Question about Canon PowerShot A620 Digital Camera
Canon a620. no image on display and pictures turn out black
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Oct 24, 2010
SOURCE:
The viewer of my canon A620 is blank when I turn on the camera to take a picture
Press the DICP button 2 - 3 time and see the LCD turning on or not. Let me know.
Aug 07, 2012 | Canon PowerShot A620 Digital Camera
LCD SCREEN WILL NOT DISPLAY POWER SHOT A620
From my experience, there is a setting on your camera (to preserve battery) that makes the screen black. There is probably nothing wrong with your camera, you just need to find the DISPLAY button and push it until you see the image on your screen.
If you do not have a manual for your camera, you can download one here:
http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a620
Hope this helps!
Jul 26, 2011 | Canon PowerShot A620 Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
Power Shot A620 Canon 7.1 mega pixel 3 years
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 30, 2009 | Canon PowerShot A620 Digital Camera
Black screen
Simply right click on the track itself and select send to/DVD-RW or CR-RW depending on the type Compact disc drive you have. Then you will see a notification, "you files to be written to CD." Simply click on it or go to your Compact disc drive on My Computer and click “write these files to CD.” Then follow the screen instructions. IT is that simple. All you need to do is press and release the display button until the screen displays. Usually Canon Powershot cameras have 3 display modes:- colour, black & white, blank. Your camera is set to blank that is why you cannot see any image/screen displays no image. Just press and release the display button until the screen displays. That should do it.
Sep 13, 2009 | Canon PowerShot A620 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Screen is black while taking picture.
Think that you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Jul 25, 2009 | Canon PowerShot A620 Digital Camera
Canon powershot A620 black screen can't take pictures
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 25, 2008 | Canon PowerShot A620 Digital Camera
Canon A620 No Picture
First try hitting the DISP button (sorry if this offends, but many people have made this mistake). If this doesn't help, next try resetting the camera. Turn on the camera, and hold the menu button for at least five seconds. Believe reset is also in the menus.
If the above doesn't help, then unfortunately this sounds like your CCD image sensor may have failed. This would then require professional repair. Contact Canon at 1-800-OK-CANON.
Sep 14, 2008 | Canon PowerShot A410 Digital Camera
No pix on memory card...E18 msg on camera..
it sounds like the cards is know good. It happen to me once if you take the card out of the camera before turning it off it can destroy the card. Then the card is know good at all. The camera will not be able to read it or the computer.
Jan 16, 2007 | Canon PowerShot A620 Digital Camera
Canon PowerShot A620 Digital Camera Logo
621 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
