Question about Compaq Presario 5000 PC Desktop
Will not reboot
When rebooting, get message: "Non-System disk or disk error"
I have not disk in the drive
  • djessen Jun 07, 2008
    I tried the F2 @ power-up time and did not get the BIOS menu to change.
    I tried holding down F2 @ power-up time and did not get the option to change the BIOS options.
    DJ
  • 983 Answers
If any cd or dvd is there in the cd or dvd drive remove them first then try booting ....
if problem persists then check the boot device priority in the BIOS menu ....change the boot device priority if required(change to 1 st boot device floppy, 2nd harddisk drive,3 rd to cdrom drive)
i think you know how to go to bios setup (it s del or f2 at time when you switch on the pc)..........
if problem persists again check whether the harddisk is detected or not in the bios setup ...
if it is not detected then just open the CPU & check the bus & power supply cable connected to the harddisk remove them & reinsert them ...
if required then replace with the new ones ....
after this if the same problem persists then the operating system might have got corrupted just reinstall ....
still if you face same problem then the harddisk might have got crashed .....
just try partitioning them again ....
any doubts reply me
i am always here to assist you
thank you
bye ....
Posted on Jun 07, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jun 08, 2008
    at the booting time it will show with your below the logo whether f2 to pressed or f8 or del to enter in to bios setup or to change the order ... just check it & press the suitable key
  • 6,487 Answers
Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
Change your computer's boot sequence. To do this, you must change your computer's setup and the option that controls which device your computer uses to start from. Make sure that you select a device that has boot files (or operating system files) installed.
If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP) on the drive.
  • Mark Gil
    Mark Gil Jun 07, 2008
    Reboot again your pc and press DEL instead of F2 because some MOBO use that to get to your BIOS.
    Scholar:
  • 198 Answers
Did u by chance change any settings in the bios.... if yes please change the settings.... if u donno hw to chnge the bios settings... please ask me...
  • kishore swamy Jun 08, 2008
    when u boot ur system continuosly hit the f2 button.... u wil definitely fet into thwe bios menu... or else try del button also... press both the button simultaneously....
    once u get into the bios menu.... got to IDE devices and change ur booting priorities.... change it under primary master device... if u already hav an operating system in ur hard disk, then giv the priority to hard disk... for this u hav to change the settings... in case the operating system as got corrupted then u hav to install operating system, again frm a external source.... if u hav a bootable windows cd, u can do it... for this u hav to change the priority in the bios to cd-rom....
    usually in many of the systems ther wil be an option called"auto" . u please change the settings to auto in the priority order.... this will automatically take the correct device by itself and boot the system...
    for any assistance revert back
Non system or system disk error
Bad HDD? Have you tried a system restore/recovery. Reboot, at preboot repeatedly tap the F-11 key try to get to system restore/recovery.If it's an old machine you may need to replace the HDD.
Nov 06, 2012 | Compaq Armada M700 Notebook
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
My hp laptop shows non system disk or disk error
Apr 04, 2012 | HEWLETT-PACKARD MINI 5103 Netbook
Was using system and then it just powered down. When started back up it stated that there was a system error and the options were to restart normally or to do a system recovery (recommended). Would only...
Hello.
From your description, sounds like a hard drive error: problem with recovery, hard drive message.
So, I'd recommend a replacement hard drive.
Hope this helps.
Oct 21, 2010 | Toshiba Portege M800 Notebook
Message appears : Non system disk or disk error replace and strike any key when ready during start up.
a) You have a disk in the floppy drive or CD and the computer is trying to boot from that drive. Remove disk and reboot computer. Or ...
b) Your hard disk has failed
Or ...
c) Your operating system is damaged.
Apr 05, 2010 | HP Compaq 6720s Notebook
System Error
If you have a disk in one of your drives, windows is trying to boot off it. Make sure you haveemptied your drives and then try rebooting.
Jan 11, 2009 | Compaq Evo N610C Notebook
New HDD Install Prob
Basic Troubleshooting Tips after Installing a New Hard DriveBased on Seagate IDE hard drives.
If you have installed your drive and it does not function properly, perform the following basic checks:
Additional Troubleshooting Tips
If you have performed the preceding basic checks but the problem persists, follow these guidelines for troubleshooting specific cases:
After you install your new drive, your computer will not boot, and no error message appears on the screen.
The screen remains blank when you power up the system.
The system does not recognize the drive.
The dealer partitioned and formatted the drive for you in the store, but the drive does not respond when you install it.
The system hangs in FDISK or fails to create or save the partition record.
The system error message, "Drive not Ready," appears.
The FDISK error message, "No Fixed Disk Present," appears.
The drive does not format to full capacity.
The DOS message "Disk Boot Failure," "Non-System Disk" or "No ROM Basic - SYSTEM HALTED" appears.
The system error message, "HDD controller failure" appears.
Check your computer manual or BIOS manufacturer to determine whether your BIOS supports drives that have more than 4,092 cylinders. If your system has this limitation, use the following procedure to configure your computer:
Turn off your computer, open the case, and remove your new drive.
