First try giggling shifter or put in neutral. Let me know if security light is flashing. Please see my tip at http://www.fixya.com/cars/r6222268-engine_doesnt_crank_turn_over . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Testimonial: "Simple solution made car turn over!!! JT is a GURU!!!! I would recommend this Guru anytime! Four Thumbs Up!!!! Thank you JT!!!!!!!!"
Thanks for the compliment. The problem is with your safety interlock switch. The switch is designed to prevent starting the car in gear but is going bad. The switch is mounted on the top of your transmission where the shifter cable attaches and looks like a thin black box. Cost for a new switch is under $20. I will paste instructions below from autozone.com on steps to replace the part.
R
Apply the parking brake and block the wheels.
Place the vehicle in the neutral position.
Remove the shifter linkage.
Disconnect the electrical harness to the switch.
Unfasten the switch, then lower from the vehicle.
To install:
Place the shift shaft in Neutral.
Align the flats of the shift shaft to flats in the switch.
Install the switch assembly.
If the bolt holes do not align with the mounting boss on the transaxle, verify the sift shaft DO NOT ROTATE THE SWITCH. The switch is pinned in the neutral position. If the switch has been rotated and the pin broken or when using an old switch, adjust it.
Tighten the switch screw to 18 ft. lbs. (25 Nm).
Remove the gauge pin.
Attach the electrical connection, then connect the shifter linkage.
ADJUSTMENT
Place the transaxle control shifter in the neutral notch on the detent plate.
Loosen the switch attaching screws.
Rotate the switch on the shifter assembly to align the service adjustment hole with the carrier tang hole.
Insert a 3 / 32 in. (2.34mm) maximum diameter gauge pin to a depth of 5 / 8 in. (15mm).
Tighten the attaching screws.
You are a Guru-that just worked! Wouldn't start in park so tried neutral and it kicked over.
What was that all about and what should we do to service this car if necessary?
Thank you so very, very much!!!
