Tobisha Laptop, black screen with arrow upon start-up
    Scholar:
  • 73 Answers
Hi Morticia,
I think that the explorer.exe is not loading on. this can be caused due to various reasons.
Follow the below steps to straighten this issue :
* On the black screen with arrow, press ctrl-alt-del keys.
* This should bring up the WINDOWS TASK MANAGER.
*Click on NEW TASK which is on the bottom right corner on the TASK MANAGER.
*This should bring up CREATE NEW TASK window, Type in "explorer.exe" and press ok....
This should bring back your desktop screen.
Please vote for me if you think this solution helped you fix your issue.
Enjoy and cheers !!!!
Posted on Oct 24, 2010
SOURCE:
Why is Dell latitude E5400 backlight ok in BIOS but screen black upon start up
It sounds like if your screen stays lit fairly well during BIOS that is would be an issue with the Operating systems settings themselves. If you are using windows i would look for any options that may have something to do with display lightness darkness contrast anything really. Also see if you can hold the Fn key on your key board and locate a sun or light bulb with an up arrow beside it. While holding the Fn key press the light bulb or sun several times and see if that helps.
Apr 24, 2014 | Dell Latitude E5400 Laptop
I have my laptop stuck in safe mode. i checked safe boot by mistake, now why cant i get back to undo it?
Hi Steven-
Laptops should return to normal mode upon subsequent start-up. If it does not, when you (re)start your computer, begin tapping the F8 key repeatedly (like a woodpecker). After a few moments, this will bring up a manual start screen (white letters on a black background)-you will see an option to Start Using Windows Normally down toward the bottom of the screen. Using your arrow keys, scroll down to that choice and hit ENTER. Your PC will then boot up in regular mode.
Apr 01, 2014 | Gateway Computers & Internet
Hp pavillion g6 laptop repair screen comes up and then goes black
boot your computer under safe mode by pressing F8 upon restart, repair option page will come out, locate by using arrows and enter to select. look for "last known good configuration" and select.
let it start to windows. and see if your problem solve.
thanks
Mar 23, 2014 | Computers & Internet
Black flickering screen on my tobisha laptop
flickering screen could be the inverter being faulty these inverters are cheap to buy just make sure you get the correct one.
Could also be an issue with your sleep button these are very small and gets activated with you close the lid.
LCD back light is broken.
inverters do brake as it supply the power to the lcd.
Mar 09, 2014 | Computers & Internet
Start up
First I will suggest you to Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen
After that restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacture site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
Jul 04, 2013 | HP Pavilion DV2910US Laptop
How can I get my laptop to start? I can't even get it to safe mode!
You will need to repair the Microsoft Windows installation using the orginal recovery disk that came with your notebook.
Also the laptop is overheating, clean the intake and exhaust vents.
Take care!
damnor01
Jun 11, 2012 | HP Computers & Internet
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
Screen is black upon start up and I cant see anything. I can hear it starting up.
Press FN+F6. If the display is not back then follow the steps.
Please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. After the if you seen the screen dark then press FN+Right arrow in key board(>). When you press FN + ( < ) or ( >) key that's time its working for brightness controlling for screen. Now if all well then fine other wise please let me know .
Another suggestion is, run your Acer driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Feb 10, 2010 | Acer Aspire One Netbook 8.9" Notebook
Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Mar 25, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
Open Questions:
AOL MAil TecHNicAL SuPPoRt {1.855.536**5666}#[email protected] NEW JERSEY This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 22, 2019 | AOL Computers & Internet
AOL MAil NuMbER {1^855^536^5666}#[email protected] TEXAS This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Epson Printer Tech support number -*+1*{855~536~5666}.*'- Epson Printer Customer Support KJAWLLI [email protected] is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the [email protected] email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. [email protected] support number When you are using the [email protected] for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the [email protected] support number and ask for the help. Once you dial the [email protected] customer support number, you come in contact with a team of experts at the [email protected] customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the [email protected] support phone number will help you with that simply and quickly. This is [email protected]'s best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a [email protected] agent. Features of [email protected] support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the [email protected] customer support phone number. Here are some of the features of customer service: The [email protected] customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the [email protected] customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this [email protected] provides you the facility of [email protected] support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the [email protected] Here are some of the issues that you are going to face when you are using the application:
Oct 22, 2019 | Epson Computers & Internet
Computers & Internet Logo
55 people viewed this question
Ekse
Marvin
Marvin
