SM8280867 water not going out. stops spinning futher
  • Anonymous Aug 31, 2008
    sm8280867 water not going out
Check rubber spider coupling between motor and gearbox.
Posted on Sep 24, 2008
Model SM8280867. Why does it fill, then spin without washing?
1.try to unplug your unit then wait for 5 minutes
2.plug back your unit
3.program back your unit and start
Sep 05, 2015 | Whirlpool Washing Machines
Sm8280867
See if all the connections are tight; try inter-changing the water pipes. Water should have good pressure at faucet.......
Apr 27, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not rinse
you can put the extraction pipe /drain hose to ground level and water will drain then should open vacume switch thw programer is at fault as the programe sticks
Aug 18, 2012 | Estate Washing Machines
Whirlpool SM8280867 stopped agitating and makes noise.
you can find disassembly video on youtube,chances are you probably need a coupling,part no.285753a u can find exploded image/parts from sears .com
Mar 06, 2010 | Washing Machines
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
ULTIMATE CARE II WASHER DOES NOT SPIN
you need to check your clutch lining. post me the model number for futher help
Jun 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
After a load of laundry is washed the clothes are still soaked. What would cause this?
Hello brendalee. The unit is not performing the rinse cycle. I can suggest you VERY SLOWLY turn the control knob a click or two and see if the water for the rinse cycle starts when the unit stops after the wash cycle. Unit should fill, wash again, and spin. If the machine never spins I will need Mgfr, model, & serial # to assist you futher if you wish to use some hand tools and repair the unit. Good Luck.
Oct 08, 2008 | Washing Machines
I have a magtag neptune TL washer that stops after each spin cycle and gives a LL or LO on the timer screen. I can open the machaine and fix the clothes. Sometime this works snd then again it does not. I...
There is a service brochure inside the machine and you can access the info on the self tests by finding this brochure. It may be that one of the springs or balancers on the drum holder is bad, loose or broken.
Jun 09, 2017 | Washing Machines
Washing Machines Logo
986 people viewed this question
Top Washing Machines Experts
