Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Hayward super ii wont start when cold - Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
  • 990 Answers
If this only happens when it is cold it is probally just a start capacitor. If you open the back of the motor it will be a black cilinder abount two inches by an inch around with two or three wires coming from it. Remove this noting where the wires hook up. I pool store or motor shop will have a new capacitor for you, but you have to bring the old one to match up. Replacing this should solve this problem for you.
Posted on Oct 24, 2010
SOURCE:
What's the capacitors MFD-rate on a Hayward super pump?
this depend on the pump horse power look at the cup is should have this numbers on it
Oct 04, 2013 | Hayward 1HP Super Pump II Inground Pool...
Hayward super II wiring
move so both terminals are used sometimes they don't line up put on 220 then move to other position
Jul 24, 2012 | Hayward Super Pump 1 1/2 - Hp for In...
I have a hayward super ii pump model sp1615z1 that wont start I replace the capacitor because it wasn't working when the timer turn it on.After replacing the capacitor the pump worked fine for a...
There is no cheap fix for a burned up motor...you'll need to replace it. You can replace just the motor for about half the cost of a whole new unit. When you replace the motor you should replace the pump seal as well. Your motor number should be UST1152 for the 1.5 HP and the seal number a 201.
John
Jun 27, 2011 | Hayward SP3015EEAZ Super II Pump 15Horse...
My hayward super II pump is cycling between hign and low speed every i second until it overheats and shuts off. What could be the problem
VOLTAGE IS SET FOR 230 AND YOU ARE RUNNING IT ON 120V BACK OF THE MOTOR HAS A WAY TO SET THE VOLTAGE.LOOK ON TOP OF THE MOTOR FOR THE WIRING SCHEMATIC . THERE IS A START AND RUN SPEED.. HOPE THIS HELPS VOTE Jay
Jan 30, 2011 | Hayward 1.5hp 230v 2 Speed Uprated Super...
Pump starts but then trips breaker ?
the pump motor has a short in it its pulling far to many amps thats why the trip pops out
Jul 30, 2010 | Hayward GO-KIT #2 HAYWARD SUPER II PUMP...
My Hayward Super II Pool Pump isn't priming. The
I think your impeller may be stuck OR your start capacitor has failed. Your pump is going off on over load because it cannot turn or cannot start.
Thanks for your interest in FixYa.com
May 14, 2010 | Hayward Pool Products Hayward Super II...
My Hayward Super II Pool Pump isn't priming. The motor will start, and hum for a few seconds but then it just shuts off. The motor will try again after a minute or two only to shut off again. The cycle...
Pull the six bolts on the back of the pump and pull the motor and pump housing back. remove the difuser and try spinning the impeller. If it wont spin you may need a new motor. If you pull the wires. You can find a motor shop in your phone book and they can rebuild it for you usually for about 100 bucks. Or replace it with new for a lot cheaper than what your talking. Good luck.
Mar 25, 2010 | Hayward Pool Products Hayward Super II...
How to remove hayward super pump difuser
They just press into place and to remove them you pull straight away from the rest of the motor/pump parts.
Oct 02, 2009 | Hayward 1HP Super Pump II Inground Pool...
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
147 people viewed this question
Top Hayward Pool & Spa Experts
Bill Jordan
john h
US Parts Center
US Parts Center
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
