Question about GE Spacemaker JVM1640SJ Microwave Oven
GE SPACESAVER MICROWAVE MODEL JVM130H 003 DOES NOT HEAT GOOD AND DOES NOT HEAT AT ALL SOMETIMES ON A CYCLE. MY ONLY FIX IVE CONSIDERD IS A REPLACEMENT SINCE IT IS A 1990 MODEL.
SOURCE:
  • 43 Answers
SOURCE: GE Spacesaver over the range microwave oven
GE Microwave ovens, and Microwave Ovens produced by GE but released under different brand names, have had several power problems for the past 20 years. Because it is so easy to sell parts and charge outrageous rates for repair GE never corrected the problems. They just continued it in the next model. They found that you would most likely purchase a new unit rather than paying $75. for a service charge, and $150. for labor plus parts (if out of warranty period).
Most failures were cold solder connections on the power relay board. These would come completely dis-connected after arcing and burning away the solder. Could be 1 month, could be years, but they knew it would happen. This power relay board feeds 120volts to the LV (low voltage) side of the HV (high voltage) Transformer. No High Voltage,,No cook. Everything seems to run normal, but if you listen carefully you will not hear the low tone from the HV Transformer. Over my thirty years in the business I have re-soldered rather than replace so many I couldn't count.
Next to that, a defective Magnetron.
Posted on Jan 25, 2008
SOURCE: Microwave Fuse keeps blowing
where is the fuse located on model jvm1851wd001
Posted on Jul 21, 2008
SOURCE: 1985 GE Microwave Spacesaver Uninstall
I CAN'T FIND THE SCREWS TO ATTACH THE TOP OF THE SPACE SAVER TO THYE BOTTOM OF THE UPPER CABIONET, WHAT SIZE OF SCREW IS THIS. WHY DOESN'T IT HAVE A NORMAL SCREW, I ALREADY WENT THROUGH ALL THE SCREWS THAT LOWES HAS.
Posted on Aug 25, 2008
  • 108 Answers
SOURCE: GE Spacesaver XL JVM1341WW002 microwave broken door handle!
Its a free country Bage, but microwave energy is extremely dangerous! Repairs are not feasible unless performed by factory personnel under warrantry, and certified. I suggest you contact the manufacturer about the problem.
Ray
Posted on Nov 19, 2008
SOURCE: Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
Posted on Apr 02, 2009
I have a GE Spacesaver XL1800 Model#HDM1853WJ01 It will not heat, This is the second time, warrenty is out. Is it worth repairing. Is it the Magnetron.
sometimes... you can repair it by your self. but before the magnetron. try to check the high voltage fuse and the high voltage capacitor... ty
Jun 17, 2011 | GE Microwave Ovens
J,VM59 003 Feb '84 date GE Spacesaver-My display went dark. Otherwise it is fine.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Heat won't work on ge spacesaver microwave oven --what to do from
heatman101
ioi
Dec 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave has no heat
heatman101
ytewyteyu
Aug 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JVM141G001 Spacesaver microwave; fan and heat not working
The average cost of a over the range microwave is around $550. You would have to call around or go visit an appliance store or a place like HOME DEPOT or LOWE'S to get a price quote on replacement parts. If it is cheaper, FIX IT. Good luck.
May 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Heat doesn't come on in microwave
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | Microwave Ovens
GE Spacesaver doesn't heat
if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Aug 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
151 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
