Question about Interactive Toy Concepts Crossfire Arctic Cat Rc Snowmobile
Need to find replacement for broken belt/track.
    President:
  • 1,978 Answers
Belts for cleated tracks are no longer available from arctic cat. You will have to find a used belt on EBAY, at a salvage yard, or upgrade to a rubber track. An Arctic dealer can look up pieces needed to upgrade to rubber track from the old accessory parts listing to do the upgrade. You will need to replace your drive sprockets and possibly the drive axle to run a rubber track with out cleats.
Posted on Jan 16, 2011
SOURCE:
Hi my top loader don't spin what can be the problem it wash rinse but don't spin
The drive belt may be broken. The belt pulls and spins the the pulleys to make the machine spin. Empty it out (water) and unplug it. Turn it on its side to see if you can get access to the inside from the bottom, otherwise see if there is a panel you can unscrew on the back. Once you can see inside you will see that there is a belt off track or broken. Replace the belt and your good to go. You can probably get a belt from sears or home depot for less than $20.00
Sep 05, 2016 | Washing Machines
Fde436rbt1 troubleshooting
The problem is most likely the=> Drive Belt 134503600
has broken or come off of the=> 5303212849 Idler Pulley Assembly
The Idler Assembly could also need to be replaced should it be worn out and throwing the belt off track. You just will not know until you are able to look at it physically. The belt roution is as follows
I will be here should you have questions, Thanks Sea Breeze
Feb 28, 2013 | Frigidaire Dryers
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
1997 Jeep cherokee larado squeals replaced the drive belt a few times and it keeps tearing
Inspect the belt tensioner for the following conditions:
Noise
  • If the belt squeals, the tensioner force may be insufficient. Check the belt length gauge, if the length is correct, replace the tensioner.
  • If the tensioner clatters or rattles during engine operation, there may be internal interference or wear. Replace the tensioner.
  • If the belt chirps, you may have a worn pulley or tensioner or cracks in the tensioner bas or arm. Check the mounting bolts, if they are okay, replace the tensioner.
Sticking or Seized Tensioner or Idler
  • If the tensioner does not operate smoothly or doesn't move, you may have: internal thrust surface damage/wear, internal damage/wear, or a broken spring, replace the tensioner.
Appearance
  • Inspect the tensioner arm for cracks or other damage. If the tensioner is broken, it should be replaced.
  • Look for excessive tensioner movement at idle, which can indicate internal wear, an out-of-round pulley or loose mounting bolts. Check the mounting bolts, it they are in good condition, replace the tensioner.
  • Make sure the tensioner is not tilted or misaligned. Also make sure a gap exists between the tensioner arm and base. If you notice a problem, check the mounting surface, it the surface is okay, replace the tensioner.
Belt Tracking
  • If the belt does not track properly on the pulley tracking surface, you'll need to troubleshoot the problem. Check the mounting bolts and the system alignment. Then, make sure the correct belt is being used for the vehicle. If all of these things are intact, replace the tensioner.
Belt Length Indicator
  • A belt length indicator is built into each tensioner.
  • The gauge identifies the effective operating range of the tensioner.
  • It consists of a pointer and either two or three length marks.
    • On a three-mark gauge minimum belt length, maximum belt length and ideal belt length are indicated.
    • On a two-mark gauge only minimum belt length and maximum belt length are indicated.
    • Ideal belt length on a two-mark gauge is generally half way between the minimum and the maximum.
  • When a belt wears and stretches with age the tensioner will move towards the maximum belt length to maintain proper tension.
  • As the pointer nears the maximum length mark, replace the belt.
May 04, 2012 | 1996 Jeep Grand Cherokee
The serpentine belt on a 2.4L is VERY loose after alternator replacement. Can I tighten it or is the tensioner or belt dead?
I think you are on the right track, suspecting the tensioner. It should spring back after you release it. There is a pretty heavy spring inside, it may have broken.
Nov 21, 2011 | 2000 Chevrolet Cavalier
I am trying to get the serpentine belt back on but it sems that the tentioner is not in line with the rest of the belt track. I think this is why i can not get the belt back on.
IF YOUR DRIVE BELT HAS BROKEN AND YOU ARE REPLACING IT AND THE BELT TENSIONER NOT LINED UP WITH BELT.EITHER TENSIONER BOLT LOOSEN OR TENSIONER IS BROKEN AND NEED REPLACING.
May 17, 2011 | Chevrolet Cavalier Cars & Trucks
Nokia 6300 queries
For your first questions ans there may be loosen the LCD belt so if your phone is under warrenty go to near by NOKIA care and if not in warranty unscrew your phone and check the LCD belt if required tight it. Still have a problem then your LCD belt may broken so replace your LCD with new one because belt is not replaceable. Hope this may solve your 1st problem
Now for 2nd problem just install the nokia pc suite it can read easily.
For your 3rd problem go to getjar.com and find alarm application after some search you can find the JAVA application to fulfill your requrenment.
And for last problem go to music player and then option and setting change repeat option to single track to all after doing this you can listen songs without selecting next track.and make a playlist for listning your faourite songs among all tracks...
Hope this will solve your all problems best of luck n dont forgate to reply...
Jul 24, 2010 | Nokia 6300 Cell Phone
KENMORE DRYER MOD# LEQ9858LWO WILL NOT TURN BUT HEATS
If you hear a humming, then it is probably a broken or slipped belt from the motor to the drum. There is usually a pully on the shaft of the motor, a tensioner pully on a spring, and a groove on the back of the drum that the belt rides in. If this belt breaks or comes off track, the motor will still spin but the drum won't.
You will probably need to take the front or back off of the dryer (varies by model) to expose a view of the belt, and once you do this, it will be easier to see if the motor is turning or the belt has broken or slipped.
If the belt has slipped, be sure to inspect it for wear, and replace it if worn. Otherwise, it will slip again and you'll have to repeat the process.
Jun 10, 2009 | Whirlpool LEQ9858L Electric Dryer
My Sharper Image Power Tower 200 won't turn
Most likely the belt is broken. The CD track can be removed by taking a slot screwdriver and gently pushing in the center tabs on any track. With a little patience you will eventually release the track and expose the inside where the motor, gears and belt drive are located.
Dec 20, 2008 | Sharper Image Power Tower Motorized DVD...
Interactive Toy Concepts Crossfire Arctic Cat Rc Snowmobile Logo
263 people viewed this question
Top Interactive Toy Concepts Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
