Question about Kodak EasyShare Z1275 Digital Camera
Lens stuck in the out position. will not take pictures
  • Kodak Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Oct 24, 2010
SOURCE:
Why is my camera taking picture in reverse through the viewfinder?
This sounds like a mechanical problem inside the camera. If it has a flip-up mirror behind the lens, for example, the mirror may be stuck in the up position. Have it serviced by a qualified technician.
Nov 06, 2014 | Olympus Cameras
Hi. my problem with my camera is that my niece play with it and she pushed the lens mechanism while the camera is on. now, the lens was stuck and doesn't comes out anymore. when i'm turning on
Force it out like it was forced in. Try to rotate the lens. Remember it has to be off. As soon as the lens is half way out, turn the camara on and the lens will go to its position. If not, while the lens is out turn it left or right until it's back to its position.
Good luck.
Aug 24, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
My cameras fell, afterward the lens did not go back to its position. i cant off the cam.also i cannot able transfer the pictures in the computer.
sounds like the lens is stuck, can be a barrell problem if so very expensive...try doing the picture transfer manually using a card reader
Apr 25, 2009 | Olympus FE-115 Digital Camera
Lens error, restart camera
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
My nikon says lens error
my camera says lens error. the lens is also stuck in the position as if it where taking pictures. it will not retract.
Jun 16, 2008 | Nikon COOLPIX L5 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Wide/telescopic lens stuck
This might be the problem:
http://www.instructables.com/id/Repair-Stuck-Lens-on-Panasonic-FZ5/
Oct 23, 2007 | Panasonic Lumix DMC-FZ8 Digital Camera
Camera froze whilst taking pictures, lens stuck.
It happend to me also. I think it is caused by the lens mechanism. It is stuck and it disabled all other functions.
Jan 02, 2007 | Canon PowerShot A75 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
41 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
