Question about iRiver S10 2 GB MP3 Player
Iriver s10 problem
Hi
my iriver s10 wont turn on and i dont know why, i press many time on the reset and i cant turn on the device
  • 1 more comment
  • Anonymous Oct 31, 2008
    hi my iriver s10 is locked and it's in korean. how do i unlock help help help help help help help help help help help help help help help
  • willchatters Nov 16, 2008
    yeh my iriver s10 also will not turn on,it has completely dided on me, restart button does not repsone and when try and charge it, the charging icon doe snot appear, helpppppppp!?
  • serdevi Dec 01, 2008
    file system is damage
There is a 'reset hole' next to the power on switch - you need a pin to push into the reset hole
I do not use the software that comes with the S10 - it always wants to go on to the internet and re download itself. If I want to copy music over I use windows explorer and copy MP3s into the music folder
Here is what I do when I need to reset - format S10 machine from windows
1. plug the S10 into the computer via the USB key
2. You should see the S10 in Windows Explorer as a portable flash disk
3 Right Click and select format - Warning! all data will be lost if you have not backed up!
4 In the File System drop down list select FAT (the default is FAT32)
5 Click start to format the device.
6 Once the S10 has been formatted unplug it from the computer
7 Turn the S10 on and scroll down to SETTINGS
8 Right click and scroll down to Advanced
9 Right click and scroll down to Format Device
10 Right click and then click OK to confirm
On the same menu as Format Device is Reset All Settings - I recommend you do this as well.
11 Plug the S10 back into the computer
12 When you look at the S10 in Windows Explorer you will see it has created some extra folders
13 drag and drop MP3 music files into the Music folder and away you go!
14 you can create additional folders in the Music folder if you want to organize your music
Posted on Jan 01, 2009
Reset and it will work
Posted on Sep 17, 2008
I made mine work, i made sure i pressed the reset button then charged it quickly, the lights turned on and left it chargiing , it is working again now!
Posted on Nov 16, 2008
Put it on charge to make sure it is powered before trying to switch on
Posted on Sep 13, 2008
IRIVER WONT WORK AAAAHHH HELP!!!!!? my iriver wont work when i try to turn it on it comes up and says system files missing to restore the system files, connect to iriver plus wat dose that mean i have...
When system files are missing on the player, you will need to reinstall the FIRMWARE.
When looking online for the connection type for the H10 / H10JR, I can see 2 CONNECTION TYPES for the H10 / H10JR:
1. MTP, when using Windows Media Player 11 ( WMP11 ), for the H10.
2. iRiver Plus, when using iRiver PLUS, for the H10JR.
The connection type determines what software on the computer will be used for transferring media.
Each software on the computer needs corresponding firmware on the player to be installed.
When the player itself comes up with the information to connect to iRiver PLUS, this is the correct software for this device probably. Then the device is a H10JR.
When not having the program iRiver PLUS, go to the iRiver support site, for the download:
http://www.iriver.com/flash/index.asp?code=0302
In the left column click Plus3 and go for the download.
Run iriver plus 3 and then select [Tools > Portable Device > Firmware Upgrade] from the menu.
Need more help ? Just post a comment.
In case you have the other model player, the H10, let me know if you need assistance for its recovery.
Dec 15, 2009 | iRiver H10 MP3 Player
IRive Mplayer- cant turn on
maybe u just need to press the 'on' power a little longer until the green light reappear again. then u press it one more time. I hope it will work. bcos the same thing was happened to me, too.
Nov 23, 2008 | iRiver Mplayer MP3 Player
I river s 10 not workng
Not sure of the real answer for this but I use my Iriver like an external hard drive. I just drag and drop my music on without using the Iriver software. Have not had any problems yet.
Aug 12, 2008 | iRiver S10 2 GB MP3 Player
My iRiver T10 2GB wont turn on. Ive changed the battery already. I was updating my iriver2 when the firmware update told me to remove my iriver for it to take effect. then when i took it out my irivers...
Press and hold the reset button for one minute and then see if it boots, after that try reinstalling the firmware if needed still.
If you ever need software for your by the way visit this website
http://www.opendrivers.com/company/27302/iriver-free-driver-download.html
Jul 03, 2008 | iRiver Audio Players & Recorders
Turning off iriver S10
HI I am sure you have an answer by now but if you continue to hold down the button on the right hand side (opposite side to the volume buttons) it will turn off.
Apr 25, 2008 | iRiver S10 2 GB MP3 Player
Cant charge iriver s10
I do not believe there is... but you can purchase the chargers from ebay pretty cheap.
Apr 08, 2008 | iRiver S10 2 GB MP3 Player
Iriver S10 how to remove cover?
I was able to open mine using my nails, it's clipped on the borders inside and there is a bus plug. I think the operation is a bit risky, as it's extremely mimiaturized, and dont loose the buttons ! If you have to solder, make it as flat as possible, or you wont be abe to close it anymore...
Dec 25, 2007 | iRiver S10 2 GB MP3 Player
Iriver s10 how to release hold...
press and hold both volume buttons for 3 or 4 sec
Oct 29, 2007 | iRiver S10 2 GB MP3 Player
iRiver S10 2 GB MP3 Player Logo
1,685 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
