Question about Sony Ericsson Z710i Cellular Phone
Battery charger-leaking yellow liquid
Battrey charger was left plugged in to mains electric socket for at least 17 hours charging the phone,then phone was removed and the charger was left connected to the mains socket for 8 more hours until it was seen to be leaking a yellow liquid,is the liquid dangerous ?.
the phone still functions ok,the battery charger has been put into a sealed
bag,will it be safe to use again?.
  • Anonymous Aug 28, 2008
    yellow liquid,on main display
    Guru:
  • 458 Answers
No, it will not be safe to use it again, and yes, the yellow liquid is VERY DANGEROUS. Please do not use it again, you need a new charger.
i dont think the batery was affected, but if it was, you also need to throw it way and get a new battery.
Posted on Jun 08, 2008
My battrey is not charging
1) is the power source active (some wall sockets have a switch to render power there inactive -Australia)
2) is the charger plugged into an active power strip or an active wall socket?
3) is the charger damaged?
4) how long has the cell phone been charging? If the battery was completely discharged, it may take a bit for it to show a screen of it charging.
5) if the battery will not accept a charge, it will have to be replaced. Lithium batteries retain longer life spans if you charge them when power level is down to about 20 percent, NOT when they are completely discharged.
6) Better write down the battery number and amps when you pull the battery and keep it with phone documentation.
Jun 12, 2017 | Cell Phones
I have an Invacare Pronto M-91 Sure Step Electric Wheelchair that when plugged into wall socket is no longer charging chair batteries. The onboard Signet charger's led light isn't illuminating at all when...
The charger is defective. I would not try to charge it externally because if you charge it with a higher rate of current (amperage) than the original charger, it could explode or leak.
Jun 05, 2014 | Health & Beauty
No battery status in the screen of Garmin 255. I just bought a new Garmin 255, before charging, it can not on, meaning, the battrey is empty, that is fine. Pluging the car charger, the unit can turn...
The battery status only shows up when the satnav is disconnected from the charger. Your first charge should be a continuous charge until the battery is full. This can be done by connecting it to your computer for 8 hours approximately or 4 hours to your car cigarette lighter socket or 4 hours to an, optional extra, mains charger.
May 20, 2011 | Garmin Nuvi 255 GPS Receiver
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
I need to know how to charge the batterie om my sisters merits wheelchair,i do not know how to plug it up,,or if the charger is located on the frame someplace or if its freestanding.plain and simple i do...
sking the off board charger is a 5 inch by 3 inch rectangular box with a power plug on one end and a round silver 3 prong plug on the other. The charger plugs into the charger port located under the front of the joystick. Plug the charger plug into the joystick and then into the wall socket. When it is fully charged the light on the chrager will turn from yellow to green. Unplug the power from the wall socket first then unplug from the joystick In ither words always have the charger unplugged when you plug the charger up to the chair Now if the chair has an onboard charger there should be a power cord that just plugs into the chair usually somewhere in the rear of the chair all you have to do is plug it into a wall socket and charge away Hope this helps you
Mar 10, 2011 | Electric Mobility Merits Electric...
Invacare m51 scooter. I just replaced the batteries in my dads chair. We charged it all night the first night and it ran great the next day. recharged it for several days after using it and now the battery...
Sweet you do not need to leave the charger plugged in for several days. Sounds like there is a charger problem When you first plug the charger in with batteries depleted you should be getting a red and yellow light with the yellow turning green when fully charged. now the charger (built in) could have become unplugged from the power module located in the rear of the chair behind the black cover. To get to it you have to remove the seat, shroud and batteries then using a phillips screwdriver and adjustable wrench remove the black cover. The charger cord will be the last one on the left with a small 4 pin white plastic plug make sure it is well seated in the power module. If it isn't loose then you have a problem with the charger or the circuit. Now if you know of a friend that has an off board charger for a chair or scooter that you can borrow you can charge the batteries using the charger port located under the front of the joystick Plug the charger into the port then into the wall socket and let er rip Charge until the light turns green overnite is a good habit to get into If the onboard charger is bad I would suggest you by an offboard charger (cheaper) Now if Medicare paid for your Dads Chair then they will pay for any repairs even batteries and you can contact the provider that your dad got the chair from to see if they will repair it Hope this helps
Feb 17, 2011 | Health & Beauty
My nuvi 760 has never charged from the car. Is there another way to charge it?
It can be charged from a computer. Connect it to your computer with the mini USB lead and it will charge. It takes about 8 hours compared to 4 hours with the car charger or with a mains charger.
If your car charger isn't working it's likely that the fuse is blown. I presume you checked the cigarette lighter socket first and that it's working. If not try something else in the socket and make sure that's not the problem.
At the end of the charger lead plug, that goes in the cigarette lighter socket, there's a ring. Unscrew the ring and the plug comes apart. Be careful not to lose the silver tip. When the plug comes apart you'll see the fuse. You'll get a replacement in any car electrics shop or anywhere that supplies satnavs. I hope this solves your problem.
Jan 08, 2011 | Garmin GPS
My nuvi 760 doesn't charge in the car. is there another way to charge it?
Jan 08, 2011 | Garmin Nuvi 760 Handheld GPS Receiver
CHARGING FAULT
hi friend,
step 1
Make sure you have all of the accessories. Some phones need special adapters for charging. If you're having problems fitting the charger into your cigarette lighter socket, check with your cell phone company. You may need an adapter ring.
  • Step 2 Find the right battery. Certain phones can only be used with batteries from the same company. If you are using a counterfeit battery, be aware that you may not be able to charge it with your current set up.
  • Step 3 Read the manual. Something as simple as charging a battery may take specific instructions. For example, some cell batteries need to be charged immediately while others come fully charged.
  • Step 4 Use your charger. Most cell phone chargers are easy to use plugging right into your phone and home outlet or car electrical cigarette socket. Read your manual on specific steps needed for charging your phone.
  • Step 5 Try Cellboosts. These convenient devices are disposable battery packs that plug into your phone, charging it when the charger isn't accessible. Cellboosts usually last for an hour and are not compatible with all cell phones.
  • Step 6 Go solar. This innovation allows you to charge your phone wherever there is light. Just attach your cell to a portable adapter and let the light do the rest
  • hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Televison & Video
    Sony Ericsson K770i Phone won't turn on red light apears on the top left, any suggestions?
    This has happened to me twice - the first instance occurred when I'd only had the phone a few days and the second occurred today after months of trouble-free use.
    On both occasions the phone wouldn't charge via the mains charger - it wouldn't switch on even when plugged in and neither the battery or the charger were warm to the touch after hours of charging, indicating that nothing was happening.
    The solution for me was to connect the phone to my PC via the USB cable - nothing happened at first, the PC didn't recognise the phone and it remained lifeless. However, I left it attached to my PC and after 10-15 minutes it suddenly whirred into life.
    The battery was COMPLETELY flat despite my attempts at mains charging, so I let it charge via USB for a while then transferred it to the mains charger. This time the mains charger worked.
    I've no idea why, but this has worked for me twice so give it a try.
    Jun 07, 2008 | Cell Phones
    Sony Ericsson Z710i Cellular Phone Logo
    141 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    270rexton
    270rexton
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
