while connected to power source check the power inlit make sure it is not damaged or broken goodluck
Mar 18, 2011 | Magellan Maestro 4250 GPS
Magellan 3000T, approxiamtely 2 years old. Last week, left home and it died on the road, it wont turn on even when powered by external power. The charge light shows it is charging. but it never...
hi djmercer1
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Nov 24, 2010 | Magellan RoadMate 3000T GPS Receiver
My Magellan Maestro 3210 constantly says low battery while on trip and shutoff, I have it plugged into the astray why would the battery be low, how do I get it off battery power setting, or why is it doing...
Usually when you see low battery like that it means the battery itself needs to be replaced at it can't hold a charge or enough of a charge to be usefull. If you unit is over 18-24 months old then th e battery is most likely the problem. This will happen even if you have always used external power as the battery doesn;t get properlly cycled enough.
It is possible that it is the power source you are using is too low but sounds more like the battery is the problem.
If you have warrenty the battery should be replaced by Magellan. If not a replacement battery is about $30 and is something you may be able to do. You need to remove the back cover and unplug the old battery and plug in the new one and put it all back together.
Here is one link for a battery but there are other just search for Maestro 3210 battery with google or bing and you should find a few places that offer them.
http://www.batterymart.com/c-magellan-maestro-3220-gps.html
Mar 30, 2010 | Magellan Maestro 3210 GPS Receiver
It will not stay charged while driving.
Bad power supply or a bad battery. most likely the battery since the age on this one is about 3 years old, that should be about time to replace the battery.
Mar 12, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
The whole center turner doesn`t work anymore ,i think i need to buy a whole new middle button
If the dial doesn't spin, then unfortunately your Fuze is physically damaged, and will need to be repaired.
If the dial stopped working on its on, versus not working due to physical damage inflicted by being dropped, abuse etc., and your player is less than one year old, it is covered under SanDisk's warranty service. Email support@sandisk.com to ask about this. They will probably want you to provide proof of purchase (showing date and place of purchase and name of the reseller).
Feb 11, 2010 | SanDisk Sansa Fuze MP3 Player
Batterie dead
A 3 year old battery is on the cusp of being at the end of its life. You must first test battery strength ( voltage ) and then the alternator output for proper voltage.
Apr 04, 2009 | 2000 Chevrolet Venture
Magellan 2200T will not accept charge
Well, I am not sure if your problem is the same as mine. My unit stopped working as well after about 1.5 years.
I opened it up, thinking the battery might be a goner. But after opening it up and checking the battery with a voltmeter, it looked good.
On re-connecting the battery, everything worked fine...loose contact maybe? Its been working fine so far.
Jan 28, 2009 | Magellan RoadMate 2200T GPS Receiver
Magellan roadmate 2000 no power
Bill
Nov 16, 2008 | Magellan RoadMate 2000 GPS Receiver
Magellan RoadMate 2000 GPS Receiver Logo
236 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
