Question about Belkin (F5D7633UK4A) Wireless Router
How do secure my router - Belkin (F5D7633UK4A) Wireless Router
Where is my network security key
My friend,
You have to lo-gin into the router setup page .
1.Put this address (192.168.1.1) in the address bar and then you will see the router setup page.
2.Then this will ask you for the username and password.
3.Username is nothing so leave this blank and password is admin.
4.Then you will see the router setup page .
5.Click on the wireless Tab under the basic wireless settings you will see wireless security .
6.Click on the wireless security and you will see there your router wireless security key.
7.Always select Security Mode as WPA2 PERSONAL.
8.If you want to change the security key you can.
9.After changing the settings Click on the sav settings.
Regards:-
Amit Awasthi
Dec 09, 2010 | Linksys Wireless-G WRT54G Router
How to remove a router security key from a DIR-655 D-link router?
Please follow the below steps to remove the security key from your wireless router DIR-655.
1. launch "Wireless Security Setup wizard". by clicking on setup.
2. Click "Next" , You will get a screen giving you an option to select the security level.
3. There you can select "None - No Security". & click on "Next & then click on "Save".
This would remove your security key from your wireless router.
Regards
Oct 11, 2010 | D-Link DIR-655 Wireless Router
Wireless 'n' router
Please reset the Router to restore it to factory settings. Please locate a small pin point whole, reset button near the Ethernet ports of the Router and press it for 10 seconds. Once you reset the Router, please login to the Router and change the Router login password under Administration tab.
Please follow the steps mentioned below to secure the Wireless Network.
  • Please open the Web browser, type 192.168.2.1 and press enter.
  • Please enter the User Name "admin" and leave the password blank.
  • Please click on Wireless section and click Security.
  • Now, you can pickup any of the Wireless Security like WEP, WPA, WPA2 etc.
  • Select the Wireless Security encryption type and save the settings.
  • The Wireless is secured now.
Good Luck.
Thank you for contacting.
Jun 07, 2010 | Dynex DXWEGRTR Router
Vista attempts to connect with the router "unsecured network"
Hi Friend,
If the security is enabled on your computer then on router the security has to be enabled.
Please follow the steps:
1.Open the router page (192.168.0.1)
2.Enter the username and password
3.ClickWireless settings and fill the section as mention
Name(SSID)-As per your choice
Region-As per your location
Channel-6
Mode-Auto
Security options
WEP
Security Encryption
Authentication-Automatic
Encryption strength-64bit
Security Encryption key
Key1-type a 10 digit password
Click Apply. Turn off the router for 30 seconds and turn it on again.
I hope this will resolve the issue.
Regards
Chiranjeet
May 22, 2010 | NetGear WGT624 Wireless Router
Can't get the Linksys Router's list of Network Security Settings
The router has a built-in web-server.
So, just connect your web-browser to that web-server,
select the correct page, and click PRINT.
Jan 01, 2010 | Linksys WRT160N Wireless Router
Bought a new laptop and having trouble connecting to the internet, it keeps asking for a security key, I have tried all the numbers on the bottom of the router but nothing works, could you please tell me...
Your security key is usually in brackets on the bottom of the router. If a key was not provided with the router, you might want to call your internet service provider and ask them what it is. Also, the security key (password) for the router could have been changed at one time from the number that is on the bottom of the router.
Aug 18, 2009 | Zyxel P660HW-D1 Router
How do I secure this router?
Using your wired computer, open the router's setup page using Internet Explorer or any browser and type http://192.168.1.1 to open the router's admin page. Go to Wireless tab, then wireless security sub tab. Choose WPA for security
Apr 27, 2009 | NetGear RangeMax WPN824 Router
I DO NOT KNOW HOW TO SECURE MY MR814V2 ROUTER
Hello! To secure your wireless router, have a look at this Knowledge Base article below. This will guide you through the steps of how to set up wireless security on your exact model router.
MR814v2 Wireless Router Security Configuration Guide
Best of luck!
Mar 16, 2009 | NetGear MR814 Wireless Router
I want to secure my wireless router
Put a password on it.Configure your router for WPA personal (WPA-PSK ) encryption
Jan 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Security of wireless network
You can directly connect your computer to the router thorugh the routers "internet" port and then re-run setup. OR you can type the IP address of the router into your address bar (the default is tipically 192.168.1.1 or 192.168.0.1) and then enter the router username and password (I believe the Belkin default is username:"Admin" password:"Password") in the admin control planel look for a "wireless security" tab. You can then define your wirelss security settings there. Just remember to configre the same settings on all devices that will connect to the router.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D7633UK4A) Wireless Router Logo
21 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
