Back to:
Tags:
2000 Nissan Maxima
Water pump
posted by humble2008 on Jun 07, 2008
I have a 2000 max in order to change my water pump do i have to change the the timeing belt? and is there two belts that have to be changed?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 16, 2008
Not Rated (0)
cammykins
Rank:Wiz Wiz
Rating: 82%, 154 votes
What is the model of your car, year and how many miles do you have on it?
Normally they say you are to replace the belt within 80k miles with the "tune up" which some times if it doesnt look too cracked you can push it possibly another 10k or more miles but it's not a good idea since it keeps things on schedule and running smoothly. If you are handy with cars or know someone who is educated as a mechanic you can have them replace it for a simple $30 or more but just purchasing the proper belt for your car make, model, year. etc. That is what we did. Otherwise most places will charge you an arm/leg to have them replace it for you--we're talking $100 as high as $200!! for a $30+/- belt!
As far as the water pump you'd also have to verify that with a mechanic. There might be more tied to it then you think there is. Some places will offer you a free estimate [make sure they are trusted!] then you can run from there on what you might need in order to fix it or have a mechanic you know replace it. I'm sure it's most likely going to cost you well under $2K if you have a reliable source replace those items for you.
But most of the time you do not have to place one with the other. Those go within their own schedule times [belt] and others just go out on you [aka: water pump].
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on water pump:
I don't want to Accept this solution
Can you Help with these Cars problems?
Mitsubishi Lancer
My right headlight keep on going out after i have replaced...
2000 Nissan Maxima
when I put in a CD it says CD then CD ERR. I have to power...
2000 Nissan Maxima
it was cyl.#4 i had change that coil already. the car run...
2000 Nissan Maxima
2000 holden astra no oil pressure found rounld plastic...
2000 Nissan Maxima
I bought the light bulbs from auto parts store, How do I...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
