Question about RTO Plasplugs DWW406US Power Master Wet Saw
MY PLASPLUGS POWER MASTER PLUS WET SAW MODEL #DWW406US HAS A BAD POWER SWITCH .HOW OR WHERE CAN I GET A NEW SWITCH.
My Ryobi 10" Compound Miter Saw (with laser) will not turn on when I push the button. Nothing happens at all. Its as if a safety switch needs to be turned off, but I'm not finding one.
you did not give model number. The saw should not be used without blade guard uncles you are to attached to your fingers. the power switch may be bad or it could be motor. Should not buy used power tools without ensuring that is operating properly. Here is a site that sell replacement pars. be careful that the price of repair parts plus the purchase price does not come to more than 50% the price of new tool
https://www.toolpartsdirect.com/
Jun 12, 2018 | Ryobi Saws
DWW105US replacement motor
there is no 105us but there is 100 and 110 and 150,it is actually a plasplugs tool heres the pdf manual for the dww100
http://www.plasplugs.com/manuals/DWW100.pdf
the 110mt
http://www.plasplugs.com/manuals/DWW110MT.pdf
dww150
http://www.plasplugs.com/manuals/DWW150.pdf
there is also a 1 year guarantee,
Support Shop help
You don't need a Paypal account to buy from us, just select Paypal and then add your credit card details no need to log in.
If you are having problems using this store please contact us at:
Plasplugs Products Limited
Windsor House,
Windsor Industrial Estate,
Hawkins Lane,
Burton upon trent
DE14 1QF
VAT Registration no. GB 130 0581 64
To contact us by telephone, please call 0800 840 6820.lines are open 0830hrs 1730hrs Monday to Thursday and 0830hrs to 1430hrs on Friday, excluding Bank Holidays.To contact us online please complete e-mail [email protected]
http://www.plasplugs.com/index.php?main_page=page&id=19
Apr 21, 2015 | Saws
Craftmans radial arm saw model 113.198111 short down within 3 to 4 seconds and pops circuit breaker
I purchased a Master Craft radial arm saw brand new and made three cuts and it did the same thing. I took it back to the store where I bought it and they gave me another new one. Something in the motor had burnt out.. You could smell it also.
Sep 09, 2014 | Craftsman Radial Arm Saw, Power Switch,...
Switch won't work
Take it apart and fix the switch or put a new, different switch in the circuit. May just be a broken wire. Jack
Nov 23, 2013 | Roberts 10-22500 QEP 7 Tile Wet Saw
I'm trying to change the blade on my Plasplugs tile wet saw, after not having used it for over three years. No matter what I do, I can't get the nut off! I've tried WD-40, graphite, hammering...
Try rotating the nut COUNTER-CLOCKWISE.
Usually, nuts and bolts are Righty-Tighty, Lefty-Loosy, but frequently saw blad nuts use a Lefty-Tighty, Righty-Loosy.
They are built so that when the blade starts to turn, it puts a momentum on the nut that tightens it, so that a loose nut won't come flying off, and get someone injured.
Jun 26, 2011 | RTO Plasplugs DWW406US Power Master Wet...
MY SWITCH WENT OUT ON MY TILE SAW WHERE CAN i GET
You can get the part from husky website at:
http://www.huskysupport.com/products/product.aspx?ID=4
From there scroll down till you see part number
6102018
switch Knob for $5.38
Hope this is what you are looking for
Nov 30, 2009 | Wet International Husky 7" Wet Tile Saw...
Instructions
I found the instructions at the website www.plasplugs,com you can download them or print them.
Nov 16, 2009 | RTO Plasplugs inc No. TLC207 Tile Cutter
How to fix a tile saw pump
take it all apart and clean it completely. They do not put pump in saw water, use only totally fresh and clean water.
Jul 14, 2009 | RTO 6391K Felker 24" Tile Master Plus Wet...
Dewalt ds2400 wet saw will through in line breaker not start
sounds like the breakers working to good,i would by pass the reset switch,most likely that switch is bad anyways,we always plug our saws into a outlet box that has a breaker in it ,you know those reset switches are stupid, by pass the reset switch like it wasnt even there,and if that works i would replace the whole cord with a new 1,and buy a 5 dollar junction box that has a breaker in it,i dont know if there is a seperate plug on that saw where u plug the water pump into, if there is i would check that plug first before you bypass the switch.good luck chad
May 14, 2009 | Dewalt D24000S Wet Saw With Stand
Need to change the blade on a plasplugs diamond wheel wet saw
The shaft threads seemed to be stripped and you may have to get a set of Torx bits or if not then one bit for the torx screws to take them off. If the threads are stripped on the shaft then you may have to replace it.
Ken S.
Mar 23, 2009 | Saws
RTO Plasplugs DWW406US Power Master Wet Saw Logo
269 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Vuk B
Bill Boyd
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
