Question about GE Dryers
Dryer is plugged in and the power seems to be working fine...for example, the light is on when I open the door and the button for the light works when I push it on and off. However, when I push the start button for the dryer, it just makes a murmured humming sound, like a low hum. Nothing else happens and nothing else seems to function. Any suggestions?
  • 3,074 Answers
This may help;
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Oct 24, 2010
Testimonial: "Thanks a million. Yup, that was indeed very helpful, and exactly what I needed. You directed me to the perfect solution. Thank you, thank you."
  • noeeve Feb 22, 2011
    THank you I was so worried when my dryer stoped working I thought I would have to buy a new one THat site really helped.
SOURCE:
Washer won't start
a model and make would help...but give this a try first, unplug for several minutes and plug back in. will reset onboard cpu.
Dec 27, 2017 | Dryers
My dryer was working fine until one morning it wouldnt even start. We have cleaned out the traps, We have checked the door... the light comes on every time its opened. The buttons seem to work and move...
This is a symptom of a blown thermal fuse located on the blower housing. This thermal fuse is in wired in series with the motor and power to the motor is cut when the fuse blows then the motor cannot run and no dryer function works. Click on the link below for the details on how to troubleshoot this kind of dryer problem.
Troubleshooting Whirlpool and Kenmore Dryers Not Starting
Mar 12, 2011 | Dryers
Dryer has power, buttons on front beep when touched, but dryer will not turn on when you hit the run button, and drum light has quit working, cannot seem to locate my users guide or fine one on-line to...
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Jan 29, 2011 | Kenmore 84072 Electric Dryer
Dryer will not start
Sounds like its blown a thermal fuse.Its under warranty if you just bought it.You need to set up a repair while you have warranty.
May 21, 2008 | Dryers
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Mar 17, 2008 | Kenmore 73952 Gas Dryer
Dryer suddenly stopped - F&P ED56 Autosensing Dryer
what is the make/model of your dryer and does it have an electronic display? different solutions apply to different models thank you
Sep 09, 2007 | GE DVL223GB Gas Dryer
Dryers Logo
532 people viewed this question
Top GE Dryers Experts
vince
gbob59
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
