Question about Sony Cyber-shot DSC-W55 Digital Camera
Camera says please turn off than on - Sony Cyber-shot DSC-W55 Digital Camera
    New Friend:
    Problem Solver:
  • 14 Answers
Defective lens block assy
Posted on Oct 25, 2010
SOURCE:
Mine requests "PLEASE TURN CAMERA
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Aug 14, 2011 | Panasonic Lumix DMC-LX1 Digital Camera
How to fix my fe camera-340 when i turn on the
The problem is the firmware of the camera it seems to be corrupted.Firmware is the software installed in the camera which controls all the functions.Please contact any service center to upgrade the firmware as doing it yourself may harm the cam.
Thanks
Feb 16, 2010 | Olympus FE-340 Digital Camera
MY CAMERA WONT COME ON THE TELESCOPE LENSE WONT GO BACK IN IT DOSNT SEEM TO CHARGE
Please try the following: Don't forget if you're charging though the computer NOT to turn the camera on. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 27, 2010 | Kodak EASYSHARE M1063 Digital Camera
Dosent turn on
Whenever I turn camera on it immediately turns off.Battery new and fully charged.
Here are the steps for M873 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 18, 2010 | Kodak EasyShare M873 Digital Camera
Zoom turns my camera off
Here are the steps for no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 18, 2010 | Kodak EASYSHARE M1063 Digital Camera
I have Kodak EasyShere V1223 It won,t Turn on, Go
Here are the steps for V1223 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 17, 2010 | Kodak EasyShare One Digital Camera
Error in digital cam that please turn off the camera and on again
smeone had gifted me panasonic digital cam DCM LZ8 bt when i turn it on an error accurs that please turn off ur camera and then on again
please help
Jan 01, 2010 | Panasonic Lumix DMC-LZ8K Digital Camera
Cameera lens will not open (expand) when turned on.
Please check whether you're using a fully charged battery.
After fully charging the battery if the issue still persists, please try Power Resetting the Camera.
To Power Reset the Camera.
First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cameras
Camera turn off
dear top Experts. I have digital camera DC E30 BENQ .I do turn on my camera after seconds turn off.first please help me.secndly for repair my camera I need manual repair. thank you very much
Apr 09, 2009 | BenQ DC E30 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
57 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
