I lost the camera usb cable to load pictures from my olympus camera to my computer . where can I get another one ?
    New Friend:
  • 13 Answers
I would recommend buying them off of Ebay. In my city, the cord is about 40-50 dollars in any store and about 2 dollars on eBay.
Find the model number of your camera and then do a search on ebay with your model number. You will find the cord.
You can also buy a USB stick that you can insert your memory card into and then plug into a USB slot in your computer. These USB sticks are sold also on eBay, or any store like Best Buy, Future Shop, etc.
Posted on Oct 24, 2010
Testimonial: "Thanks .I bought it for 2.50 a buy.com "
SOURCE:
I have olympus fe-330 camera but i lost the usb cable.how can i transfer pics to my laptop?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 09, 2012 | Olympus FE-330 Digital Camera
How do you down load pictures to the computer from a olympus sp800uz
You must install special software that came with the camera to up load pictures to a computer with the cables that came with the camera. The detail is covered in the manual of which a copy can be down loaded from http://static.highspeedbackbone.net/pdf/olympus_SP-800UZ-Manual.pdf
A quick method of using the SD memory card in your camera to shoot pictures on, and then removing the card from the camera, plug it into a card reader attached to your computer. You also can insert the SD card directly into your printer if that printer has "PICT-BRIDGE". That means that the printer has a card reader built in. Many newer Lap Tops have a card reader built in. You may also attach a card reader by USB connection to your computer.
In any event all of the above are covered by the manual.
Jan 23, 2011 | Olympus SP800UZ Digital Camera
I lost my usb cable and i want to copy my pictures from internal memory to memory card
Hi, You can use card reader to copy the pictures to your computer. I suggest to buy a new usb cable for best data transfer.
Regards,
Dec 08, 2010 | Olympus FE-280 Digital Camera
Can i charge an Olympus fe-4000 with a usb cable connected to my computer?
No. The camera does not incorporate any charging circuitry. You have to use the supplied battery charger to charge the battery. The USB cable is strictly for transferring pictures and videos to the computer.
Jun 28, 2010 | Olympus Cameras
Download pictures
Hi,please follow the steps given below;
1.Install on your computer the software that came with your digital camera
2.Connect your camera to your computer using the USB cable that came with your camera. You must have a USB port to download pictures to your computer.
3.Choose the folder where you want your pictures downloaded. The computer will choose the "My Pictures" folder by default unless you want them in a different folder.
4.Preview the pictures. You can delete any you don't like or want. Make sure to delete them off your camera as well or the next time you download that picture will downloaded again.
5.Select a picture and print. Some software will let you put borders and cute sayings on your pictures. Have fun with it.
Take care
Jun 13, 2010 | Olympus FE-310 Digital Camera
Transferring pictures
Once the camera is attached to the computer via USB cable, windows explorer treats the camera card just like another hard drive. the same goes if the camera card is inserted into a card reader.
Because of this, the camera can be seen as a listed hard drive, (C:), (D:), (E:)..... With windows explorer open view "Computer", listing all existing drives, plug your usb cable into the computer and the camera. When you turn on your camera, AutoPlay begins. Choices range from import pictures to viewing pictures with whatever programs are loaded into you computer.
If not AutoPlay then just use Windows Explorer. The Camera will appear as "Removable Disk (K:) [(K:) is on my computer]. Opening this disk will show subdirectories "DCIM" and 100OLYMP. Your pictures are in 100OLYMP. They can be higlighted and drug into the folder of your choice on your computer.
View with windows media center, etc. or download Google's free PICASA 3. It can also download ("Import") your pictures.
good luck
Nov 13, 2008 | Olympus Camedia C-700 Ultra Zoom Digital...
Question about my camera...
you can open up my computer, go to removable disk, open dcim, 100Olymp, and then copy and paste pics to your computer but it is easier to use the olympus master 2 program
download it from the following link:
olympusamerica.com/software
Oct 17, 2008 | Olympus FE-210 Digital Camera
Lost c-370 olympus cam driver
IF you are using Xp , just plug in camera with USB lead . Open MY COMPUTER find the icon for the camera( usually found after the DVD/cd drives ) adn just drag or use the move command to move the requiredfiles to where ever you want . I NEVER use the Olympus software too long winded . Hope it helps :)
Apr 25, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Need a driver for FE-190
need a driver or cd to download my pic on my computer olympus FE 190
Mar 30, 2008 | Olympus FE-190 Digital Camera
Olympus u725sw
connect the usb cable to computer
Dec 13, 2007 | Vivitar ViviCam 6330s Digital Camera
Open Questions:
Computers & Internet Logo
53 people viewed this question
Ekse
Marvin
Marvin
