Question about Cycling
How to raise the handlebars on my Schwinn Trail Way Hybrid Bicycle?
5 Suggested Answers
SOURCE:
dunnbiker
  • 8546 Answers
SOURCE: How do you raise the handlebars on a Schwinn
Your options are limited. Once cut, the steerer tube can be no higher than it is.
http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise
and reach might give you the added height you need. If you LIKE the handlebars, the stem
is the best option as most new ones come with front loaders (detachable front caps) that
allow replacement without stripping components off one side of the handlebar. In minutes
a Bicycle Shop could swap any number of them onto your bike for you to try.
I would recommend you get used to the position that yields a careful compromise between
aerodynamics and uprightness when needed.
Posted on May 07, 2011
  • 6 Answers
SOURCE: raising the handlebars
If your bike is older it might have a quill stem.To raise this you have to undo the allen key headed bolt situated where the bar & stem attach to the bike.It is often obscured by a plastic plug to prevent water rusting the bolt head.If this doesn't go high enough an adjustable quill stem must be fitted.
If you have the modern design of stem(A-head)you will have to replace the stem with an adjustable type which can be set upto 60 degrees.
Posted on Sep 29, 2009
dunnbiker
  • 8546 Answers
SOURCE: How do you raise the handlebar of a Schwinn Ridge
The handlebars stem is an Aheadset-style and as such has spacers below it to set its height. Once the steerer tube is cut to fit the combination of stem and spacers there's no going UP, only down. Stems can be replaced with different rises and lengths. Maybe that would help. A Bicycle Shop would have everything you need and the know-how to decide if you can mount the child carrer.
Posted on May 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: How can I raise the
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Posted on Jul 29, 2011
How can I get a manual for my new Schwinn 700c Men's Trail Way Bike S5984TG
Owner's Manuals ' Support ' Schwinn Bicycles
www.schwinnbikes.com/usa/.../owners-manua...
Schwinn Bicycle CompanyGet owner's manuals for Schwinn bikes here. ... Perfect for riders who want a classically-styled, comfortable and simple bike to cruise around town or on the ...
schwinn 700c trail way Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on schwinn 700c trail way related ... I need an owner's manual for 700c Schwinn Fifth Avenue Men's Hybrid Bike,.
[DOC]mens schwinn 700c trail way hybrid bike read expert
104.236.22.177/mens-schwinn-700c-trail-way-hybrid-bike-read-expert.doc
mens schwinn 700c trail way hybrid bike read expert , amazon customer reviews ...schwinn 700c men s trail way , men s 28 inch schwinn zeno hybrid bike ... Vw Passat Alltrack User Manual , John Deere Compact Utility Technical Manual ...
Jan 05, 2016 | Cycling
Download instructions for a Schwinn 700c Womens Third Avenue
Schwinn Bicycle CompanyGet owner's manuals for Schwinn bikes here. ... Perfect for riders who want a comfortable and easy-riding bike with convenient features for casual riding over all ...
700c Schwinn Third Avenue Women's Hybrid Bike, Plum ...
www.walmart.com/.../700c-Schwinn-Third-Avenue-Women.../2...
Walmart
Rating: 4.5 - β€Ž41 votes - β€Ž$149.00 - β€ŽIn stock
700c Schwinn Third Avenue Women's Hybrid Bike, Plum .... call your local store as complimentary assembly may be offered at that location. ... Manuals & Guides.
700c Schwinn Third Avenue Women's Hybrid Bike - Walmart ...
Walmart
Rating: 4.5 - β€Ž25 votes
Dec 21, 2015 | Schwinn Cycling
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
I have a schwinn fastback road bike. I want to know how to raise the handle bars?
A reputable Bicycle Shop would have fit the bike to you before you took it home.
Aug 13, 2011 | Schwinn Cycling
How can I raise the handlebars on my Schwinn 6061 bicycle?
Jul 29, 2011 | Cycling
I have a 4 year ols schwinn omni 191 C5 bike, i would like to raise the handle bars? can figure how to do it, used me hex thingy to remove bolt from sterring column and its would not raise, any help?
Jul 26, 2011 | Schwinn Cycling
I have a 24 inch ladies bike Ranger Schwinn trail that needs to have the handle bars raised. Can this be done at home? How much will they come up and what tools will I need? Thank you
Read:
If you had purchased the bike at a reputable Bicycle Shop they would have fit the bike to you before you took it home.
Jul 09, 2011 | Schwinn Cycling
How do you raise the handlebars on a Schwinn kicker pro bicycle?
May 07, 2011 | Cycling
Where can I get a owners manual for my schwinn 700c solitaire hybrid bike?
www.schwinn.com has all the owners manuals. they are generic, so choose the one for a geared Hybrid bike.
Jan 03, 2011 | Schwinn Merge 700c Men's Hybrid Bicycle
How do you raise the handlebar of a Schwinn Ridge AL 26" bike? I want to add a child carrier and I need to raise the handlebar to make it fit.
May 27, 2010 | Schwinn Ridge Al 26" Men'sboy's Mountain...
Cycling Logo
1,291 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
