Question about Garden
13hp. techumch. wont stay on high throttleposition. rpm,s drop.
Come to stop truck wont idle it shutts off
That's a very high rpm for an idle! It should be between 700 to 9oo rpm. This truck needs a tune up, at least!
Jan 21, 2013 | 1997 Dodge Ram 1500 Club Cab
2003 chevy malibu 3.1 shuts off and wont stay on
Check the idle air control valve for carbon buildup. Also check for a vacuum leak.
http://ricksfreeautorepairadvice.com/bad-idle-air-control-valve/
High idle rough idle Ricks Free Auto Repair Advice
Jan 12, 2018 | 2003 Chevrolet Malibu
I was wondering what rpm should my tacometer be at when going 70 mph? it seems high and im not sure if transmission is dropping into the final gear. the overdrive doesnt work either, is it stuck in...
Cruising speed rpm should be roughly 2200 rpm If OD (lockup) is not engaging it will be running at about 3,000rpm.
If it was staying engaged, you would not have a problem at cruising speed but would be "lugging" when taking off from a standstill. OD should come on at about 45mph and the tach should show a drop in rpm.
Apr 20, 2010 | 1999 Jeep Grand Cherokee
1997 f150 truck starts but doesnt stay running, only if you
sounds like either fuel pump weak or fuel filter plugged
Dec 06, 2009 | 1997 Ford F150 Regular Cab
Compressor drops to 80 lbs when sandblasting, should hold 110lbs.
The air pressure on your system is actually controlled by the orifice size at the tip. The tip wears very fast and the air pressure will drop accordingly. Install a new tip and retest pressure. The only way to increase pressure as the tip wears is to increase the rpm of the motor/engine. Also check for leaks in the system. If possible, start out with a smaller tip and lower engine rpm a bit then increase rpm as the tip wears. You can also play with the grit size as the tip wears. Slightly larger grit/sand will work better as the tip size increases and pressure drops. Good luck with you sandblasting project.
Mar 31, 2009 | Air Tools & Compressors
Cold start high RPM
the rpm will drop after is starts worming up a bit and it will build pressure be for it drops.
Mar 29, 2009 | 2008 Dodge Durango
Slow acceleration, high rpm
This sounds normal to me! The engine will read that rpm when accerlerating lightly. It is the stall of the torque convertor. The oil pressure will always be higher when the rpm's are higher, or when the oil is thicker - cold.
Virbration? That is a different story. Oil won't cause that.
Mar 25, 2009 | 1992 Buick LeSabre
07 chevy silverado 5.3 auto trans.
I have a 2000 GMC that does that also, only mine wont slow down unless i turn it off and retsart, only does it when engine is really warm.
Mar 14, 2009 | 2003 Chevrolet Silverado 1500
Garden Logo
29 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