CAUTION: To avoid electrostatic discharge damage to your computer or hard drive, make sure you are well grounded before touching the drive, cable, connector or jumpers.
Move the jumper on the alternate-capacity jumper, as shown in Figure 6. This causes the drive to appear to your BIOS as having a 2.1-Gbyte capacity (4,092 cylinders, 16 heads, 63 sectors per track). You may need third-party partitioning software, such as Disk Manager, to achieve full capacity of the drive.
Remount your drive in the computer and replace the computer cover.
Insert a bootable system diskette into drive A and turn on the computer. It should boot from drive A and automatically detect the new drive as a 2.1 -Gbyte drive.
Insert your DiscWizard diskette into drive A and type A:XDM. Then press ENTER. This runs the Disk Manager program.
Follow the Disk Manager instructions to install the dynamic drive overlay and to partition and format your new drive to its full capacity.
After Disk Manager is done, reboot your system. You should see the Disk Manager banner and be able to access the full capacity of your new drive.
If the steps listed above do not remedy this problem, try the following:
Make sure the monitor is plugged in and turned on.
Check all cards.
Make sure the video card is seated in its slot and secured with mounting screws.
Turn off the computer and remove the drive host adapter. If the screen turns on after you reboot, the host adapter may be incompatible or defective. If so, see your dealer.
Check all cables.
Make sure the power supply is adequate for system needs.
Reboot the computer and listen to make sure the drive motor starts up. If the drive is very quiet, it may be difficult to hear its discs reach operating speed. If the drive motor does not start up, recheck all drive cables.
Verify that for each drive, a drive-type is listed in the system setup program.
Try rebooting your computer by pressing the CTRL, ALT and DELETE keys simultaneously. If the drive is recognized after you reboot the system, the computer BIOS test may be completing before the drive is ready.
One solution is to slow the processor speed during startup. If your computer has a turbo switch, set it to slow speed before turning the computer on. If there is no turbo switch, you may be able to use keyboard commands; see your computer manual for details. After the computer is up and running, return the processor to the fast speed.
Another solution is to warm-boot your computer after every power-on.
Check for I/O address conflicts. To isolate the conflict, verify that the drive and host adapter are compatible with your computer. Turn off the computer and remove all the peripheral adapter cards except for the video card and host adapter. If the computer recognizes the drive when you reboot the computer, turn off the computer. Reinstall the other peripheral cards, one at a time, until the conflict reoccurs. After you have isolated the source of the address conflict, you can resolve the conflict by changing the 1/0 address of the peripheral that appears to cause the conflict.
If Disk Manager has installed the DDO on your hard drive and you have booted directly from a diskette, the information in the boot record for the drive may not have been loaded. Make sure there is no diskette in drive A and reboot. If you want to boot from the diskette, follow the "Booting with a Diskette" instructions under "Advanced Disk Manager Options" on page 20.
Reboot the computer and make sure the drive spins up.
Check all cables.
Make sure the DOS or Windows version the dealer used to partition and format the drive is the same version you have installed in your computer. If it isn't, see your dealer.
Verify the drive-type values in the system setup program. You must install the drive using the same drive-type values your dealer used to partition the drive.
Check for 1/0 address conflicts between peripheral cards.
Check for viruses.
Check all cables.
Your setup system diskette may be corrupted. Try using a backup diskette.
Make the partitions smaller.
Change the interrupt jumper setting on the host adapter.
Some BIOS have a Track 0 protection feature that protects Track 0 from viruses. This may cause FDISK to hang the system. You must disable this feature in the system setup program before you can use FDISK. See your computer reference guide for assistance. Be sure to re-enable this important feature when FDISK is done.
Check all cable connections. Make sure pin 1 of the drive is connected to pin 1 of the hard-disc controller or host adapter.
Check for 1/0 address conflicts.
Verify the drive-type values in the system setup program. One of the following problems may have occurred:
The values may be set with an incorrect translation characteristic.
You may have entered a parameter value that exceeds the physical capacity of the drive.
You entered a translation characteristic that does not take full advantage of the drive's capacity.
The drive's physical specifications exceed the translation limits imposed by the BIOS.
CAUTION: If you change the drive-type values in the system setup program, you must partition and format the drive again. This erases data on the drive.
If you have partitioned the drive into individual logical drives, you may need to make the partitions smaller to access the full drive capacity.
If your computer supports LBA mode, you may need to enable LBA mode in the system setup program to access the full capacity of the drive. Refer to your computer's reference guide to find out how to enable LBA.
Your computer may not support drives that have more than 4,092 cylinders. Follow the instructions on page 25 for After you install your new drive, your computer will not boot, and no error message appears on the screen.
Reinstall the DOS system files using the DOS SYS utility.
Check all cables.
Use FDISK to verify that the primary partition is active.
Check for viruses.
Confirm the jumper settings on the drive.
Verify the drive-type settings in the system setup program.
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Oct 19, 2008 | Computers & Internet
Hi! I think I have the same problem that you did with your laptop.
Remove any cd's in the drive and any floppy disks and reboot. if that doesn't work hit F8 as it reboots and boot to safe mode...
Aug 25, 2008 | Computers & Internet
Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
May 09, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
75 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
