Question about Dell Inspiron 6000 Notebook
No drive detected
No cd drive seen in my computer
i have win XP
  • 1 more comment
  • Rahil Kamra
    Rahil Kamra Jun 07, 2008
    Click the Start button, click Run, and then type regedit in the Open box.
    Click OK.
    The Registry Editor window appears.
    Click the plus (+) sign next to each of the following keys:
    HKEY_LOCAL_MACHINE
    SYSTEM
    CurrentControlSet
    Control
    Class
    NOTE: When you click on the plus sign more folders will expand out below it follow the expanded set each time to find the next folder listed.
    Click {4D36E965-E325-11CE-BFC1-08002BE10318}.
    On the right hand side of the window, click UpperFilters.
    Click Edit on the menu bar.
    Click Delete.
    Click OK.
    On the right hand side of the window, click LowerFilters.
    Click Delete.
    Click OK.
    Click Registry.
    Click Exit.
    Restart the computer normally
  • Rahil Kamra
    Rahil Kamra Jun 09, 2008
    sorry i accedently rated myself again
  • gregingalls Sep 17, 2008
    I am havingn the same problem. I was able to boot off the drive to install XP Pro (Worked fine with XP Home). I checked for the Upper and lower Filters in the registry and there were no entries to delete (Confirmed I was in the right location). There are other registry keys with the Drive's model # listed so I know Windows knows it's there. I need help getting this drive visible!!
    Thanks!!
  • 3 Answers
Click OK.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Click Delete.
Click OK.
Click Delete.
Click OK.
Click Registry.
Click Exit.
Posted on Jun 07, 2008
Mother board masi km4am-l H.D.D. 1 TRA WES 64MB when installing win xp hard not detected by win setup. I updated bios but not worked. advance thanks
you should not update the bios...the issue is the hard disk is on sata ...and you need a raid driver installed to detect the hdd...so ...either get into BIOS and under advanced features..look the place where the drives are detected..and select the hdd and look for a feature called AHCI ..and disable it ..and leave sata like ide..and save with f10 and restart ...after that the hdd will be seen ..
another way is to make a floppy disk with the raid driver on it (the one from the mothermoard drivers disk ) ..and when it ask you to press f6 for 3rd party software ...press it ..and insert the floppy ...it will pick up the raid driver and will go like a charm ..
if you do not have a floppy ..install a second cd drive ..and use a cd ..and after pressing f6 for 3rd party ..browse and point to the raid driver on the mobo driver cd ..
Jul 15, 2011 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Insataling windows xp problms
If u just want XP . Source a dos boot ( u can get files from internet), format the HDD .create main partision for windows xp and try installing
May 22, 2009 | Computers & Internet
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
Samsung cd/dvd combo drive problem
Check you'r jumpers ei master slave. and all cables are hooked up right, power hook up are fully in. you may have to up date win xp. sp 2-3 so on. enter cotroll panel. system. hardware tab. device manager. look under dvd/cd-rom drivers if they are listed there 1st try to update the drivers. if that don't work then uninstall all of the dvd/cd roms listed there. then restart you'r computer. on the re start win xp install wis. shold find the roms and install them and update them. if that don't work you'll have to call the microsoft free help line. this is what they had me do when I had the same problem. you may in the end have to wipe and re install window, sorry to say. hope this helps you
Mar 19, 2009 | Samsung SM 352 CD-RW/DVD-ROM Burner
Error loading operating system
you'll need to run windows setup again.
Insert the cd restart and when asked to start with cd click enter.
Jan 14, 2009 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
Mitsumi cd-rom fx4821t wont work
have you installed any software for compiling the data and writing it on the disc....
try to use nero and tell if it shows any error
Aug 31, 2008 | Mitsumi (CRMC-FX4821T) (crmcfx4821t)...
Transcend 4gb pendrive not being detected in Win XP
my 4gb pendrive is not detecting in my win xp operating system,before 2,3days i repaired my operating system,after that it is not detecting..pls help me
Jul 23, 2008 | Transcend (589307) Media
Transcend 4gb pen drive not getting detected
pen drives generally have 3 to 5 years warranty, if your pen drives are not detectng on other systems also, its better to replace it
SAMSUNG CD-ROM SH 152>> Detection Error
Dear Sheila
After connecting it to the motherboard, switch on the pc, then go to properties of "my computer" then choose "Hardware" then choose device manager and over here u will come to know weather ur CD rom has been detected or not, if it has a question mark then it means u have to install drivers for it, but if ur using Win XP, i am sure it shd detect automatically and need not ask for drivers. Hoping a good rating from u....!!!
Thankyou
Feb 15, 2008 | Samsung (SC-152) Internal 52x CD-ROM Drive
Dell Inspiron 6000 Notebook Logo
785 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
