Question about Kitchen Gourmet 2 Slice Waffle Maker
How long do you cook waffles with the KItchen Gourmet Model SW-035A waffle maker
2 Suggested Answers
SOURCE:
  • 480 Answers
SOURCE: I open a Kitchen Gourmet Waffle Maker Model
i would take it back to the place you bought it at and have them replace it if not there should be a phone number on your instruction manual that you can call for customer service.
Posted on Dec 25, 2010
Once the waffle is cooked how do you open the iron?
You need to spray oil on the waffle iron top and bottom before you put the batter in so it doesn't stick.
When it's cooked (steam mostly stops coming out), just lift the top off, and use a fork to lift your waffle out.
Aug 27, 2015 | Kitchen Appliances - Others
How long do i keep the waffle batter in
Shortly after closing the waffle iron it will start to steam, Watch when the steam stops and open the iron. The waffle should be golden brown.
After you get the hang if it you can adjust the cooking time for lighter or darker waffles. There are videos on Youtube that may help too.
Jul 03, 2014 | Black & Decker WMB505 Waffle Maker
Lost instruction manual
Instructions
How to Select a Waffle Iron
Determine what type of cooking you'll be doing. If you're planning on preparing one waffle at a time, for example, then the smallest model of waffle iron will be the best fit for you. On the other hand, if you plan on frequent entertaining, or if you have a larger family, you'll probably want to choose a deluxe model.
Decide on the type of waffle maker that you'd like to own. There are a number of these available, ranging from simple differences---round versus square, for example. Some feature removable cooking elements that can be replaced with others, such as grilled sandwich attachments.
Internationally Accredited Hospital Visit Now to Get a Healthy Life!
www.apollohospdelhi.com
Take the varying grades of quality available in waffle makers into account when choosing one. This point may seem obvious---choose the highest quality waffle iron, right? Not necessarily. If you plan to use your waffle maker on rare occasions, say, once every couple of months, then you won't need the highest quality available. Waffle making several times monthly, however, will warrant a sturdier model with thicker non-stick coating applications applied to the cooking elements.
Consider the cleanup aspects of each waffle iron that you're comparing. Some waffle irons feature removable cooking elements; this is a tremendous benefit when cleanup time comes around, as it is much easier to clean the grill elements separately than attached to the entire waffle iron.
5
Take brand into account when making a decision. Brands with a reputation for high quality are usually more expensive than lesser-known labels. However, this doesn't mean that an "unknown" brand can't produce a good product. When taking this aspect into consideration keep in mind the requirements that you need and purchase a waffle iron accordingly. Additionally, many celebrity chefs have endorsed cooking products---including waffle irons---which adds a little more cost to the product. Finding the company's non-endorsed model of waffle iron will mean the same quality at less cost.
Jan 11, 2013 | Kitchen Appliances - Others
Cleaning your waffle iron WPLT4
Let me start by telling you WHAT NOT TO DO.
  1. Never clean a waffle maker while it's still hot. Let it cool completely.
  2. Never dunk your entire waffle maker in water.
  3. Never use scouring pads, steel wool or abrasive cleansers.
  4. Never use a knife or pointed object to clean your waffle maker(I've actually seen that advised on less reputable sites).
When it comes to cleaning a waffle maker, your first source of information should always be the owner's manual. There are many different kinds of waffle makers, so your buddy Mr Breakfast will gladly defer his expertise to the company that makes your waffle maker.
What I can speak about is my own favorite waffle iron. It's a modern electric waffle iron with non-stick and non-removable baking plates. That's the same kind you have? Oh good. It looks like you came to the right guy.
Cleaning the baking plates:
  1. Remove any small puddles of oil with a dry paper towel.
  2. Brush away any crumbs with a soft-bristled kitchen brush or old toothbrush.
  3. Remove any batter stuck to the iron with a rubber spatula.
  4. To remove really-stuck-on batter, douse the baked-on batter with cooking oil. Wait 5 minutes for the batter to soften. Dab the batter off with a paper towel or cloth.
  5. To prevent staining and long-term oil build up, wipe down the baking plates with a damp cloth or paper towel.
  6. Make sure the waffle iron is completely dry before storing.
To clean the exterior, wipe down the housing and handle with a damp cloth.
Keeping it clean:
There are a couple things to remember to make sure our kind of waffle maker stays clean.
  1. Unless stated otherwise in the manufacturer's instructions, you should never coat the baking plates of a non-stick waffle iron with cooking spray. Over time that will give you a gummy build up that will turn your waffle maker to junk. Today, when a waffle maker makes the claim that it's non-stick, they really mean it. The only oil you need is the oil in the recipe. If your waffles are sticking, it's your batter that needs more oil, not your waffle maker.
  2. Unless stated otherwise in the manufacturer's instructions, don't use soap to clean your baking plates. Soap can be the enemy of a non-stick surface. Oil - on the other hand - can be a great friend. It creates a thin layer that helps maintain the non-stick surface. Soap will completely obliterate that layer of friendly oil. Harsh soaps can deteriorate the manufacturer's non-stick surface over time.
Mar 05, 2011 | Salton WM4 Waffle Maker
ProLine waffle maker sticking. Followed all direction from factory. No Pam used.
The plates on the waffle maker need to have some sort of cooking oil or butter to lubricate and prevent your waffle mix from sticking.
Spray some PAM on the plates once the correct temperature has been reached, or alternatively brush on a little melted butter or vegetable oil. Pour in your waffle mix and when cooked the waffle should lift straight off.
Jan 16, 2011 | KitchenAid Pro Line¿ Waffle Baker
How should I clean this product?
you should not submerge this completely in water but whip it out with a soapy dish rag .
Jan 01, 2011 | Kitchen Gourmet 2 Slice Waffle Maker
I open a Kitchen Gourmet Waffle Maker Model #SW-035A The unit plastic cover is broken. The box was not crushed. Where do I exchange the unit for a new one. Thanks for your help in advance James...
Dec 25, 2010 | Kitchen Gourmet 2 Slice Waffle Maker
My Waring Mod# 150 Waffle maker went out in the middle of cooking a waffle and stopped cooking. The red light is on ,but the green light wont come on.
there is a thermostat in the waffle maker if its got over heated the thermosts will have cut out,, or burnt out?
Oct 17, 2010 | Waring WW150 Waffle Maker
How do i clean a phillips kb5500 waffle maker. can you submerse it at the plates don't seem to detach
no,,,,dont put it into any water,,,,heat up the waffle maker then wet a dish cloth and put it in the waffle maker for a fuw seconds,,the steem will clean the plates and you can then wip the plates off with a "hand full" of paper kitchen towel so you dont burn your hands,,, to keep it clean just after cooking put a drop of cooking oil in the waffle maker wip it round with kitchen paper
Jun 27, 2010 | Kitchen Appliances - Others
Kitchen Gourmet 2 Slice Waffle Maker Logo
82 people viewed this question
Top Kitchen Gourmet Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
George Scott
George Scott
Are you a Kitchen Gourmet Kitchen Appliances - Other Expert? Answer questions, earn points and help others
