Question about Kenmore 72622 Gas Dryer
Our Whirlpool gas dryer, Model # LDI5701W1 stopped working in the middle of a cycle. Power supply is fine. With door closed, I can't hear the timer humming. Could it be a door switch, timer,?
  • 3,074 Answers
It maybe but here is a website that shows how to test them, it may be a loose or broken wire, a reset button on the motor, or other things:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Oct 24, 2010
SOURCE:
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
Error code of three beeps on a whirlpool dryer model 68972981
Hi troy crawford,
Well if it beeps for 3 times and then shut off when you press start it means that the dryer thinks that dryer door is open. You will have to replace your door switch to fix the problem. or you can also try closing the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. many time it will works...
Good Luck
Regards
Nov 07, 2011 | Whirlpool Dryers
LER4634J01 Stopped in middle of a dry cycle, will not restart, I can hear the timer functions click but it is like there is no power when you hit the start button, I have checked all connections including...
Wait apx 90 min and try it if it starts your dryer needs to be cleaned out. also ck your vent to the outside. If you have a ohm meter you can ck the switch that closes with the door to make sure it is working. The other problems are motor switch located on the front of the motor. This switch controlls the motor on and off and speed. If you take your dryer apart there will a paper schematic inside if you can read a schematic it is very simple to diagnose your problem. Remember to unplug your dryer before attemptingany repair.
Aug 08, 2010 | Whirlpool LER4634J Electric Dryer
I have a whirlpool dryer, model number lgt6634dq0. The timmer does not stop after the drying cycle has ended. My guest it might be the timer. After the dryer has finished it's cycle I can hear the timer...
HI. The timer will be the culprit here. The timer motor is damaged, and the cogs seem to be worn, as well. I recommend replacing this failed timer mechanism. Once replaced, the unit will operate correctly.
Dec 03, 2009 | Whirlpool Dryers
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Kenmore 72622 Gas Dryer Logo
147 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
