Question about Toshiba P42LSA 42 in. LCD Television
Toshiba Integrated High Def LCD TV
My TV is about 2 years old. Never had a problem. Turned it on today and the color was abnornal. We seem to have no reds. Very green. I adjusted color and tint to no avail. Is there something obvious I'm missing?
  • Annejohn Jun 07, 2008
    Hi, Basti. Unplugged cables and TV itself. Nothing. Any other suggestions? Thanks!
  • Annejohn Jun 08, 2008
    Hi there. Still need help. Anyone with another suggestion? I appreciate it!
    Genius:
  • 1,447 Answers
Have you tried reseating the cables from the back of your tv? try unplugging it and replug it.
keep me posted, thanks!
Posted on Jun 07, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jun 07, 2008
    or you can check this link might help you as well click HERE
    Edgar Allan Pagayona Jun 09, 2008
    Have you tried connecting a different source, DVD? it might be the main board that you are having issues with then.
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Why has my Toshiba flat screen tv got a broad green horizontal band across the top?
One of the circuit board ribbons connected on the vertical control is probably loose there is a few vids on you tube for this repair , failing that some of the driver capacitors need replacement with higher voltage caps same microfarad.
Oct 15, 2014 | Toshiba Hi-Def Flat-Screen Lcd/Led TVs 32"...
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Can't get HD on my TV. Tried with every cable type but cannot get High Def
2 things have to happen. first, your tv has to be set for the correct resolution, second, You need to be recieving high def from your cable/sat provider.Your tv does not make programming high def, it allows high def.
Mar 10, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Old toshiba
Hi Veronica,
I need to know exact model number of your Toshiba TV to help you out.
You can find it at back of TV on some kind of sticker.
Oct 11, 2008 | Zenith R49W36 49" Rear Projection HDTV
The color red no longer works on my Toshiba 65HDX82 rear projection television. I am trying to figure out if it makes sense to repair. The rest of the TV seems to work fine.
if the tv is digital (high def) it does make sense its just a bulb most likely. if its analog it does not make sense. for a plasma or lcd with comparable picture to rear projection will be 5-6 grand and the colours will be comparable. less money will get you less than perfect colour and black levels on your set. only if your set is digital if not its a very different story if you need more help let me know i can guide into the right decision
Sep 21, 2008 | Toshiba Televison & Video
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Picture problems
The pixelation is probably caused by MPEG2 compression on the DVD and Virgin media video streams, the blur is probably caused becasue you are displaying a standard definition signal on a high definition TV.
However if a high-def source still has these problems then you may have a faulty TV, your best bet is too hook up a high-def source such as a HD/Blu-ray player or PS3/360 games console.
Should a high-def source look ok, then you may have some look changing the display settings on the TV to try and improve picture sharpness and color balance.
Thanks.
Nov 08, 2007 | Televison & Video
Toshiba 50H82 blown fuse f470
Solder jumper wires for prevent maintenance.....on signal
board = 008,010,017,048,600.............................T.
Oct 23, 2007 | Toshiba 50H82 50" Rear Projection...
Toshiba P42LSA 42 in. LCD Television Logo
181 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
