Moved a magnavox 51mp6200d/37 from one house to another. TV will turn off and flash a six-one code at the power button. Uplugging it might give me another few minutes, or a few days before it does it again.
  • mrfixit853 Oct 25, 2010
    I have not heard any clicking before it turns itself off.
  • mrfixit853 Oct 29, 2010
    I didn't find any loose connectors. I unplugged most of them anyway. 10 minutes after I turned it back on.... the 6 1 blinks again.
  • 4,889 Answers
Do you hear Any clicking noise before the set turns off?
Posted on Oct 24, 2010
  • eagle338
    eagle338 Oct 25, 2010
    In that case the first thing I would try would be to take the back cover off and check whether any of the connectors(on the boards) have come loose or just unplug and re-plug all of them. This is one of the most common problems that occur during moving. If problem persists then let me know. Some of the connectors(like those on the sustain boards and buffer boards) are slightly tougher to remove. If you get stuck somewhere let me know and I will see you through this.
    PS: Note that a plasma tv is High Voltage electronic device. Be sure to unplug before you begin. Do not touch components such as capacitors that can hold potentially lethal voltages for several days after the set is turned off. If you are not confident that you can do it yourself, then seek the advice of a qualified tv tech.As my mentor always says, your life and limb is worth much more than this.
    Sai.
  • eagle338
    eagle338 Oct 29, 2010
    6-1 means vertical deflection failure. Since you say the tv has been moved, I strongly suspect that there was some physical damage to the set and coolant leaking is the worst case scenario. Time for a call to a local tv tech unless you are highly skilled in HV electronics. You do not want mess with the deflection circuit without prior experience. If you want me to find you a tech in your area then please get me your zipcode.
    Sai.
SOURCE:
Magnavox 51MP6200D/37 has no sound or picture. Flashing code 68 (6 long, 8 rapid) on on/off button. What does code 68 indicate for this model?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips & Magnavox TVs are entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Sep 25, 2015 | Magnavox Televison & Video
The conversion board needs replaced.
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
51mp6200/37 won't turn on gives diagnostic code on power button six long one short what could be the problem?
Hello
Six Long and One Short represents the digit [61] of the fault diagnosis. You have to look for it at its service manaul for details. OK.
Oct 13, 2011 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51MP6200D/37, when watching, the picture faded to black and then the sound went within a minute. now the power light just blinks and to turn it off we have to unplug it.
maybe you set it in freeze mode or timer.... the blinking reason mostly is for freeze and standby mode.... try to rest your program in tv.
May 27, 2011 | Vizio L32 32 in. LCD HDTV
Magnavox 37MF331D 37 in. LCD TV tv will not come on, power light blinks. I tried disconnecting power cord and hold power button to discharge, still will not come on and as soon as I apply power again the...
I had the same problem with a Magnavox LCD TV. It would not turn on and the light on the external PSU flashed. I found a replacement 12V 5A power supply on EBAY. It brought the set back to life.
Sep 12, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Magnavox 37mf321D HDTV won't turn on
It may be touching in the back of the tv on a power point. Yours is doing the same thing mine did before it finely all most burnt up it self and my house The metal casting that the tv mounts on in the tv ,does not have enough room in it. the metal casing touches one of the power supplys in the back and shorts out. If its like my 32'' magnavox flat panel
Apr 14, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
MAGNAVOX 51MP6200D/37
You will have to give the set out for service. This is not something you can service yourself.
This can be some failed components in the CRT bias and drive circuits, or maybe a CRT has failed. This has to be determined by taking measurements and doing some tests.
I believe that your set may have been manufactured by Philips.
Philips Support:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=51MP6200D%2F37&session=20080214101141_66.249.66.131&slg=ENG
Jerry G.
Apr 16, 2008 | Philips Magnavox 27MS343S 27" TV
51'' magnavox 51mp6200d/37
It's 1020i, if you haven't gotten the info somewhere else already
Oct 28, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
