Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
I need a manual for a Kenmore Super Capacity 3.5 Quiet Tumble Action Washer
    President:
  • 1,937 Answers
See the following Sears site:
http://www.managemyhome.com/
Click on the Manuals tab, enter your model number and you should be able to get a PDF version of the manual.
Posted on Oct 24, 2010
Testimonial: "Thanks! That worked great. But now I figured out by reading the Owners's Manual what I really need is the Operating Instructions card."
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Ok so I guess it is common this problem. So I found there is a screen in the water exhaust line right before the pump. Take the lower front cover off of machine, via 2 screws front very very bottom of machine... thier there just lay on the floor and you will see them. Then you will see a black house type contraption... inside that is the screen. To remove remove the three hose clamps one silver and 2 greenish blue. whoops forgot to warn you bunch of stinky muck is gonna come out. Take the hose to the sink, not the disposal side, and attempt to clean. Then when you cant get the compacted yuck out of the screen thing... go outside and pound it upside down on a rock... ok dont pound .. you get the jest. You will now find every coin you ever lost... if your lucky like me you can know afford to go purchase an ice cold blizzard from DQ... Sorry but all that was the easy part. Suggestion dont work on this late at night after Home Depot is closed. Nother suggestion take the greenish-blue clamps to home depot and purchase normal hose clamps... I wish I would of had that option.. as you put it togethor make sure hose is moist to hell it slip on. I found I hooked the pump up first then the small drain top connection then the big fat main drain... and walla you just fixed your machine... you see the barrell wont turn with water in it, its a safety feature now it will be able to drain therefore it will spin...
Posted on Feb 17, 2013
2 Suggested Answers
6ya staff
SOURCE:
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I have a kenmore washer that does not drain and
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 03, 2010
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
heatman101
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
We have a Kenmore 3.5 Super Capacity Quiet Tumble Action Wash Easy Access. The spin cycle works however the water won't drain and our laundry is soaked. Help...
It could be either the pump or a clog in the discharge hose. Take a shop vac and attach it to the discharge hose to remove the water from the machine. Remove the pump housing and run a wire down the discharge hose to check for a clog. If there is no obstructions, reattach the pump housing and remove the pump motor. Run a spin cycle and see if the pump motor turns.
Aug 27, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
I have a Kennmore super capacity 3.5 quiet tumble,action wash,easy access washer. The problem is, it won't do the spin cycle and clothes are coming out wet. I looked at the tech sheet and it says to check...
You might want to check the plumbing in the bottom of the machine for clogs. On most modern washers, the spin cycle will not start if the water is not completely drained or doesn't drain fast enough. I had a similar problem and found a there was a rubber fitting with a plastic cup inside that serves as a trap to prevent debris from entering the pump. It had a piece of scotchbrite, forty cents worth of change and a hairpin stuck in it.
Jan 20, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
Jun 24, 2009 | Kenmore 44072 Front Load Washer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
4,910 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
