Question about Dryers
Maytag Mofdel # LDG 9326 AE I need to take the front off to check the dryer vent tube.
  • 3,074 Answers
Http://www.partselect.com/dryer+open-cabinet+repair.htm
Posted on Oct 24, 2010
SOURCE:
My maytag bravos dryer says AF and I cleaned the filter what else could be clogged up?
check vent tube in back of dryer an also check the outside vent make sure you have a good air flow
Apr 30, 2015 | Maytag Dryers
I have a maytag heavy duty gas dryer model number LDG412 i need to know how to clean the vent all the way to the duct, the dryer is getting hot but it is taking a long time to dry clothes now, inside where...
while cleaning the venting is never a bad idea and i recommend its done yearly,a common problem with older (the ldg 412 is from the mid 1980's) Maytag dryers isa stripped drive hub on the blower wheel and absolutly no air is being circulated throughout the dryer. A lot of times when starting the dryer and when it stops a rumbling noise will be made if the blower wheel is the problem. To check it if is the blower wheel you can remove the front panel by removing the screws that are a slight angle at the bottom of the front panel,tilt it out toward you at about a 45degree angle,then off. At that point remove the four 5/16" hexhead screws holding on the front drum support,lift it up slighly then off. The blower wheel will be in the lower left corner and you could spin it by your hand if it spins around the motor shaft it slips onto and does not move the drum while turning the blower wheel,it is stripped and needs to be replaced.To replace it remove the 1/4" hex head screws that hold the front plate to the plastic blower housing(7 screws) and the 5/16" hex head in the tab also in the plate in the front of blower housing the plate where come off. To replace blower wheel remove the greenish/black clamp from the center hub and the thin metal ring that fits ina groove on the motor shaft, a special c/e clip ring pliers are needs to remove the ring. A inexpensive pair could be picked up at most places that sell tools(ace hardware/lowes/home depot/sears) The part number for the blower wheel is 303836 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
assuredparts.com
I hope this will help you to repair your dryer,
Gene
Aug 07, 2011 | Dryers
I have a Maytag Quiet Plus ll Model # MDE9806AYW. We found water in the dryer vent. Do you have any idea what could be causing this?
A plugged outlet vent. Start the dryer and go outside and check the vent. It should have a strong air flow. It the air flow is not strong check all the vent tubing and the outside vent.
May 31, 2011 | Maytag Dryers
Clothes are not drying as fast as before. Lint trap is not collecting ling.
venting issue. check vent tube for restriction. A quick way to know if it is external is disconnect vent tube run a load of clothes if they dry well then it is the tube, if it is the same then it is internal and the dryer will need to be disassembled and cleaned from the lint trap back. Good Luck Tim
Nov 29, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
The lint is not getting caught in the lint trap, the vent tube is full of lint, and the clothes are taking longer to dry. Is there a possible blokage inside the dryer?
Yes, maytag has two screws located on front bottom. Take off front of dryer and vacuum out everywhere in the machine and the exhaust line. Check your belt as this is a good time to change it, if you have never done so, you may need to take a digital picture to aid in putting on new one; its a little tricky. Good luck!
Nov 06, 2010 | Maytag Dryers
My gas maytag dryer has no heat
first check the thermal fuse for continuity in the dryer blower housing/vent,then check the high-limit and/or cycling thermostats and the radiant sensor(flame eye) on the burner tube of the unit,then check the ignitor in the burner tube housing and finally the boost and secondary gas valve solenoid coils on the gas valve body inside the unit near the front entry of burner tube
Apr 29, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I need to know what size vent tubing i need for an maytag neptune dryer
I believe 3 inch vent will fit this. Use a metal or aluminized vent if at all possible.
Dec 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Have an LDG 710. Igniter does not work in unit
can only think your not getting volatge to igniter so need to check that route. gas has to be present and is there a pressure switch for gas? checked your thermostats? safety's? heated cycle?
Apr 16, 2009 | Maytag Dryers
We have a maytag atlantis dryer and I would like to clean out the lint that get in behind the lint catcher in the front end of the dryer before it gets to the exhaust tube, but I'm not able to get my...
Check local HD, Lowe's, Wal-Mart, etc. for a Dryer vent cleaning kit. Among other items, there is a flat tube attachment which connects to your vacum hose allowing you to get into the lint filter area.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
