Question about Sharp R-1514 Microwave Oven
The start button stopped working it makes a wierd clicking sound like its broke. The fan button, light button and stop/cancel button all work fine. My wife said she has been pushing it sideways for awhile now to get it to work, i guess it finally went out. I need to know how to change the start button.
SOURCE:
  • 12 Answers
SOURCE: buttons won't work
It sounds like has loose wires that are contacted to the display screen or the lcd lights are busted on the display I would return it.
Posted on Dec 30, 2007
MicrowaveSvc
  • 9174 Answers
SOURCE: Microwave Stopped Running
Sounds like you have a problem with the keypad or controller, or possibly bad door switches or mounts.
In any case, for your convenience we have posted the entire service manual at our site:
http://www.microwavedisplay.com/R1870_R1871_sm.pdf
I would also suggest you look over our door switch file at http://www.microwavedisplay.com/doorsw.txt
If you need further help, feel free to contact me directly or reply back.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
MicrowaveSvc
  • 9174 Answers
SOURCE: Sharp R-530ES microwave oven stopped working
You have a bad secondary interlock (lower door switch) or its mount is damaged or out of alignment.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Dec 28, 2008
MicrowaveSvc
  • 9174 Answers
SOURCE: Sharp Microwave diplay light not working
We regularly repair these display / control units nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller, AS-EET
[email protected]
Microwave Oven Control Panel Repair Nationwide
Posted on Jul 11, 2010
MicrowaveSvc
  • 9174 Answers
SOURCE: Sharp 510 HKF "clicks" only when start button
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Posted on Jan 28, 2011
Work light and fan stopped working
sounds as if your touch pad ,and,or the circut boaed it's connected to is going bad.
Nov 08, 2013 | Kenmore Microwave Ovens
I unplugged my aunt's microwave to clean it, when I plugged it back on the light inside is on and the plate turns and the fan goes, cannot do anything with it, can't cancel or start, only way is...
Likely when you cleaned it, grease mixed with the cleaner you used got between the button panel and the actual button switch behind the panel, making it stick on. Will need the model to determine how to remove the panel to clean underneath...OR, it may dry out and start working normally again.
Nov 03, 2017 | Frigidaire FMV145K Microwave Oven
GE Microwave Doesn't Work, Timer Ok
More than sure, the door micro switches do not work properly, they should be carefully checked.
Sep 24, 2017 | General Electric Microwave Oven
Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
May 12, 2009 | Dacor DMT2420SS Microwave Oven
Lite bulb & fan stopped working but oven works fine.
had the same problem (self induced) and shorted out the oven.  took the control board out and found i had burned the circuit between the connector and high/low light microswitch.  just jumped the circuit with a piece of solder, reinstalled the board and the fan and light started working. it doesn't have a low light setting anymore but who cares, just saved 130 bucks.  not going to tell my wife how i broke it, only how i fixed it. very proud of myself and learned a little bit, mainly unplug the unit before working on it.
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave running although not turned on
Thought I had answered this, but this is usually caused by either a bad door switch, a loose door switch mount, or possibly a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Apr 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 11, 2007 | KitchenAid KCMC155J Convection/Microwave...
Microwave won't heat food.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Dec 21, 2006 | Maytag MMC5000 Microwave Oven
Sharp R-1514 Microwave Oven Logo
104 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
