Question about RCA Thomson Digital Cable Modem (DCM305R)
When i use my phone i lose my wireless internet connection
  • 2,571 Answers
I take it you are using an adsl connection. Have you installed the micro filters correctly?
You need to install a micro filter at every junction and socket. If you dont, you will loose your internet while using the phone
Posted on Oct 24, 2010
SOURCE:
It keeps losing the internet connection.
Are you connecting via wired or wireless connection. If wireless there might be another device such as a cordless phone that is interferring, or your TV is just on the edge of the range for your wireless router.
Aug 17, 2015 | Televison & Video
Lose nettalk connection from router after on phone for twenty minutes
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 28, 2013 | netTALK DUO Wi-Fi VOIP Internet Phone...
I keep losing my internet connection when I use the wireless router. When I disconnect the wireless router, internet works great but when I reconnect it it keeps cutting out. I unplug it for ten seconds...
Try changing the channel to 11. Cordless landline phones often interfere with the default router channel. It can even be your neighbors phone that is conflicting.
Feb 06, 2011 | D-Link DIR-615 Wireless Router
I keep loseing connection when a phone call comes on house phone
  • call your ISP first to fix the issue on your line problem
  • after that after issue of trouble ticket and resolution of your ISP
  • then your router support
  • thanks
Aug 11, 2009 | Zyxel Prestige 600WH Wireless Router...
Losing wireless connection
Your phone frequency must be the same with frequency of your wireless router. To avoid this you access the web GUI of your router page..http://192.168.1.1..( in most cases)...and go to the wireless settings...look for the frequency tab and change the settings ( you can try 1-10). DO trial and error...
Jul 11, 2009 | Computers & Internet
Lose internet connection when phone is in use
Your cordless and wireless mode is running on same frequency.
You can do couple of things...use the wireless mode in b instead of g in the router.
Else use a different cordless phone which runs in 5.8 or 6.0 frequency.
Hope this helps.
-Pankaj
Mar 26, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Cordless phones and wireless connection
you have to login to the router. Once logged in you will go to your wireless tab and and will be able to adjust the channel that the router is transmitting on.
May 31, 2008 | Linksys Wireless-N WRT150N Router
Lose wireless connection when the phone rings...
You won't have to buy a new adapter as long as the new router uses the same standard (i.e. 802.11b, g or n).
May 01, 2008 | Dell Wireless 2350 Router
Need help
You are losing your internet connection because of interference with the wireless router and cordless phone. Try either switching the channel on your router or on your phone. That should fix your problem.
Apr 15, 2008 | Dynex Enhanced-G Wireless Broadband Router
RCA Thomson Digital Cable Modem (DCM305R) Logo
53 people viewed this question
Top RCA Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
