Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
What causes Ice to accumulate on the back wall of the freezer? We had not properly closed the door of the freezer before leaving for an extended time. Now we are having problems.
  • 520 Answers
If you left the door open for long, ice will build up. You need to turn off the fridge and let it defrost. this will take a while because it is probably also iced up in the coils where you cant see. when defrosting you may end up with water on the floor under the unit because the small drip pan isnt designed for this situation. best to put your food in a cooler and leave it off with the doors open for several hours. depending on how much ice, it could take 2 to 8 hours to defrost.
Posted on Oct 24, 2010
    Problem Solver:
If you have the freezer in the garage. it hot out there and the warm air will condense ,when u open it all the time. or the seal is not sealing right when its closed.
6ya staff
SOURCE:
795.72063.112 keeps accumulating ice in the freezer. Keep defrosting it but it continues. How do I find the problem and fix it once and for all.
This could be a lot of things. The most common cause of this is an air leak in the seals. To check the seals take a dollar bill and close the door on it leaving a little stick out and see how hard it is to pull out. There should be some resistance to pulling it out of the door. Then move it up and try again. Check all the doors to see if they are fitting tight. Any air leaks into the unit can bring moisture and then the moisture condenses and freezes near the evaporator coils. The other thing is a water leak from the ice maker or water lines. Last but not least is the defrost system. If there is an obstruction in the drain try that is under the evaporator coils then the unit is defrosting like it is supposed to but the water has no place to go and is running over the tray and refreezing on the walls of the freezer.
Jan 10, 2016 | Refrigerators
There is ice forming on the inside back wall of the freezer. What does this mean? Would it cause the refrigerator alarm (beeping noise) to go off?
It usually means that your door is either not closing properly or the seal is deformed. Moist air is getting in and condenses on the coldest surface at the back of the freezer. Check that the freezer is not too full (stopping door from closing fully) and check the door-seal.
Sometimes it is caused by icing of the thermostat. Ice is a good thermal insulator so the thermostat does not switch and the freezer keeps running constantly. Make sure there is adequate air circulation and no ice around the thermostat.
Defrosting usually fixes either problem.
Oct 13, 2014 | Refrigerators
Why won't my fridge cool properly
This happened to me also, I had to let refrigerator defrost all the way by unplugging it. The lines that carry the freon had frozen so they were not circulating properly. I had to buy ice and use coolers for food, then wait till next day before plugging unit back in.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Apr 24, 2014 | GE GSS22SGM Side by Side Refrigerator
Samsung RF26XAEBP frig a little over 2 years old sounds like fan motor is rubbing behind icemaker area when i open the door it stops close the door it starts again how to resolve?
You need to unplug and then remove the rear panel inside the back of the freezer and look over the fan assemblies to insure they are not hitting accumulated ice. Ice buildup around fans can be caused by leaving refrigerator or freezer door open over extended times or defrost component failure. Either way it's a good idea to have a look at the inside of the evaporator compartment to prevent damage to fan blades and food loss. Click HERE FOR=>> Samsung Refrigerator Model RF26XAEBP Parts I will be here if you have questions, Thanks Sea Breeze
Jul 03, 2012 | Samsung RF26XAEBP
How do you keep ice from accumulating in top freezer?
Make sure doors are sealed properly. Any leak will cause the freezer to keep running which is why the ice builds up in the freezer. Hope I have helped.
May 17, 2010 | Refrigerators
We have Kenmore side-by-side door refigerator, recently we found a problem with freezer, all the items any type of containers are getting iced in the form of a thin layer.even the sheves and most of the...
