Question about Sony Alpha DSLR-A350K Digital Camera
I have a Sony Alpha 350 DSLR and I have a hand with an exclamation mark in it, the shutter will not operate either. I have replaced the battery and memory card, done a reset to default and it is still there, any clues? It was working perfectly until I swapped the battery to a re-charged one. Pauline
SOURCE:
  • 9 Answers
SOURCE: MY MEMORY CARDS NO LONGER
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.
Best regards - Michael
Posted on Feb 16, 2009
  • 9 Answers
SOURCE: Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
fotomohamed
  • 321 Answers
SOURCE: Sony Alpha won't read memory card
card slot pin is stuck or broken
Posted on Jun 19, 2009
Obertelli
  • 3006 Answers
SOURCE: MY BUILT-IN FLASH NO LONGER WORKS WITH MY SONY ALPHA 300 DSLR
In that case it's broken and is not a DIY fix. Usually it's either the flash tube or flash charging circuitry/capacitor, and they're the sort of things which can just fail suddenly.
Your camera will still be under the manufacturer's one year worldwide warranty, so contact Sony in your country to find out what the local arrangements are.
You'll need to provide proof of the purchase date, if you cannot do so then the repair will be chargeable; Sony have a fixed fee policy for dSLR repairs and if you're in the UK then it's currently £114.56.
Note that if you're in the UK then you additionally have Sale of Goods Act protection for up to six years (five in Scotland). The Act states thaty goods must be of durable quality with respect to the price paid and intended use. Clearly the camera should not fail within such a short space of time so you may be able to return the camera and demand a refund from the retailer. Enforcing your rights is sometimes a different story altogether, but note that if you accept a repair from the retailer then you future rights to reject the goods are severely reduced.
One further VITAL point: if there is even the slightest evidence of any unauthorised repair attempts, all your consumer rights vanish.
On balance, I'd strongly recommend that you either return the camera for exchange/refund or return it to Sony under warranty.
Hope that this helps, all that I ask in return is for you to take a moment to rate my answer.
Posted on Feb 03, 2010
SOURCE: Alpha DSLR-A100 Digital Camera: i got problem with memory card. keep showing the m...
not all memory cards fit sony alpha perhaps you have bought wrong cd.try using your sd slot
Posted on May 06, 2010
How can I use timer on sony alpha 33
Using the timer should be fairly straightforward once you read instructions on doing it from the user manual:
Sony DSLR A200 manual
Apr 20, 2014 | Sony Alpha DSLR-A200 Digital Camera
Sony a100 wont turn on
If the battery is charged, try replacing the battery first. Also try turning on the camera with the charger plugged in. If neither helps, you will probably need to have the camera sent for repairs, but you can still try checking out the user manual for helpful information:
Sony Alpha DSLR A100 manual
Nov 11, 2013 | Sony Alpha DSLR-A100 Digital Camera
I m using sony alpha 330 dslr cam but recently i am getting camera error displayed on screen but though m able to click pix. so if ne1 can tel me what the error is about?? Thanx
there is something wrong with your lcd screen or shutter button.you can send to the professionally maintance center or yourself find the replacement on the website.
www.skiliwah.cn/
MSN:[email protected]
Aug 17, 2011 | Sony Alpha DSLR-A330 Digital Camera
Hello, I'm having troubles with my camera, a sony alpha 580 dslr. I try to take a picture and the shutter stays down a few seconds when I don't have it set to that and it is making these awful grinding...
sounds like the shutter chain is slipping, or shutter is sticking, this does not look good. you may need to have the body replaced, usually camera shops will tell you that the repair costs more than the replacement.
i would take to a sony dealer for further advice, I assume you are still under garantee you should be ok. as this model only came onto the market last august. and usually has 24 months cover on parts.
I hope this was useful.
Jan 23, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
I cannot figure out how to use the timer setting on my Sony DSLR a100. HELP
Press the Drive button (marked with a one-handed clock). Use left/right to select the one-handed clock. Use up/down to select the delay, then press the OK in the middle of the cursor pad. Start the self-timer by pressing the shutter release button.
May 22, 2010 | Sony Alpha DSLR-A100 Digital Camera
How to attach remote shutter release (RM-S1AM)to
HI,
You need the RMT-DSLR1 Remote Commander for this model. You have the wrong remote. The camera only has a USB connection for a PC or printer.
Mar 11, 2010 | Sony Alpha DSLR-A380L Digital Camera with...
HOW TO USE HDR FROM SONY ALPHA 300
HDR IS NORMANLLY A PROGRAM AND IT WORKS GREAT BY TAKING THREE IMAGES AND GETTING THE BEST TONAL RANGE .
Nov 27, 2008 | Cameras
Sony Alpha DSLR-A350K Digital Camera Logo
95 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
