Question about Sony KP-53S65 53" Rear Projection Television
Sony kp-53s65 rear projection
I've isolated the problem with this set as c514 on the board. Problem is its toasted and I can't see a part # and don't have the manual for it. Can you help? AL
  • KjunClay Aug 13, 2008
    I think I have the same problem: The red light on the front blinks steady and I get nothing after pushing the power button. Does this sound like it would be the C514 Capacitor? And if so is there a service manual available to use also?
I found this info.. hope it helps...
390PF 2KV CAPACITOR, Sony Part Number: 1-162-133-00
Posted on Aug 13, 2008
  • Sony Master
  • 8,617 Answers
C514 is a ceramic capacitor its ratings are 390PF 2KV @10% tolerance
Posted on Jun 08, 2008
Burnt out EY34
EY34 is a location near a small blue capacitor that commonly burns up; Location number for the cap should be C514 and the values of it are 1,000 pf (pico farad) at 2 KV (2,000 volt rated).
Often if it is burnt it is the only problem and both Hitachi and Sony used the same identical part in several of their sets.
Let me know if you have questions.
sd tech
Sep 25, 2011 | Sony KP-53S65 53" Rear Projection...
When I turn on my sony (KP 53S65) the screen doesn't light up
The most common problem for this TV is a bad capacitor (C514)
Call a good TV Tech and have him check for that first. Should be a $125 job at the most
Jul 31, 2009 | Sony KP-53HS30 53" Rear Projection...
What is the root cause of capacitor C514 to fail?
I would first suspect the Flyback unit on the D board of causing this (this regulates the power the the other boards and the rest of the TV!
I think that is where to look!
Please rate my response
Thank You!
Jan 17, 2009 | Sony KP-53S65 53" Rear Projection...
Trying to identify a capacitor on the power supply board
IF you have the G BOARD part #A-1316-367-A it's:
1-162-133-00 CERAMIC 390PF 10% 2KV
IF you have the G BOARD part #A-1316-422-A it's:
1-161-754-00 CERAMIC 0.001MF 10% 2KV
Jan 04, 2009 | Sony KP-53S65 53" Rear Projection...
KP-53S65 blury at times
the screen control and the focus control on the flyback transformer need to be turned down a little
Nov 12, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP 53S65 Rear Projection TV
I don't know if this will help you but I just experienced a similiar problem with a sony kp-53s35.
It turns out that a fluid leaked out of a rubber boot on one of the guns( I have no idea what the fluid is or why it is corrosive), down to a circuit board and started to desolve a jumper wire. when it had eaten away enough of the wire, the residue or solution1.gif was conductive enough to cause an arc to a ground bus bar that ran along the circuit board. The TV still worked but would crack and pop like firecrackers inside.
I was able to increase the distance to the ground source by bending the bar away. Then I scraped and scrubbed the board with contact cleaner to remove residue and replaced jumper wire.
Has worked fine since.
Mar 18, 2007 | Sony KP-53S65 53" Rear Projection...
Need to know part number or value for C514 in horiz out put circuit for kp-53s65
C514 has three different values possible. Just use this value as it has worked fine for me in the past. 680pf /2kv Sony part# 1-162-116-00
Jan 20, 2007 | Sony KP-53S65 53" Rear Projection...
Standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Dec 11, 2006 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
242 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
