Question about Epson Office Equipment & Supplies
All three lights are flashing on my Epson Stylus NX125 printer, and the printer won't print... Help!
SOURCE:
SOURCE: problem with my printer Epson Photo Stylus RX425
This file http://www.eserviceinfo.com/downloadsm/22895/SEIKO%20EPSON_EPSON%20RX420-425-430.html solves the problem,but it dont change your ink pads !
Posted on Nov 23, 2007
SOURCE: Failure to print
inyestores tapados extraerlos y sumergirlos en alcohol isoprilico varias veces ojala dearlos de un dia para otro yo entiendo el ingles pero tengo problemas para escribir no se como me enviaran lq forma de la lectura la pueda ver en español saludos desde chile
Posted on Mar 08, 2008
  • 13 Answers
SOURCE: Parts inside your printer require maintenance or
A service error where you get a message telling you that "Parts inside your printer at the end of their service life, contact your dealer for replacement", or "Parts inside your printer require maintenance or replacement, call your service company", is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is to replace the waste ink pad/pads with a new one/ones and then reset the Internal Waste Ink Pad Counter. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer. You can see exploded parts diagrams for most epson ink jet printers and can also check on possible parts ordering, by Compass Micro Inc, at http://www.compassmicro.com/parts_select.cfm . Some people actually wash the ink out of the old pads, by holding them under running cold water. Then they simply dry them out and reinstall them back into their printer. The choice on what to actually do, is yours to make. I would at least recommend getting that waste ink counter reset procedure and performing it first, to make sure your printer will then work. There is an "Epson Stylus C60 Printer Information Page", that also includes the C40 & C42 series, that you can view at http://epsonhelp.freehttp.com/C60.html . It does have a section on the left side you can click-on, titled WASTE INK PAD SERVICING and also a section titled HOUSING REMOVAL, that will be of some help to you, if you want to try the needed servicing. However, you will still need to actually reset that Internal Waste Ink Counter, to clear the actual service error condition. You may be able to reset that waste ink counter, using the SSC SERVICE UTILITY available at http://inkjetprinterhelp.us/sscserve.exe . Unfortunatly, that utility only works using a windows operating system. You can check and see if your particular epson printer is compatible, by going to http://inkjetprinterhelp.us/epsonSSC.html ...Here's some previously posted info that may also help. To reset the error download this utility: http://inkjetprinterhelp.us/epsonSSC.html . Once installed run the program and configure it, closing the main window and right clicking the icon in the tray area, from there choose Configure and select your printers model. After configuration, select Protection counter -> Reset protection counter, it should be able to clear the error message. If that does not actually work, then the only suggestion I can give is to perform a soft-reset before resetting counter. Remove also the Epson status agent, it detects errors and it may hinder communication with the printer, then reboot your pc. As profile choose the one sscservice didn't use after autoconfiguration, check for printer response. Remember that you should also clean the waste ink pads located at the printer bottom. For a more in-depth procedure go to his site at http://myprinter.altervista.org/simplefaq/mysimplefaq.html#counter "....Unfortunately, that ssc service utility may not actually work on all epson printers and not on all operating systems, so you will have to check it out for yourself. Just in case that source does not work: You may then need to go on-line to try and locate the actual reset procedure, to buy and download to actually reset that waste ink counter
Posted on Mar 12, 2009
SOURCE: All lights flashing on the Epson Stylus photo 870
Unfortunately, the Russian software does not work on a Mac, and it crashes at launch when installed in WZ98 under Virtual PC. However, I found this on another site, and it worked immediately:
The sequence to reset the waste ink counter is as follows:
WASTE INK ROM RESET ONLY 870, 1270
1. Turn the printer off using the power button on the panel of the printer.
2. Disconnect the interface cable at the back of the printer.
3. Hold down the "LOAD/EJECT" and "CLEANING" buttons simultaneously.
4. Turn the printer on. Release all buttons as soon as paper out light flashes.
5. Quickly press (within 3 seconds while PAPER OUT light is flashing) the "CLEANING" button for 10 seconds.
6. Release the button and the printer will initialize.
7. Once initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on
Works great, no muss...no fuss!
Posted on Apr 29, 2009
pineworks
  • 4345 Answers
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
New cartridge wont work and power and ink lights flashing.
You probably need to remove the protective film from the contacts on the cartridge. murf427
Oct 25, 2012 | Epson Stylus All-in-one Inkjet Printer...
Dose the printer epson stylus NX125\127 comes with a USB wire?
Yes
http://www.epson.com.au/products/multifunctional/stylusnx125_specs.asp
but you can buy one yourself for less than $5.
Jul 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My windows xp can't find my epson stylus nx125 printer driver
You can get them from EPSON website and install them:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=150186&prodoid=63088088&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=20&y=10
Just choose what youi want, a complete (40MB), or Driver only (8MB)
Drivers and Utilities Combo Package
Windows 7 32-bit Edition, Windows Vista 32-bit Edition, Windows XP
epson13804.exe - 40.9MB - posted on 09/15/10
This file contains everything you need to use your Epson Stylus NX125 and NX127 with Windows XP, Vista 32-bit and 7 32-bit.
This combo package consists of the following items:
  • Printer Driver v6.72
  • Scanner Driver v3.770
  • Epson Status Monitor 3
  • Event Manager 2.40
Driver only:
epson13802.exe - 7.9MB - posted on 09/15/10
This file contains the Epson Stylus NX125 and NX127 Printer Driver v6.72. The Epson Status Monitor 3 is incorporated into this driver.
Please leave rating if it helps.
Jan 20, 2011 | Office Equipment & Supplies
My epson stylus nx125 acts like it is printing but the page comes out blank. I have already checked the ink level and paper
HI Good day!! Try to Head Cleaning the printer, go to your printer properties and then "Maintenance you should see the head cleaning.. and then try to print some test page see if there's a changes in quality of the print.
Oct 21, 2010 | Epson Stylus NX105 All-In-One Printer
Printing Problems with Photos
you can try this one just to isolate if it is an issue with the software or with the hardware itself
it is just for windows users only
1) Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 07, 2008 | Epson Stylus Photo R220 InkJet Printer
Problem printing
3) Click on START.
Dec 29, 2007 | Epson STYLUS CX3900 All-In-One InkJet...
Color printing problem for Epson CX4200
try this :
Please confirm that the head cleanings were done using the most effective method listed below.
3) Click on START.
Dec 29, 2007 | Epson Stylus CX4200 All-In-One InkJet...
Dark red prints with lines throught the picture
1. Make sure the printer is turned on but not printing.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Printer doesn´t print using the mangenta ink cartridge
try this :
3. Click on START.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
Dec 20, 2007 | Epson Stylus C63 InkJet Printer
Printing in blue only
Try cleaning printhead like shown in this video. Usually works quick.
Dec 12, 2007 | Epson Stylus CX6000 All-In-One InkJet...
1,417 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
