Question about Silver Cross 3D Stroller
Damaged wheel bearing. How do i get a new one ?
    New Friend:
  • 3 Answers
Https://www.silvercross.co.uk/contact-us/spare-parts/
If you email siver cross they are pretty good at getting the parts you need :)
Posted on Oct 26, 2010
SOURCE:
How to fix this rear wheel 2009 vstar 950
Looks like the hub bearing has disintegrated. Take the wheel off and give it to a reputable bike mechanic to replace the bearings as special equipment and a press will be required. You may also need a new axle if its been damaged.
Apr 12, 2015 | Motorcycles
What will cause a rear axle bearing to go bad on one axle 3 times in two months?
the axle could be bent or damaged, the differential housing could be damaged, could be wrong bearing. you don`t say if this is a rear wheel drive you have or just a front wheel drive. there are front wheel drive bearings that have problems even new, because of manufacturing problems or inferior materials. try a different manufacture for a bearing.
Aug 24, 2014 | Cars & Trucks
If i replace twice the right wheel bearing and still damage the wheel bearing
if the bearing is new and the shaft is not damaged,and its fitted correctly,i cannot see why it is been damaged,so,make sure its the right bearing,, check the shaft the bearing fits on to, for damage and wear ,if all ok put plenty of grease on the bearing then re assemble the wheel,make sure the nut holding the bearing is not overtightened,and fit a new split pin.,also make sure the wheel is not damaged, now to be a 100% on the safe side have the steering checked over and the wheels ballenced,then you should be ok...hope that helps,have a good day....
May 09, 2014 | 2000 Lincoln LS
When sitting at a red light my Mazda 3 idles real funny...vibrating almost sounding like a cats purr?
2006 Mazda 3
Applies to 2006 Mazda Mazda3:
Available engines
4 Cylinders 2.0L MFI DOHC
4 Cylinders 2.3L MFI DOHC
Could be a number of things - you're going to end up checking the entire car.
Off the top of my head:
a) exhaust component has rusted loose (usually catalytic converter heat shield). Any loose exhaust component (hanger/muffler, etc.) will vibrate at idle.
b) glove compartment door - loose hinge
c) motor mount - rubber part of metal/rubber mount vibrates loose & falls out.
d) transmission mount - ditto.
The Maintenance manual for your car says:
Clicking noise at idle or driving
1 Inspect Main (Crankshaft) Bearing - Excessive Bearing Clearance.
1 Inspect Rod Bearing - Incorrect Rod or Main Bearing Clearances.
2 Inspect Rocker Arm - Worn or Incorrectly Adjusted Rocker Arm(s).
3 Inspect Piston Ring Set - Worn or Broken Piston Rings.
4 Inspect Piston - Worn, Damaged, or Faulty Piston.
5 Inspect Fuel Line Assembly - Fuel Line Leaking.
6 Inspect Hose Clamp - Loose or Missing Fuel Line Clamps.
Tapping noise at idle
1 Inspect Valve Lifter - Insufficient Oil Supply.
2 Inspect Fan Blade - Broken, Missing, or Faulty Fan Blade(s).
3 Inspect Oil Pump Screen - Clogged Oil Pump Screen.
4 Inspect Oil Pump Drive Gear - Damaged or Faulty Oil Pump Drive Gear.
5 Inspect Exhaust Valve(s) - Burned, Worn, or Sticking Exhaust Valves.
6 Inspect Oil(Crankcase)Capacity - Lifters Need Additional Lubrication.
7 Inspect Oil Filler Cap - Oil Filler Cap Damaged or Missing.
8 Inspect Oil Pump - Damaged or Faulty Oil Pump.
9 Inspect Oil Filter - Old or Clogged Oil Filter.
10 Inspect Oil FLow Check Valve - Damaged or Faulty Oil FLow Check Valve Caused Loss of Oil Pressure.
Vibration while Accelerating
1 Inspect CV Half-Shaft (Remanufactured) CCT - Worn or Damaged CV Half-Shaft.
vibration while braking
1 Inspect Brake Rotor - Warped or Uneven Brake Rotor Surface.
Vibration while driving - entire vehicle
1 Inspect Brake Rotor Specs - Warped or Uneven Brake Rotor Surface.
2 Inspect Ball Joint-Lower - Worn, Damaged, or Faulty Ball Joint.
3 Inspect Ball Joint-UPPER - Worn, Damaged, or Faulty Ball Joint.
3 Inspect Wheel Bearing-Front - Worn, Dry or Damaged Wheel Bearing.
5 Inspect Tie Rod End - Worn or Damaged Tie Rod Ends.
6 Inspect Wheel Bearing-Rear - Worn, Dry or Damaged Wheel Bearing.
7 Inspect Wheel Hub Bearing - Worn, Dry or Damaged Wheel Hub Bearing.
Vibration in rear axle area while driving
1 Inspect U-Joint - Loose, Worn, or Damaged U-Joint.
2 Inspect Driveshaft - Bent, Loose or Unbalanced Driveshaft.
4 Inspect Differential Drive Pinion - Worn, Damaged or Broken Pinion Teeth.
4 Inspect Wheel Bearing-Rear - Worn, Dry or Damaged Wheel Bearing.
5 Inspect Pinion Bearing - Worn or Damaged Pinion Bearings or Yolk Shaft.
Vibration in steering wheel while driving
1 Inspect Wheel Bearing-Rear - Worn, Dry or Damaged Wheel Bearing.
Vibration in tire/wheel area while driving
1 Inspect Wheel Bearing-Front - Incorrectly Tightened or Installed Wheel Bearing.
Vibration under vehicle while driving
2 Inspect Muffler - Damaged or Burned Out Muffler.
Vibration in rear wheeel area while driving
Dec 01, 2011 | 2006 Mazda 3
Bad Wheel Bearing on a 1994 Toyota Camry should I also replace the abs sensor?
