Question about LG Dryers
I have a 5 yrs old LG dyer that will not start. When I push the start button it is just making an electrical buzzing sound and if I hold the button long enough is starts to smell like something electrical is burning.
  • LG Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 28, 2010
6ya staff
SOURCE:
Just makes a buzzing sound when you turn the start button on.
that is the motor!try this,open the door,with one hand push in the door switch button and hold it in,as you hold in the button spin the drum with your other hand and have someone else push the start button and see if it starts,if it does you have a bad motor,if the drum doesn't spin by hand you could have something stuck in the blower wheel,let me know what you find
Feb 05, 2011 | Frigidaire FEQ1442ES Electric Dryer
Maytag Dryer won't start withouth me turning the drum.
Good day. Ugly problem.
My first choice would have been the motor, but.......
Here is the process, it might help you.
The power to the motor goes first to and thru the door switch. It then returns to the timer.
When the timer is turned to any running position, power leaves the timer where it is split into 2 leads.
One of the power leads goes directly to the centrifugal switch Which is the switch on the motor with all the wires. If you spin the drum, you also spin the motor, and if spun fast enough will close the contacts on the cetrifugal switch, thus sending power to the motor, allowing it to run. I guess you have done that.
The second lead out of the timer goes to the push to start switch, it then leaves and goes to the centrifugal switch but on the power side, so it is directly connected to the main winding in the motor.
That is why when you press the press to start switch, the motor runs, and if held in it will continue to run.
In fact, at this point, the motor had 2 sources of power, either of which can run the motor.
Thus releasing the push to start switch doesn't matter, since it runs off the other source.
Possibilities.
The centrifugal switch is not wired right. Please recheck. (or the motor was bad out of the box. Happens).
The push to start switch is bad, and needs replaced.
Or, the wiring going to or leaving the push to start switch has broken or making a bad connection.
Lastley, I said the power comes out of the timer and splits into 2 circuits. Not always true, in some models the timer sends 2 seperate wires out carrying the power, with the possibility the timer could be bad.
Hope this helps.
and thank for using FixYa
Jan 07, 2010 | Maytag MDE6000 Dryer
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Elite 73952 will not start
sounds like it is the motor, open the door and press the door switch in ,have another person push the start button,and you tunr one of the drun fins. IF itstarts, you need a motor
Mar 11, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer has power, just buzzes, does not start to spin
sounds like you need a new motor .or PAY professional help .
Jan 28, 2018 | GE DPSB613GDWW Gas Dryer
Dyer was grinding, then won't run
Sounds to me like you motor has froze up. Is there any smell coming from the dryer? The fuse would not cause this. A fuse would make the dryer do nothing when you hit the start button.
Nov 21, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
125 people viewed this question
Top LG Dryers Experts
jimorris77
John Tripp
John Tripp
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
