Question about Sony KP61XBR200 TV
Unsuccessful autofocus followed by E15R code--red curves out at corners
There were no warning signs. Powered up one day and the red convergence was terrible and the blue is possibly off. Looks 3D. The center is closest but horizontal lettering shows red shadow evenly below letters. Corners are drastically curved to outside. The red light somewhat resembles a bowtie shape in widescreen format. Any help would be appreciated seeing as how I live far from a repair shop. I am somewhat a diy but terminology and trade jargon I don't always know.
  • 1 more comment
  • ws6tester Jun 08, 2008
    Tried magnet trick and red would move around. Afterward tried autofocus and could see green and blue align at cross, red never moved. But immediately following autofocus blue and green are misaligned again. How long until the magnetic field is corrected?
    Are crt's replaceable by mortal man or require numerous solders instead of connectors?
    Will the blue and green correct back if I leave it off or leave it on? Or is this a new problem I created?
  • Sony Master
  • 8,617 Answers
EKse sent me your problem. What the problem your experienceing is caused by are the convergence amps need to be replaced. Your model is one of the few that uses the STK392-020 convergence ICs they are located on the D Board mounted to tow large heat sinks. Also check the 4.7 Ohm 1/2 watt metal film resisitors that are all in a row under the fins on the heat sink as its very common for a few of these resistors to be open. you will also notice 6 pico fuses that will be either solid green or solid yellow check them as well as they are 3.5 amp fuses. You can get any of the parts that you need such as the replacement ICs and resistors at the following link they have free shipping and they will help you out with free instalation instructions with pictures. let me know if you need more assistance.
Posted on Jun 08, 2008
  • Sony Master
  • 13,433 Answers
This clearly is a hardware side problem. Most likely the red crt tube is geting old - lazy - failing. and would need to be replaced.
allthought I'm not sure since I'm not fimiliar with this spesific model.
Here seems to be the service manual.
http://www.user-manuals.com/advanced_search_result.php?keywords=KP61XBR200+service+manual&forward=plist&osCsid=f600a9b9736a58ad3224ea4de796240b
Posted on Jun 07, 2008
  • 2 more comments
  • Ekse Jun 07, 2008
  • Ekse Jun 08, 2008
    Your problem is on the component level, not fixable with a magnet on the screen.
  • Ekse Jun 08, 2008
    Ofcourse you can keep trying it, noting to loose there..
  • Ekse Jun 08, 2008
    Its a huge tv..
    I will contact a collegue, Il give him a link here, expect him to reply within 24hours.
  • 983 Answers
There may be problem in CRT tube ....
you must and should visit the technician ...
he will fill the CRT tube again ....
this discoloration will be gone after that....
before that you can just try one trick ....
take a magnet and take it to the area where the discoloration is occurring & from that area just take the magnet to the corners or edge .....
by this the discoloration may go ....
try it .
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jun 09, 2008
    well only technician can replace it ... or if you have the detail idea on that you can do it ....
    Scholar:
  • 198 Answers
This is a problem of the crrt tube inside your tv..... there wil be major problem this tube,..... only because of this, the pictures r noyt clear....
http://www.devicemanuals.com/guide/Television/Sony/Sony-TV-Projection-KP61XBR200-User-Guide-TXpRNE9UZz.html
dwnld the user manual frm here and change the crt tube
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Picture in 3d without the 3d glasses
your convergence settings are moved and they need to be adjusted and if you adjust and still have the problem then its the problem of convergence STK ICS and they need to be replaced.
for adjusting the convergence please click this link this will help you how to adjust the red, blue and green settings in your tv.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
for replacing the convergence STKics just click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
feel free for further assistance.
thanks.
Oct 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence
did u do a repair in recent days
by replacing the convergence ICs?
Jun 18, 2008 | Toshiba 43A10 43" Rear Projection...
Red and blue separated and curved on bottom corners
IC8C01 267P173010 HIC - STK394-250
IC8C02 267P173010 HIC - STK394-250
THESE are the location number, part number and actual number of the two convergence chips which will have to be replaced.
Mar 18, 2012 | Mitsubishi WS-55613 55" Rear Projection...
When we try to adjust red cross, red adjustment will go side to side but not up and down. Red horizontal line is curved instead of a straight horizontal line. Blue can be adjusted up and down and don't...
Thats the classic sign of failed convergence ICs and resistors. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the parts and the Cd with instructions.
Mar 09, 2010 | JVC AV-48WP30 48" Rear Projection...
Distorted picture
You have a convergence problem.On this model you can change the convergence amp board which has the convergence IC's on it making it an easy repair.
Oct 06, 2007 | Samsung HC-P4752W 47" Rear Projection...
Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have bright pink and green on tv
this is a typical symptom of convergence. i.e red and blue beams arent not focus.
the convergence ics need to be replaced (check for open resistors), followed by a refocusing
pls rate me!
Mar 21, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Convergence problem?
The convergence anp ICs are usually what go bad in that unit. They are two ICs both are STK392-040 and they are at board location ICZ103 and IZC103 on the Sub Board attached to large heat sinks. You can get replacements with free installation instructions and free on line tech support at the following link.
http://servicemanuals.vstore.ca/
let me know if you need further assistance.
Apr 10, 2008 | Samsung HCL4715W 47" Rear Projection...
Blue curves up on the ends and red down
Your going to need to hook up a cross hatch generator to adjust the internal convergence alighnments. Anytime, a tube is replaced, there is alot of alighnment involved with the convergence, and it cannot be alighned from the customers convergence controls. I suggest first you get a service manual, and follow the alighnment to the letter for the convergence. If you do not have a cross hatch generator, then your going to need a test disc(DVD) that has a cross hatch on it. If you do not have access to those two things(cross hatch generator or the test disc) you will need to call out a tech to do this alighnment to the set. They (service tech) don't tell you when you get an estimate for a picture tube that there is some alighnment involved that reguires special test equipment. Thats why they charge what they do. I wish I had better news for you, but without proper test equipment, this is going to be a tough battle. Good Luck Please do not forget to rate this thread.
Dec 12, 2006 | RCA D52W19 52" Rear Projection Television
Sony KP61XBR200 TV Logo
250 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