1)The door gasket on the freezer door helps keep the cold air in and the warm air out. If the gasket is dirty or damaged, it may prevent the door from closing properly, which can lead to frost buildup on your freezer walls. To make sure the door is sealing, slip a dollar bill or a sheet of paper between the gasket and the freezer and then close the door. If the bill or paper pulls free with little or no resistance, the gasket isn't sealing properly. Wipe the gasket with a damp cloth to remove dirt, grease and other residue. If the gasket is damaged, replace it with a new one. Sometimes frost can accumulate on the back panel of your freezer if the door is open too long or too often. When you open the door, you let warm, humid air inside, and this condenses and freezes. Make sure there are no packages preventing the door from fully closing, and limit how often you open the door by removing what you need all at once.
2)Ventilation is important because it ensures your freezer stays cold. If something inside the freezer blocks the internal vents, the freezer may become warm, causing condensation to form on the walls, and eventually leading to frost buildup. When loading your freezer, make sure there are no items resting against the rear wall of the freezer and space the contents out as much as possible to improve ventilation.
3)Side-by-side refrigerators with a built-in ice maker may accumulate frost if the flap on the ice dispenser doesn't close properly. This allows warm air to enter the freezer side, condense and freeze, causing frost buildup over time. Open the freezer door and examine the flap inside the ice chute. It should be flush against the housing. If it is not, empty the ice bin and make sure there is no ice or debris preventing the flap from closing.
4)If your freezer door closes properly and nothing is keeping it open, frost buildup on the back panel may indicate a problem with the freezer's self-defrost system. The self-defrost system turns off the compressor for a short time every six to 12 hours so it can turn on the defrost heater. This melts any frost buildup on the freezer coils, and the water drains to the pan beneath the freezer. If this component fails, frost continues to build. Move the contents to another freezer and turn your freezer off for 24 to 48 hours to manually defrost the interior. If frost builds up again, contact a qualified appliance repair technician to inspect the defrost timer and repair the problem.
Oct 29, 2017 | Whirlpool GR9FHMXP Top Freezer...
Water leaks from below the fridge a couple times a day?
There are several sources of water from within your refrigerator. The most likely source for the frequency you are experiencing, "couple of times a day", is the defrost system.
When your refrigerator defrosts, a heater that surrounds the evaporator piping behind the freezer back wall comes on which melts the frost on the coils causing the water to run into a drain below the evaporator. This drain can clog up with foreign particles accumulating in the drain. The clogging can cause the drain to spill over into the floor of the freezer and run out the door along the bottom of the freezer door through the door seal. This will usually leave an ice sheet on the floor of the freezer. If you do not have an ice sheet...the drain is not clogged.
The second method by which water ends up on the floor is a broken pan beneath the refrigerator intended to catch the water as it leaves the drain in the freezer. To test this, use a turkey baster and pump water into the freezer drain at the rear bottom of the freezer behind the wall using the holes in the wall. Watch under the refrigerator to see where the water ends up.
Performing these actions will lead you to the solution.
Nov 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool sideby side ref. ED5FHGXKQ02 condensation on walls of freezer causes accumulation of water on freezer floor
Most times that is a defrost drain blockage behind the rear wall of your freezer back panel. Sometimes the door seals allow some moisture to accumulate if air is drawn in through the seals leaking or the door to the dispenser is stuck open. But when you say it has accumulated in a pool of ice on the bottom of the freezer then the drain is blocked. I'm going to send you to some links and I want you to read through most of what is said and just use the parts the refer to your refrigerators problem, Sea Breeze
Sep 07, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Ice is forming at the bottom of the freezer and freezing the bottom draw shut. it doesn't appear to be leaking and the door shuts properly. it's supposed to be a frost free freezer....
Causes:
High humidity in the immediate area causing condensation to freeze at the door opening
A frozen defrost drain line not allowing water to drain off when the unit is in defrost
A bad door gasket causing an air leak
Some freezers have a heated perimeter to reduce condensation. If the stop working, moisture can accumulate arounf the door perimeter and freeze.
Leaving the door open too long or something obstructing the door
Mar 28, 2009 | Freezers
Ice build up
Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
Oct 02, 2008 | Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
69 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