You should only replace the sensor if it is damaged. Most Japanese made vehicles have bearings that are pressed in to the wheel hub. Your local parts store should have a new hub assembly that comes with the bearings already pressed in it. If you know of a machine shop that will press new bearings in the old hub and remove the old bearings that may be a little less expensive. They need to be removed and installed using a bearing press. Please rate me on this answer.
Jun 28, 2010 | 1994 Toyota Camry
How do i change front wheel bearing on a ford focus st2
SECTION 204-01: Front Suspension 2000 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/18/2003 Wheel Bearing
Special Tool(s) 15064.jpg Installer, Wheel Hub Bearing Cup
204-023 (T73T-1217-A) 21171.jpg Remover/Installer, Bushing
204-180 (T93P-5493-A) 15064.jpg Installer, Drive Pinion Bearing Cup
205-140 (T80T-4000-F) 205153.jpg Adapter for 303-224 (Handle)
205-153 (T80T-4000-W) d84l1123a.jpg Puller, Bearing
205-D064 (D84L-1123-A) 21217.jpg Installer, Wheel Speed Sensor Ring
206-054 (T93P-20202-A) Removal
  1. Remove the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
  1. NOTE: When removing the hub from the wheel knuckle the bearing will be destroyed. The bearing inner ring will be on the hub and the bearing outer ring will be in the wheel knuckle.
    Using the special tools, remove the wheel hub from the wheel knuckle.
  1. ani_caut.gif CAUTION: The special tools must be used to prevent damage to the hub. If the hub is damaged a new hub must be installed.
    ani_caut.gif CAUTION: Do not use heat to remove the bearing inner ring.
    Using the special tools, remove the bearing inner ring from the wheel hub.
  1. Remove the circlip from the wheel knuckle.
  1. Install the old bearing inner ring.
    1. Install the bearing cage on to the bearing inner ring.
    1. Install the bearing cage and inner ring assembly to the wheel knuckle.
  1. Using the special tools, remove the bearing outer ring from the wheel knuckle.
Installation
ani_caut.gif CAUTION: Avoid any impact on the wheel speed sensor ring.
ani_caut.gif CAUTION: Make sure the wheel speed sensor ring is clean.
ani_caut.gif CAUTION: Avoid any contact between the wheel speed sensor ring and a magnetic surface.
  1. ani_caut.gif CAUTION: Make sure the wheel bearing is installed into the wheel knuckle with the wheel speed sensor ring, colored black, at the wheel speed sensor end of the wheel knuckle.
    Using the special tools, install the new wheel bearing to the wheel knuckle.
  1. NOTE: Make sure the circlip does not cover the wheel speed sensor.
    Install the circlip to the wheel knuckle.
  1. Using the special tools, install the wheel hub to the wheel knuckle.
  1. Install the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
Apr 05, 2010 | 2000 Ford Focus
Had wheelbarron repaired and now brake light and abs light are on was put on computer and no codes show problems please help
SOUND LIKE THE ABS WHEEL SENSOR WIRES IS DISCONNECTED OR DAMAGED OR THE WHEEL SENSOR IS DAMAGED OR BAD.
Apr 02, 2010 | 2004 Ford Freestar
Replaced rear wheel bearings 2006 Volvo S60 and ABS lite stays on
Make sure the abs sensor is plugged in all the way.. And also make sure that the abs ring.. was not damaged in the process of putting on the new bearing...
Mar 02, 2010 | 2006 Volvo S60
I can't find any illustrations on tie rod ends or how to change the wheel bearings
tie rod ends you count the number of turns exposed and run the same number of turns on the new one after you install it. You can rap the side of the rod end with a hammer to break it loose, whack it!
Wheel bearings on the front you remove the wheels, remove the center cap on the hub, remove the cotter pin, then nut and washer, hub assembley will come off. Clean the spindle of old grease, remove the bearings, drive out and replace the old bearing races in the hub, install new races (cups) pack bearings in your clean hands with correct grease, install the bearings, install the washer, nut, tighten then back off a hair until you align the cotter pin hole. Do NOT overtighten, the bearings and races will be damaged! You snug the bearings to "seat them" then back off just enough that the wheels spin freely with no side to side play with the wheels installed to the hub. In other words grab the tires at the top and bottom and see if you have any movement toward the spindle or axle. Rear bearings are done the same way.
Sep 20, 2009 | 1994 Geo Metro
Car shakes when i put it in drive or reverse
1 Inspect Wheel Hub Bearing Worn, Dry or Damaged Wheel Hub Bearing. 2 Inspect Wheel Bearing-Rear Worn, Dry or Damaged Wheel Bearing.
Jul 02, 2009 | 1993 Toyota Camry V6
Silver Cross 3D Stroller Logo
146 people viewed this question
Top Silver Cross Baby Gear Experts
Steve Allison
Steve Allison
Marvin
Marvin
ray gallant
ray gallant
Are you a Silver Cross Baby Gear Expert? Answer questions, earn points and help others
