Question about Whirlpool Refrigerators
Center divider of refrigerator is extremely hot to touch. Is this normal? I don't recall it being hot. The refrigerator is operating normally.
  • 3 more comments
  • cassyv Jul 15, 2008
    Ours is extremely hot as well. Just started a day or two ago. Anyone have any info on this???
  • Anonymous Jul 20, 2008
    Same problem. Just noticed today. has anybody talked to whirlpool about this.
  • Anonymous Aug 21, 2008
    Same problem, will almost burn your hand!
  • Dakota1326 Sep 14, 2008
    Where door saeals against frig is extremely hot to the touch. Area is on the frig not the door.
  • rbhoppy Feb 10, 2009
    I have the same problem on a 10 year old GE Monogram builtin.
Turns out a circuit board had failed and the fan (back of frig) was not working. Because of this, coils were overheating which triggered the icemaker to stop functioning. Until the part was replaced, we put a portable fan in the back and within a day, things were cooling down and the icemaker was functioning again.
The part with installation was $200. Took less than a week for the part to arrive.
Posted on Jun 19, 2008
The center of the fridge where the doors seal is very hot. Took of back cover, coolant lines are extremly hot compressor making buzzing sound.
When you were at the back behind the compressor did ya notice that the fan thier by the compressor was running, what will make that center divider bar very hot (it's normal to be warm) is due to the fan by the compressor not running or the coil also near the compressor being clogged with dust. So check that fan and replace if not running and also be sure to clean that coil free of all the dust ( the coil should be cleaned every 6 months as normal maintiance)
GENE
Oct 04, 2011 | Whirlpool GD5SHAX Side by Side...
The middle or the sided refrrigerator is hot to the touch
Don't be concerned if it's not too hot, this is normal. However, you should be sure to read the manufacturer's instructions on how much ventilation space your model of refrigerator needs to operate well.
If the refrigerator is extremely hot, check to see whether your model has mullion heaters, which prevent condensation on the outside of the refrigerator. If so, you can turn them off, using the 'energy saving' or 'condensation' switch within the refrigerator.
If that doesn't help, perhaps the condenser motor is faulty. Call a technician certified for your model if this is the case.
Jun 08, 2011 | Refrigerators
The center divider (between the doors) gets so hot you can't touch it. Other than that- it works and cools just fine.
ok that is entirely normal
that is your moulion heater, it is ment for two things
a. it keeps your seals soft and plyable
and b. it controls hot air entry to the unit when you open the door
it offsets the heat barrier with the door open,
that is what stops humidity from building up oin the machine
Oct 16, 2009 | Samsung RS2630WW Side by Side Refrigerator
Center divider between refrigerator and freezer where door seals rest is getting extremely hot.
check the fan in the machine compartment...if the fan is not turning when the compressor is running you have a bad fan motor. this caused the youder loop to over heat trying to cool the condencer...hope it helps
Sep 19, 2009 | Refrigerators
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
The divider between the freezer and refrig is very hot to touch.
Normal for that strip to be warm since the cooling system is routed right behind it for heat transfer and to eliminate condensation. Will be warmer with increase in room temp, but if it is a significant change you should inspect/clean the coils behind the panel in the rear of the unit.
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Divider between doors has extreme heat for side-by-side model
there are 2 pipes running there to reduce the temp in the compressor its normal
Jun 16, 2009 | KitchenAid KSCS25FKSS Side by Side...
Compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
May 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Refrigerators Logo
302 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
